Old 06-12-2019, 06:17 PM   #1
parish8
Drives: 17 SS a8
is it friday yet? going to the track to crank it up.
i am going to a private track rental on Friday, 1/8th mile. something like 15 of us. last trip to the track the car ran 5.94 at 18psi with a 1.44 60'
since then I got set up with a drag alignment for the rear, got some et street pro tires and put on a pair of drag shocks. I am also pulling about 120lbs of easy weight. I am hoping to get a 1.35 60' or better and if that goes well turn it up to as high as 25psi. 7 extra psi is around 200hp.
lots could go wrong but if things come together it could be a pretty good run. why isn't it Friday yet?
Old 06-12-2019, 08:17 PM   #2
DapperDan
DapperDan's Avatar
Drives: 2017 1SS A8 Nightfall Gray
Good luck man! Get ready for lift off in that rocket ship. How about some info on the drag shocks Thanks
DapperDan is offline   Reply With Quote
Old 06-12-2019, 08:37 PM   #3
parish8
Drives: 17 SS a8
Viking crusader double adjustable. Don’t know much about them other than other people seem to like them.
Old 06-12-2019, 10:06 PM   #4
laynlo15
Drives: 2022 Lt1 A10
Are you going back to Topeka? I'm pretty sure you'll break the FI 1/8 and 1/4 mile record if you hook and book with no issues. Good luck
Old 06-13-2019, 06:11 AM   #5
Jhunsberger
Jhunsberger's Avatar
Drives: 2017 Camaro 1SS M6 (SOLD)
Good luck Parish8, let her eat! Cant wait to see the results, be safe man!
Stock: 416hp/427tq, 12.21 @ 116.80
Modified 02/2019: Whipple SC w/ 3.500 pulley, LT4 fueling, NW 103 TB, Roto-Fab Big Gulp, Kooks 2" jet coated, full Borla ATAK exhaust, DSS axles, Gforce driveshaft.
Tuned by EFX Tuning 688hp/632tq
Best 1/4 to date: 10.705 @ 131.92
Jhunsberger is offline   Reply With Quote
Old 06-14-2019, 06:34 AM   #6
laynlo15
Alright Parish, turn the beast loose today. It should be crazy fast so hold on tight.
Old 06-14-2019, 04:02 PM   #7
parish8
Drives: 17 SS a8
Fail. Best run was a 6.29@119 with a 1.60 60’. I was just starting to get it to hook and the alternator took a shit or something charging related. The that was at 16psi.
Old 06-14-2019, 05:30 PM   #8
laynlo15
That sucks, too much electronics.
Old 06-15-2019, 08:33 AM   #9
hitmix300
2016 loaded 2SS
hitmix300's Avatar
Drives: Maverick X3 Turbo R
always something with these latemodel hotrods. could always b worse tho you know that..
I am hoping to see some 9.7's out of my car on the 17" wheel. here is a slip from two weeks ago. I didn't have any time to check the tire pressure or even brake boost, just left off idle. i cannot wait for some free time to spend the day at the track and figure this car out and what works, etc. fortunately the track seemed to hold 20psi tho
these turbo cars trap hard!
hitmix300 is offline   Reply With Quote
Old 06-15-2019, 10:06 AM   #10
parish8
Drives: 17 SS a8
Yeah the mph is nice. I wonder where my car will end up when I am able to crank the boost to 25psi if 16psi gets me 120mph in the 1/8th.
Old 06-15-2019, 12:59 PM   #11
hitmix300
2016 loaded 2SS
hitmix300's Avatar
Hopefully your head gaskets will approve of that decision making.
knock on wood
