Old 08-21-2019, 02:54 PM   #1
angryBits
angryBits's Avatar
Drives: ZL1 1LE A10
PDR: Phantom Steering Angle ?
PDR says I'm providing steering input but I'm not.
Driving in a straight line, steering angle says 5-ish degrees.
When I come to a stop, steering angle drops to 1-ish degrees.
When I take off normally, steering angle shoots up to 8-10-ish degrees.
Alignment comes to mind but I'm not providing any input, the car goes perfectly straight. Could it be a silly sensor?
Current: 2019 ZL1 1LE A10
Mods: MPS4s Tires | Borla Atak | CF Steering Wheel
Previous: 2018 ZL1 1LE M6 | 2017 Z06 Z07 M7 | 2017 GS A8 | 2015 ZL1 M6 | 2013 GT500
angryBits is offline   Reply With Quote
Old 08-21-2019, 02:56 PM   #2
ABQautoxer
ABQautoxer's Avatar
Drives: 2019 ZL1
Any chance when you installed your steering wheel you got it one tooth off or the design isn't "square" to the teeth so when it was aligned the rack actually isn't perfectly centered?
ABQautoxer is offline   Reply With Quote
Old 08-21-2019, 03:01 PM   #3
angryBits
angryBits's Avatar
Drives: ZL1 1LE A10
Yes, actually I believe I did get it one tooth off and haven't gotten around to correcting it.
But would the steering angle sensor be able to know about that?
Seems like your steering wheel could be upside down and as long as the column is straight the input angle would read zero?
I'm guessing, this is new territory for me.
Old 08-21-2019, 03:06 PM   #4
ABQautoxer
ABQautoxer's Avatar
Drives: 2019 ZL1
Yes.
After install you straightened the wheel one tooth off, the rack was moved 5 degrees from center (speaking in terms of the sensor reading). Then you had the toe fixed to the car drove straight. So the sensor reads 5 degrees of input yet you are going straight.
Old 08-21-2019, 03:12 PM   #5
Tumba
Tumba's Avatar
Drives: 2017 Camaro 1SS 1LE Hyper Blue
I had my 1SS 1LE aligned during my first oil change and after my steering wheel was off about that much according to the PDR. My steering wheel also looked a bit off center to me. Turning it all the way to one side and looking at the flat bottom and then all the way to the other made it easier to see. Three alignments later the wheel is centered and PDR reads mostly 0 when driving straight down the road. It was a bit of a pain getting it done right but it drove me crazy.
Tumba is offline   Reply With Quote
Old 08-21-2019, 04:06 PM   #6
angryBits
angryBits's Avatar
Drives: ZL1 1LE A10
Yes.
Not saying you're wrong, but this doesn't make sense to me.
It's not like I pulled out the shaft or pinion and put them back into the rack 1 tooth off. It's just the steering wheel.
If the rack moved, the wheels turned, if the wheels turned, it would feel like my alignment was off and I'll feel pull.
However, when I drive straight, the steering wheel is visibly slightly turned to the right but that's because I mounted the steering wheel 1 tooth off from the original center on the shaft.
This makes more sense to me. It's more likely my factory alignment is slightly off and not enough for me to feel it pull but enough to register?
Regardless, I will try remounting the wheel back to center and I will get an alignment since I'm in need of both anyway
Old 08-24-2019, 08:22 PM   #7
nicktechla
nicktechla's Avatar
Drives: 2012 Porsche 911 Turbo S
I don't even understand the steering angle in the car, mine will throw some insane numbers sometime that aren't even possible. like 180 degrees, haha
IG: 2fast2nick
-- Current --
2012 Porsche Turbo S - PDK - Basalt Black Metallic
-- Past --
2017 Camaro ZL1 Coupe - Red Hot - A10, PDR - HRE P101
2015 Mustang GT PP - Whipple Supercharger
nicktechla is offline   Reply With Quote
Old 08-24-2019, 10:29 PM   #8
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
You OK? 180 degrees means half rotation.. steering wheel upside down. Full rotation... mind blown.. 360 degrees! I dont thing camaro has that many turns from center.
IF you had car aligned, they forgot to lock wheel in center position and aligned it.. or forgot to reset "center" position in the software.
ing for grip.
http://www.motorsportsne.com/
Old 08-24-2019, 10:35 PM   #9
nicktechla
nicktechla's Avatar
ha duh, I was thinking steering angle meant the steering angle of the wheels. That makes more sense. I think the wheel angle would be a more useful number on PDR though.
IG: 2fast2nick
-- Current --
-- Past --
Old 08-25-2019, 05:42 AM   #10
LT4
LT4's Avatar
Drives: all sold, getting another soon..
Going in a straight line doesn't mean you are not providing input. Taking your hands off the wheel is only way to not provide input, and you can't drive very far like that. I'm not sure the monitoring of the steering angle is that precise, or even has to be.
Larry
LT4 is offline   Reply With Quote
Old 08-25-2019, 07:24 AM   #11
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
you swapped the wheel...guaranteed the issue is with the wheel installation position compared to stock.
Old 08-25-2019, 07:31 AM   #12
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Gm wheels are not keyed ? Most i've seen have a missing tooth that guarantees it only goes back ONE way.
ing for grip.
Old 08-25-2019, 08:14 AM   #13
Stephen12ZL1
Drives: '21 ZLE A10
OK. I will rephrase to "it is likely" something is positioned incorrectly after the new wheel installation.
Old 08-25-2019, 10:45 AM   #14
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
Sounds like the sensor should be re-calibrated.
I had to have this done when I had the sensor replaced on my old camaro.
You will have to take it to the dealership to have thsi done.
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is offline   Reply With Quote
