Old 04-05-2019, 11:24 PM   #1
newchevyman
Drives: 2017 Camero ZL1
Product Review: BMR Lockout Kit
Installed BMR lockout kit on my ZL1 today. Very straightforward install takes maybe 1.5 hours. Even minimal mechanical skill it won't take long. Instructions are helpful and easy. No pictures of them installed not really anything to see.
I have Nitto 555 G2s in stock sizes and before they would do side to side bs under hard acceleration. That's all been removed. They spin from a low roll but car stays completely straight. From highway speeds it just hooks and goes. The rear definitely feels more planted around turns as well but Texas is flat and haven't hit any twisties yet. Will be doing a road course on Sunday and update accordingly.
I also have a drag pack, car cuts 1.6 60s like clockwork and it's definitely given the feeling that the launch will improve. Will test that butt dyno in a couple weeks and update accordingly. Product is 100% worth it. Only regret is not doing this sooner.
Link to product
http://m.bmrsuspension.com/?page=pro...productid=1635
2017 ZL1 A10
Dyno/Quarter Mile/Dragy
9.71@141.2 MPH so far.
2007 Z06 H/C/I/E Half Mile - 169 MPH. Sold.
newchevyman is offline   Reply With Quote
Old 04-05-2019, 11:35 PM   #2
Subcool
Drives: 2022 SS 1LE
I put this kit on my 17 1 le, and ended up selling it but the kit worked so well I just bought it again for my zl1. Haven’t had my z out of storage yet but I have already installed kit. Glad to hear it helped, can’t wait try mine.
Subcool is offline   Reply With Quote
Old 04-05-2019, 11:40 PM   #3
TRZ06
TRZ06's Avatar
Drives: 22' Porsche PDK GT4
Amazing how these cars handle with that one upgrade. I went the ZL1 1LE solid cradle bushing kit, but either way you go, the difference is pretty substantial to really tame that rear-end.
It is the only weak point in the ZL1 / SS 1LE suspension.
Current:
Previous:
09' C6 Z06
08' E90 M3
06' 335i (KW V2 Coilovers)
03' C5 Z06
Old 04-06-2019, 08:16 AM   #4
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
amazing difference with the lockout kit...simple install compared to the solid bushings. Either way, you can't go wrong.
Old 04-06-2019, 10:58 AM   #5
Rodan
Drives: 2018 ZL1 coupe
Installation looks pretty simple from the instructions...
No need for alignment after install?
No goofy torque to yield bolts involved?
Rodan is offline   Reply With Quote
Old 04-06-2019, 11:20 AM   #6
newchevyman
It's as simple as it appears. No TTY bolts. I can't answer for certain on the alignment. Maybe someone else can chime in? Even if it does need one my opinion doesn't change about it being worthwhile. You'll be pleasantly surprised what a difference it makes.
2017 ZL1 A10
Old 04-06-2019, 11:43 AM   #7
Stephen12ZL1
Drives: '21 ZLE A10
No TTY bolts, alignment isn't absolutely necessary. I suppose someone here could argue (I'm sure they will ) an alignment would be the "perfect" way. The way this lockout kit installs it didn't seem possible anything could move. No camber bolts are removed and/or loosened. I suppose you could get really sloppy and have the cradle in a bind when retorquing the cradle bushings and botch the alignment.
Old 04-06-2019, 11:45 AM   #8
Rodan
Thanks!
Gonna add this one to the list. I was planning on the ZLE bushings, but this looks a lot easier.
Old 04-06-2019, 12:38 PM   #9
kwav8r
Flyin NOE
Drives: 2018 ZL1 (A10)
Production description reads: "Once installed, the Cradle Bushing Lockout Kit minimized bushing and cradle deflection with nearly no change in NVH."
Am curious to hear what others have noticed in a straight ZL1after install.
I am really not happy with the side to side (for me, ass end wants wants to slide left) on hard accel.
Old 04-06-2019, 12:48 PM   #10
sv340
sv340's Avatar
Drives: 2015 ZL1
AKA: Mustang Effect
sv340 is offline   Reply With Quote
Old 04-06-2019, 01:04 PM   #11
Android42019
The Black Emerald
Android42019's Avatar
Drives: '17 ZL1, '08 Trailblazer, '11 1LTRS
I used to take off straight but over time it now kicks to the right, hopefully this will change that! Thanks for sharing!
Android42019 is offline   Reply With Quote
Old 04-06-2019, 01:30 PM   #12
newchevyman
As mentioned in the original post it will remove the side to side movement. I didn't mention NVH but I couldn't tell any change. It did not add any NVH.
2017 ZL1 A10
Old 04-06-2019, 02:58 PM   #13
TRZ06
TRZ06's Avatar
No added NVH here with the ZL1 1LE solid cradle bushings. I would imagine the same would be true with the lock-out kit.
Current:
Previous:
09' C6 Z06
08' E90 M3
03' C5 Z06
Old 04-06-2019, 03:10 PM   #14
Rodan
Just ordered one up. Looked like most places had the same delivery time, so just I grabbed it off Amazon.
Should be here in plenty of time to install it before our next track day.
