![]() Drives: Chevrolet Camaro ZL1 Join Date: Jul 2019
Should my car be faster than this: VIDEO
I had a track event last week with my ZL1 and captured video and telemetry.
A friend also participated with his SS 1LE equipped with PDR. I sync'd the laps in a video to compare and was shocked to see that our top speed was only a few mph difference. I topped out at 124mph and he topped out at 122. Only a 2mph for having an extra 200HP?! In the previous corner running up to the long back straight, we were exactly on pace with each: We both ran the kink flat out at ~102mph, shifted from 3rd to 4th and braked about the same time. Is something wrong with my car? Should it have been faster? I've heard about the intercooler problem but my IAT was 93F so I don't think the engine would have pulled power. The timing started to pull back prior to the top speed however. It was at 18.5 degrees at 115mph and by the time I reached top speed, it had pulled back to 12.1 degrees. Ideas? Thoughts? Am I missing something? https://youtu.be/zkgwsR7qE_s |
@viurniel
Drives: 19 ZLE A10, 15 2SS, 90 300ZXTT Join Date: May 2016
First, I could obviously be the driver.
I would look into air in supercharger cooling system as the second suspect. |
#3 | |
![]() Drives: 2016 Camaro 2SS Join Date: Jan 2015
Your car is fine. He simply gets through the last corner better and accelerates earlier and harder than you do. If you pause the video at 32 seconds you can see he's still around the apex of the corner but you're pretty much on the straightaway yet hes at 85mph and you're only at 78. Simply put, he just nails the corner better and accelerates earlier than you did. Obviously it takes time and distance but you eventually hit a higher top speed (since you have more power) at the end of the straight even though he held a much higher speed and accelerated earlier than you did in the previous corner. Looks like you got through the next corner a little better and you hit 98 at the end of the straight while he only hit 91. Also, you realistically only have about 150 more hp than him once you factor in power to the wheels and your car is roughly 200lbs heavier which might be why you weren't able to corner quite as well. Last edited by bdavies11; 08-12-2019 at 03:37 PM. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '21 ZLE A10 Join Date: May 2012
Your car is fine he just gets back to the throttle way faster than you do
![]() ![]() ![]() Drives: ZL1 1LE A10 Join Date: Mar 2015
Looks like you apex'd early and had to lay off the throttle until out of the turn.
He swung wider and apex'd later allowing him to get on the throttle sooner. This can be a good approach before a long straight.
Current: 2019 ZL1 1LE A10 Mods: MPS4s Tires | Borla Atak | CF Steering Wheel Previous: 2018 ZL1 1LE M6 | 2017 Z06 Z07 M7 | 2017 GS A8 | 2015 ZL1 M6 | 2013 GT500 |
I appreciate everyone's feedback.
I've done some additional analysis to try and articulate my position, because I still think the ZL1 should have been faster. I've highlighted the area of the track and shown the trap speeds. You can see that we both had the same apex speed (77mph) at the corner before the back stretch (Workout). Then we go thru the high speed kink (Scream) and we are both flat out, full throttle thru here. That's when the SS 1LE starts to pull the ZL1 (100mph vs 103mph). Then the long back stretch into Blackrock, the ZL1 finally catches up, but just barely. The ZL1 tops out at 125 and the SS 1LE tops out at 122. The total distance of that backstretch is 1,500 feet. Maybe I'm up in the night but I think in that amount of distance, starting at basically the same speed (77mph), the ZL1 should have been a lot more than 3mph faster than the SS. |
#7 |
Thank you Al Oppenheiser!
Sorry if this comes across a bit harsh, but it's not your car, it's your DriverMod.
This course is almost all turns, and you're 2-7mph slower in turns: 1, 4, 5, 6, 7, and 8 (red boxes in the pic below are his speeds). He's also using more road than you in a couple corners allowing him to carry more speed with his lighter car. Brake later, carry more speed thru the apex, and get on the throttle sooner. Switching back to the stock GYSC3 tires may help here if you're having corner grip issues (i.e. if car control isn't an issue). Good luck
#8 |
Who Needs to KNOW?
The fix is easy, MORE track time.
#9 | |
![]() ![]() Drives: A few Join Date: Oct 2017
So OP, your car is fine. Just need to work on your driving a bit and this comparison is actually a good way to do that. Just don't look at JUST the specific points you seem to be focusing on.
-Dave
HPDE/DD: 2018 Camaro ZL1 1LE || HPDE/DD: 2015 Subaru BRZ ||Tow Vehicle: 2004 GMC Sierra 2500 8.1L || Weekend toy: 1994 MR2 Turbo || The other weekend toy: 1993 MR2 Turbo || Track car: 1998 Integra Type-R || Race car: 1996 Integra GS-R || New race car build: 1992 Honda Civic Hatchback Too many cars.. never. |
#10 | |
I agree, more seat time.
#11 |
![]() Drives: truck Join Date: Oct 2010
Your scrubbing a lot of speed, he’s not. I would try and get him in the passenger seat and have him show you his line. Or if your comfortable with it have him drive your car and shit shotgun for a couple laps.
#12 |
![]() Drives: Camaro ZL1 A10 Join Date: Feb 2018
I agree with prior comments. It's amazing how much exit speed does to a lap time. The ZL1, IMO, is harder to track than the SS 1LE also. In the later you can use more of the throttle and it's lighter. In the ZL1 you manage a bit more weight and have to manage the throttle more which isn't as smooth as a NA car. As you get more comfortable trusting the throttle, and corner/exit speed you'll be faster. Even the in the hands of Randy Pobst he was only about 2 seconds faster in the ZL1. At Sebring I found a video of an SS 1LE a little faster than me...but not for long
#13 | |
#14 |
