Old 04-09-2019, 11:26 AM   #1
VinnAY
Drives: 18 1SS/1LE
1LE: do you run the Powerstop Z26 pads?
I'm considering the change from OE pads and I don't need that much bite on the street but less dust would be really great but specific question: the Z26 is how they perform in the rain? Times I've been on my A/S tires in the rain the pedal almost goes to the floor and I'm looking for better performance in that way. Too the OE pads freeze to the rotors if I even spit next to them (j/K) but they do freeze up very easy.
I didn't have this with my Mustang GT/PP w Brembos which probably had a less aggressive pad material, so I'm thinking a less aggressive pad would make the dust and rain/wet performance more liveable.
Old 04-09-2019, 11:33 AM   #2
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
Only on the street. It's not a track pad in any way.
Z26's when wet have a strange inconsistently grabby feel. They also stick to the rotors overnight when wet and do it significantly more than the stock Ferodo pads. Their main advantage is the low dusting, but in most measurable metrics they're *slightly* worse overall, which can't be a surprise at their price point. ***Edit*** *slightly*. If the stock Ferodo's are overall A+, Z26 are overall an A-, so the overall change is subtle.
FYI, a brake pedal doesn't "go to the floor" because of the pads. You likely induced ABS + have air in the ABS module. It sounds like you need a fluid flush regardless of what you do with pads.
Old 04-09-2019, 11:52 AM   #3
camaroJD
Drives: 2019 Satin Steel 1SS 1LE w/ PDR
Z26's when wet have a strange inconsistently grabby feel. They also stick to the rotors overnight when wet and do it significantly more than the stock Ferodo pads. Their main advantage is the low dusting, but in most measurable metrics they're worse overall, which can't be a surprise at their price point.
Very interesting, how bad is this in the rain? Would you call it dangerous for daily driving in rain?
camaroJD is offline   Reply With Quote
Old 04-09-2019, 11:55 AM   #4
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
Woah woah. You took my words way too far. We're talking about going from an "A+" pad [stock] to an "A-" pad [Z26]. At no point would I ever use the words "dangerous" with the Z26's.
I ran Z26's on the street with my SS 1LE brakes, and I still run Z26's on the street with my ZL1 brakes. The lack of dust far outweighs the slightly fidgety wet behavior, and when I say that it means they're still better than most other marques OE pads. That right there should tell you they're perfectly fine as a street pad.
Old 04-09-2019, 11:59 AM   #5
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
i run them on my ss but yes agreed would not run them on the track i have a set of brand new powerstop track day ready to get installed
Old 04-09-2019, 12:32 PM   #6
RazzleDazzle
Drives: 2019 Camaro Zl1 A10 w/ Nav & PDR
So - I called Powerstop to order a set of Z26's for my 1LE and they said they only fit "SS"??? HUH ???? Are they the same size (1LE and standard SS Brembo) pads?
RazzleDazzle is offline   Reply With Quote
Old 04-09-2019, 12:56 PM   #7
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
I have a complete set of the Z26 pads sitting on the shelf right now to reduce the insane dust output of the stock pads.
Haven't installed yet as I'm trying to find a countersunk punch to knock out the pins, because I know I'll smurf up the calipers if I try knocking those pins out with a regular punch.
So for now I'm dealing with the dust over chipped up calipers.
'18 1SS 1LE Black, PDR
Old 04-09-2019, 12:56 PM   #8
MP3BOOSTED
MP3BOOSTED's Avatar
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C)
1LE and SS are not the same size in brakes.. at least the fronts to my knowledge, someone will chime in with accurate info here in a sec.
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw
MP3BOOSTED is offline   Reply With Quote
Old 04-09-2019, 12:57 PM   #9
VinnAY
Drives: 18 1SS/1LE
There's no track duty here so that's not a factor for me. But with the OE pads in the rain, it's a pump, pump, pump the brakes because of the water that is on the rotors and pads, it's not a fluid problem. No issue at all when dry. Pumping the brakes when wet isn't something abnormal per se but this OE pad is dangerous when wet. It's something I haven't gotten with previous Brembo brake packages which I'm certain didn't have such an aggressive pad.
Old 04-09-2019, 01:03 PM   #10
mikem2104
mikem2104's Avatar
Drives: 18 2SS 1LE, 20 Canyon Denali
Front: Z26-1405
Rear: Z26-1718
no doubt they fit the 1le. i have them on mine, never experienced any issues in street duty that would make me question their quality.
Mike
Current Garage:
18' 2SS 1LE, Hyper Blue
23' GMC Canyon Denali
Previously:
20' GMC Canyon Denali
16' 2SS 6MT, Hyper Blue, Kalahari, 20" PVW Chrome Split wheels, NPP, MRC (Total Loss)
14' Ford Edge Sport
06' Saab 9-7x,13' Nissan 370z Sport, 12' VW Jetta GLI, 02' Olds Bravada
mikem2104 is offline   Reply With Quote
Old 04-09-2019, 01:12 PM   #11
camaroJD
I guess I jumped the gun, I'm just making sure because I'm about to replace my stock pads and poor wet performance is something that scares me. Thanks for elaborating on that.
Old 04-09-2019, 01:19 PM   #12
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
Note that I never said "poor performance". There is absolutely no problem with their mu or compressibility. When the pads are wet they may give a slightly grabby initial bite. It's not abrupt, unsafe, poor, or anything more than slight.
I doubt most enthusiasts would even notice.
Old 04-09-2019, 05:30 PM   #13
TJay74
I've had the Powerstop Z26 pads on my 1LE for almost 20k miles now, not one issue with them at all other than some very minor fade when pushed really hard.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD
Old 04-09-2019, 09:29 PM   #14
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
I bought Z26 pads for my 1LE and will never use them because it's a track car now. Anyone wants to make me a fair offer, send me a PM
