Old 05-30-2019, 08:42 PM   #1
Michigan1LTRS
Blessed ❤️
Michigan1LTRS's Avatar
Drives: 2017 1LT RS I4
CTV4 320hp 396 tq Will Camaro get it?
Yes, yes I do believe it's the next Camaro powerplant. Pure speculation on my part. Oh, hi guys!!
Old 05-30-2019, 08:45 PM   #2
Michigan1LTRS
Blessed ❤️
Oh, it's a 2.7L turbo 4 by the way.
Old 05-31-2019, 12:52 AM   #3
Evil-Bee-NH
603 Camaros
Evil-Bee-NH's Avatar
Drives: 2017 NGM I4 1LT Coupe
Eh we all thought the TT LF3 would be the next powerplant to grace the camaro as well.
Old 05-31-2019, 09:34 AM   #4
zts1986
Drives: 2019 Chevrolet Camaro 1LT 2.0T
Uh...yes, please.
zts1986 is offline   Reply With Quote
Old 05-31-2019, 09:36 AM   #5
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
So 4 banger from silverado is trickling down.
ing for grip.
http://www.motorsportsne.com/
Old 05-31-2019, 03:13 PM   #6
Michigan1LTRS
Blessed ❤️
Old 06-02-2019, 01:52 AM   #7
protovack
Drives: 2019 2LT 2.0T M6 Riverside Blue
I knew it would happen eventually. And it is very likely to end up in the camaro.
A lot of people are mad the V models aren't going to be hyper-powerful anymore, but it makes sense to me. This really is the perfect engine for the cadillac sedans and also the next gen camaro. I feel very strongly that this engine is going to throw down some insane numbers. Obviously it will be much more powerful than the 6th gen 2.0T and V6. So that leaves the question, how will they play it?
IMO, they should just make it an optional engine on all trim levels, but they probably won't. I can see them making it optional on like 2LT and above trims, maybe a $2000 option. But will they drop one of the other engines? Which would it be and why?
protovack is offline   Reply With Quote
Old 06-03-2019, 12:07 AM   #8
cooper1965
Coopers Camaro
cooper1965's Avatar
Drives: 18 Flex Fuel LTG
Doubt this will happen. Its already lame shifting the LTG at 5400rpms for peak power in some gears. The 2.7 would be like 4600 rpms.. They would have to do cams min...Requiring a lot of extra costs to research and mass produce. The 10 speed would help, but IDK.
Flex Fuel tuned by me using HPT-:-
---My Build Thread---
-----My IG PAGe-----
Old 06-03-2019, 12:26 AM   #9
Evil-Bee-NH
603 Camaros
I second your sentiments on this. But GM is clearly phasing the 8 Speed out for the 10 Speed after they failed to just fix what we already know is the issue. Me and you fought the uninformed keyboard warriors on that issue in the Ask Al section to no avail... I wonder what the real play will be going forward. GM is fractured but as a company looking stronger each day while Ford has made some serious missteps and is paying for it this only serves to embolden more bad decision making from GM.
Old 06-04-2019, 10:45 PM   #10
b0bsaget007
b0bsaget007's Avatar
Drives: 2016 2LT RS Blue Velvet
I'm honestly not sure if the next generation Camaro will get the L3B engine. The LSY, which is the successor to the LTG, is more focused on fuel economy than performance, and thus has a reduced output (~240 bhp, as opposed to 275 for the LTG). At the same time, the L3B makes almost as much power as the LGX or even the new 3.0 TT V6 going in the CT5, but doesn't sound like either engine because it's a 4-cylinder and not a 6, and some customers are gonna want at least a 6 cylinder in their base model Camaro. It's hard to say anything now, since we are quite a ways away from a new generation of Camaro, and who knows what powertrains GM will have available by then.
PC: i5-6600; RX 480 4GB; 16GB DDR4; Samsung 950 PRO 512GB SSD
Car: 2016 Camaro 2LT RS 2.0T 6M Blue Velvet Metallic | ZZP Hi-Flow Catted Downpipe | Injen EVO7300 Cold Air Intake
b0bsaget007 is offline   Reply With Quote
Old 06-20-2019, 04:01 AM   #11
protovack
It's true, there are going to be some that will be outraged if the V6 goes away. And rightly so, it's a great powertrain.
Look at what happened with the 718 Cayman when it dropped to a turbo 4 from a flat six. People just about lost it completely.
What about this. What if instead of a 4/6/8 cylinder lineup, we get the L3B for a base engine and the 4.2L blackwing V8 as the uplevel engine?
Old 06-22-2019, 03:51 AM   #12
Waleedriazz
Drives: 2018 1LT Camaro 2.0 I-4
Nahh. The blackwing will be exclusive to Cadillac only (Source: GMAuth).
And I know it hurts to know that the peak power will be at 4000RPM, but this is most likely what's gonna happen. Let's be real, the LT1 is at 4400, so 4000 isn't AS bad as it sounds.
I think the 6-cyl is out of the window after this one. Not to forget that there's a 1LT V8 coming in for the sound/vibration enthusiasts.
Waleedriazz is offline   Reply With Quote
