Old 04-01-2019, 10:10 AM   #1
RobbyBeefcake87
RobbyBeefcake87's Avatar
Drives: 2018 Camaro SS 1LE
Tire damage
I just found a nail in back tire, might have been there a while as it's a very slow leak. It's in the grove between treads so I couldn't really feel or hear it untill I visually inspected my tires today due to slightly lower tire pressure than the other tires.
I plan to go just get it patched later, but sometimes I read something enlightening on this forum. Any reason someone wouldn't do this and would just get a(2) new tire(s) instead?
2000 Miata - aventi storm wheels, roll bar.
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler.
2018 Colorado zr2 - zr2 sport bar, showcase spare tire.
2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace.
2017 Corvette Grandsport (sold) - untouched.
2006 GTO (sold) - iat relocation, air box mod, monero side marker lights.
RobbyBeefcake87 is offline   Reply With Quote
Old 04-01-2019, 10:31 AM   #2
ctrlz
very limited residual tread life is only thing that would push me away from repairing the tire.
You will probably get comments about only patching the tire in the "safe repair zone," but you don't sound like the type that would do otherwise.
Personally, I still plug tires with this type of damage (nail puncture), and I know that is viewed very unfavorably in some circles.
Old 04-01-2019, 10:37 AM   #3
AmazinglySmooth
Why did they ever stop using tubes in car tires?
AmazinglySmooth is offline   Reply With Quote
Old 04-01-2019, 10:39 AM   #4
Rayvan
Rayvan
Drives: 2018 1SS1LE, Silver Ice Metallic
I'd patch it, but I would not race the car, and you should avoid high speeds until it's replaced.
Rayvan is offline   Reply With Quote
Old 04-01-2019, 10:58 AM   #5
ctrlz
Fewer parts, less weight, ability to repair tire without removing it from wheel...
Old 04-01-2019, 11:00 AM   #6
DIYguy
DIYguy's Avatar
Drives: 2017 Camaro 1LT
Smile Old School
I greatly prefer to patch punctures.
The process of plugging them tends to cause more damage to the tire cords.
Just my opinion.
And of course you really should not patch or plug a tire with a puncture larger than about 1/8" or thereabouts (opinions vary).
I recently had a puncture and slow leak similar to the one the OP described.
I patched it using a radial tire patch and the result was excellent.
My tires have lots of tread left and I do not race my car, so replacing the tire was not necessary.
They stopped using tubes in radial tires mainly due to their greater sidewall flexure.
The tube can abrade against the insides of the tire and also can lower heat dissipation.
However, this is only true when non-radial style tubes are used in radial tires.
There are special radial tire style tubes which are OK to use.
And of course TPMS sensors and inner tubes do not play well (you can have one or the other but not both).
I have never seen tubes that can work with TPMS.
Gen6 Camaro LT (my daily driver), Cruze ECO (grocery getter), Chevy SS Pickup (wife's daily driver), Honda Shadow, Honda CBX
DIYguy is offline   Reply With Quote
Old 04-01-2019, 12:12 PM   #7
mcintyre1969
mcintyre1969's Avatar
Drives: 1968 SS/RS, 2006 H2 2016 2SS White
Sounds like you have good tread, just get it patched beefcake
2016 2SS White fully loaded
mcintyre1969 is offline   Reply With Quote
Old 04-01-2019, 12:16 PM   #8
karmatourer
STD free
karmatourer's Avatar
Drives: 2018 Bright Yellow LGX M6 RS NPP
Run-flat technology.
karmatourer is offline   Reply With Quote
Old 04-01-2019, 12:25 PM   #9
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Tire must be removed from wheel and patched from inside.
Old 04-01-2019, 12:26 PM   #10
RobbyBeefcake87
Tire
Yea I wouldn't try to patch a questionable or no go spot just to save a few bucks.
I'll go ahead and patch it since the tire still has plenty of life left and just refrain from any high speed shenanigans until I replace them (which depending on how long the nail's been there I've probably inadvertently done already lol).
The 305's look mean but I fear the day I need to replace all 4 tires! lol
Old 04-01-2019, 12:27 PM   #11
RobbyBeefcake87
Tire
Will do!
Old 04-01-2019, 01:29 PM   #12
VinnAY
Drives: 18 1SS/1LE
A proper patch on the inside cost me $16 last time on a Z rated tire...it's very affordable to the point that you shouldn't even need to consider a plug repair. But repairs can be fickle, some they will and some don't meet their envelope of repairable.
Old 04-01-2019, 02:43 PM   #13
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
A tire shop can advise you Robby if it can be patched. If it can’t then they won’t do it. I had a couple of tires in the past that couldn’t and I was told they wouldn’t even try after checking the tire. Something about a liability issue for the tire store.
Old 04-01-2019, 09:53 PM   #14
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
high speed where a plug would be a problem isn't anywhere in the range you can reach on most highways (low triple digits).
centripetal force isn't going to remove it and rolling friction isn't going to budge it. Slamming on your brakes right on the spot where it is might do something, but if you're doing that, you're already in trouble and a tire losing pressure is only going to be an additional headache.
I'd think most people who are tracking their car dont track it using their daily driving tires....that's just a fast way to waste rubber. Plugs should be totally fine between 0-100...
