Old 09-02-2019, 10:12 AM   #1
Kamaro223
Kamaro223
Kamaro223's Avatar
Drives: 2016 RS/LT Camaros
Stereo settings changing when top opens and closes
When my top is closed and I open it, the sound settings sound like they change once I get the message that the top movement has completed. The same for when I close the top.
When the top is open it sounds much better then when top is closed. It sounds like it shifts the centering around and increases the output. I have the Technology package with the Bose stereo upgrade. I want it to sound "good" like when the top is open all the time.
Does anyone else notice this? Is there a setting I can change to keep it sounding "good" all the time?
Kamaro223 is offline   Reply With Quote
Old 09-02-2019, 12:58 PM   #2
Silverado57
Silverado57's Avatar
Drives: 2017 Camaro SS
I just confirmed this change in sound recently. I thought it was my imagination.
I'm guessing the rear speakers are being disabled/enclosed with the top down?
Following.
Kevin
Luceo Non Uro
Silverado57 is offline   Reply With Quote
Old 09-02-2019, 02:40 PM   #3
GroundhogSS
GroundhogSS's Avatar
I've never noticed that. I'll have to check when the Texas weather cools down a bit.
Richard
Delivered: 08/15/2016
#TeamBeckyD
Old 09-02-2019, 06:50 PM   #4
ArmanSS
ArmanSS's Avatar
Drives: '18 Camaro 2SS VERT
I noticed this too! Would love an answer as to why this happens.
ArmanSS is offline   Reply With Quote
Old 09-03-2019, 01:58 PM   #5
unixadm
Drives: 2017 2SS Convertible Nightfall Gray
I noticed this from the first week I bought my 2017 convertible back in 5/2017. I agree that the sound stage sounds much better when the top is open and I want to be able to set that and leave it like that permanently. No setting that I've found in the past 2+ years that I have had it. I assume they change it due to the wind noise and wonder if there is a wiring change we can make to fake out the radio to always think that the top is open.
unixadm is offline   Reply With Quote
Old 09-11-2019, 02:06 PM   #6
man0steel
Drives: 2016 2LT vert 2.0 R/S A8
Following
man0steel is offline   Reply With Quote
Old 09-13-2019, 05:26 AM   #7
Driski
Drives: 2016 Camaro Convertible 2SS
Following
2SS Convertible, MRC, NPP, A8, Garnet Red, Blk Bowties
GM CAI, Ported TB, Kooks Headers, E85
Driski is offline   Reply With Quote
Old 09-13-2019, 09:42 PM   #8
Plasar
Drives: 2017 ZL1 Vert M6
* I am just joining here with 1 month experience in a ZL1 vert - so hopefully the audio experts can say definitively - but the change in "tone" you notice top up/top down is probably some sort of "noise cancellation" being added when the vert top is down.
* Note: many of the stereo upgrades talk about "clipping the ANC (automatic noise cancellation) mics in the doors". I think I might know where these are - they might be little things that look like tiny defogger vents at the back of the door. There's a pic below with the door off.
https://www.camaro6.com/forums/showthread.php?t=499824
https://www.camaro6.com/forums/showthread.php?t=505338
* This is probably not the answer you want, but I think the Bose sound is not good in any top up/top down configuration, so I encourage you to investigate a stereo upgrade.
* Here's some links for you, and I am in the middle of my upgrade with the car at the shop and about 50% done.
https://www.camaro6.com/forums/showt...ght=drfeelgood
https://www.camaro6.com/forums/showt...stereo+upgrade
https://www.camaro6.com/forums/showthread.php?t=497975
https://www.camaro6.com/forums/showthread.php?t=503822
https://www.camaro6.com/forums/showthread.php?t=561714
Plasar is offline   Reply With Quote
Old 09-20-2019, 12:37 PM   #9
BigRed7181
BigRed7181's Avatar
Drives: 2016 2SS Glacier White Convertible
The processor is changing the way it sounds to account for the open top. I am not sure why they didn't just set it up to sound the same as when top down. The only work around I found was to change everything.
16 2SS SUMMIT WHITE / NPP / MRC / 6MT / CONVERTIBLE / TINT / SPLITTER / SPLASH GUARDS / WHITE KNEE PADS / WINDSCREEN / BLACK BOW TIES / HASH TAGS / DIODE DYNAMICS / GM SMOKED TAILS / MORIMOTO / ALPINE / HERTZ / BLENTMOUNT
BigRed7181 is offline   Reply With Quote
Old 10-13-2019, 08:02 PM   #10
Plasar
Post
Pg 52 of the 2017 manual, Closing the Convertible Top:
"If the radio is on, the sound may be
muted for a brief time due to a new
audio system equalization being
loaded."
