![]() Drives: ZL1 1LE Join Date: Jul 2019
ZL1 1LE Track/Street camber settings?
Hi,
I am taking my ZL1 1LE to the car shop to set camber and alignment for the car. Is there any setup that will work both for track and street? I guess that i need to set aligment etc every time i change from "street" to "track"? |
![]() Drives: 2019 zl1 1le Join Date: Jan 2019
I also had this question after talking to a few people who race cars this is what I came up with and did.
1. -2.8 of camber upfront will toast your tires on the street 2. depending on your driving skill level you may or may not use all the camber once it is set to -2.8 I set my car to -1.8 in the front and -1.0 in the rear seems to work for me. I can still drive the car on the street and I had a blast at watkins glen with it. just my 2 cents.
2018 GMC Denali 6.2L
2019 Camaro ZL1 1LE 6 speed Riverside Blue 1LE NAV PDR. PPF entire car |
Sell Low, Buy High
Drives: 2022 ZLE, 2023 ZLE (Inbound) Join Date: Feb 2019
Depends on what your street/track balance is. I elected to set -2.7 up front and deal with the extra inner shoulder wear on the tires for street because I only put a few thousand street miles/year on the car. Running lower camber on the track will wreck your track tires much faster. Replacing street tires once every year or two at worst vs. getting 1 track day on a set of fronts vs. 2 or 3, the economics worked out in favor of running track camber all the time for me.
#4 | |
![]() Drives: 2018 ZL1 1LE, 2015 X3 x35i M-Sport Join Date: Nov 2008
Sell Low, Buy High
My wear was pretty even from ~7-8 sessions at High Plains Raceway on Friday, but even still I could probably go to 3. Was at -1.5 in the rear and they were really even.
#6 | |
I actually like having this camber on the street too but I'm a bit of a goofball
#7 | |
![]() Drives: 19' ZL1 1LE Join Date: Nov 2015
#8 |
![]() Drives: 18 ZL1 1LE Join Date: Apr 2013
Correct me if I am wrong, but I thought this was one of the advantages of the front suspension setup on the ZLE is that you can rotate the front suspension assembly so that you can get your more negative camber for the track then simply flip it back when you want your street alignment again?
#9 | |
![]() Drives: '19 ZL1 1LE Join Date: Feb 2019
#10 |
Exactly... Way too much change to just flip them.
#11 |
wnyzl11le - hmm. so -1.8 vs 1.0 front and back, Did you set the plates to "track"?
Im running 2500 miles per year with 3-4 track days. Im on R888 tires if that makes any difference. |
#12 |
![]() Drives: Zl1 1le Join Date: Apr 2018
With such low milage and so few track days, you are fine with your compromise setting. However, if you start to do more track days or really want to get the best from the car at the track go to the track setting. The performance/handling is significantly better with the track setting.
#13 |
No that is street settings for the front and rear.
