Old 03-10-2019, 05:13 PM   #1
njweatherman
Drives: 2018 Camaro 2SS, redline edition
AFM Valves Closing and Exhaust Flow
Does anyone have a picture of what the actual AFM exhaust valves look like?
My question is when the car goes into V4 mode and the AFM valves close, how does the exhaust exit the car?
njweatherman is offline   Reply With Quote
Old 03-10-2019, 05:36 PM   #2
hitmix300
2016 loaded 2SS
hitmix300's Avatar
Drives: Maverick X3 Turbo R
edited to correct info
hitmix300 is offline   Reply With Quote
Old 03-10-2019, 05:37 PM   #3
njweatherman
Thank you!
Old 03-10-2019, 06:18 PM   #4
cmitchell17
Drives: 17 2SS, 8L90, Cam, Heads, E85
Unfortunately I don't have a picture of the inside, although I believe it is the same part as the rear NPP valve. Although the actual butterfly valve on the AFM valve may be different, I would imagine it may have perforations in it or maybe a slight hole, as I don't think they would design it to completely block off flow. I know they do a good job of silencing the exhaust. The problem is they don't transition good enough so when the open and close when AFM activates and deactivates you definitely notice it.
cmitchell17 is offline   Reply With Quote
Old 03-10-2019, 11:13 PM   #5
Richkidd87
Richkidd87's Avatar
Drives: 2016 Camaro 1SS Red Hot
They close fully. The valves have holes in them so the exhaust can pass through once they’re closed.
Richkidd87 is offline   Reply With Quote
Old 03-11-2019, 07:18 AM   #6
njweatherman
Thanks everyone for the replies.
Old 03-11-2019, 09:13 AM   #7
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
Think of a bolt washer, it has a hole in the middle. When V4 mode kicks in it closes so the sound waves are reflected back but exhaust gases exit.
Old 03-11-2019, 03:08 PM   #8
Spartan268
Spartan268's Avatar
Drives: HB 2SS
Check out this post: https://www.camaro6.com/forums/showthread.php?t=507367
Little further into the thread has the picture you're looking for. The valves close fully but there's a hole in the plate where it breathes.
Spartan268 is offline   Reply With Quote
Old 03-11-2019, 06:01 PM   #9
cmitchell17
You can use a scan tool and force the AFM valves closed, then you will see how much of a restriction they do make, the car will barely shift at WOT, and it screws up the torque model and makes the shifts off.
