Old 02-13-2019, 02:48 PM   #1
rich6111
rich6111's Avatar
Drives: 2018 2SS Mosaic Black Metalic
afm disabler
has anybody used the range afm on camaro?
rich6111 is offline   Reply With Quote
Old 02-13-2019, 03:02 PM   #2
Driski
Drives: 2016 Camaro Convertible 2SS
I have. I ordered the latest version and it worked flawlessly. No CELs and no Battery Drain. It was by far the best bang for the buck to present. It totally eliminated the exhaust fart when changing from 4-8 cylinder and back again as well as the lag associated with it. I also have the switch that goes with it but never used it. Just left the unit plugged in.
https://rangetechnology.com/afm-disabler/
I currently have my car at a speed shop for header install and a tune. The AFM will be disabled and i will no longer require the Range device. When you are done with your research, and if you would like to purchase it for a drastically reduced price just PM me.
Good luck
2SS Convertible, MRC, NPP, A8, Garnet Red, Blk Bowties
GM CAI, Ported TB, Kooks Headers, E85
Driski is offline   Reply With Quote
Old 02-13-2019, 03:03 PM   #3
RyanR623
Drives: SS A8, NPP, Red Hot
Originally Posted by Driski View Post
I have. I ordered the latest version and it worked flawlessly. No CELs and no Battery Drain. It totally eliminated the exhaust fart when changing from 4-8 cylinder and back again as well as the lag associated with it. I also have the switch that goes with it but never used it. Just left the unit plugged in.
I currently have my car at a speed shop for header install and a tune. The AFM will be disabled and i will no longer require the Range device. When you are done with your research and if you would like to purchase it for a drastically reduced price just PM me.
Good luck
Drastically eh?
RyanR623 is offline   Reply With Quote
Old 02-13-2019, 03:07 PM   #4
Driski
Originally Posted by RyanR623 View Post
Drastically eh?
I have no need for it...
Old 02-13-2019, 03:19 PM   #5
Chutzpah
Chutzpah's Avatar
Drives: Wild Cherry LT1
Yes, the latest version works quite well.
Last edited by Chutzpah; 02-13-2019 at 03:21 PM. Reason: Saw someone else was trying to sell...
Old 02-13-2019, 03:22 PM   #6
RyanR623
Did it get rid of the shudder?
Old 02-13-2019, 03:27 PM   #7
Soleil
Soleil's Avatar
The range has nothing to do with the shudder.
Soleil
Old 02-13-2019, 04:52 PM   #8
RyanR623
I've heard that the range module gets rid of the shudder for a lot of people. Im the furthest thing from an engineer, and it appears not even GM engineers can figure it out... but I do know it only happens in V4 mode for me. Might be a coincidence because i'm also at a lower rpm in v4 mode. But that's why I asked the question. Curiosity.
Old 02-13-2019, 05:58 PM   #9
Chutzpah
Chutzpah's Avatar
Did nothing for my shuddder (was minor on highway). The first time I felt it was while using the Range device.
Old 02-13-2019, 06:04 PM   #10
Driski
Correct! Nothing to do with the shudder. Eliminated the exhaust fart (just as annoying as the shudder) and the lag from 4 - 8 cylinder. More fun to drive.
Old 02-13-2019, 11:56 PM   #11
Marco Falcone
Marco Falcone's Avatar
Drives: 2018 2SS Convertible MBM/Kal
I’ve had a Range AFM disabler (Ver. 8.6) in my car pretty much since new. I put it in right after hitting 500 miles.
Car now has 8100 miles in it. No issues at all. No shudders, no CELS.
Car has sat for 3-4 days a few times with the Range installed. No battery issues.
Car has also been to the dealer 3 times, for 2 oil changes and the TSB for the rear differential groan. Pulled the Range before I drove in each time. Put it back when the service was done. Again, no issues at all.
Highly recommended.
2018 2SS Vert. MBM/Kalahari. MRR FS01’s with 285/305 MPS4S. Black Bow ties, A8, MRC, NPP, 6-piston Brembo’s w/ matching rears, OEM Ground Effects/Splash Guards, 8”/Nav. Borla S-type, Pray IM/TB, RotoFab.
Past DD’s of note:
2013 Caprice PPV. (“Company” car.)
1998 Cadillac STS
1996 Impala SS
1969 Cadillac DeVille Convertible
1993 Corvette
1991 Mustang 5.0 LX
1973 Alfa Romeo Spider
1986 Mustang GT T-top
1964 Falcon Sprint Hardtop. (First car, still have the key!)
Marco Falcone is offline   Reply With Quote
Old 02-14-2019, 05:03 AM   #12
crosive
Drives: 18 zl1
I'm using the diablosport unit. It's been plugged in for the past few months with no issues. I've gone maybe a little over a week between cranks and no abnormal battery drainage that I've seen.
crosive is offline   Reply With Quote
Old 02-14-2019, 06:19 AM   #13
Driski
Highly recommended.
Similar results with mine (no cel, no battery drain)... just can't confirm results regarding shudder. I will say my shudder did not reveal its self until around 20 K miles. Still have my Range Device for sale. PM me if interested
Old 02-14-2019, 07:05 AM   #14
mdhopt36
Drives: '17- 1ag37 V6 traded, for 1SS 2018!
In V4 mode, at low revs, I note a very slight throb from the engine, but wouldn't call it a serious shudder.
My question, can the car sit a couple weeks with this plugged in and not drain the battery?
mdhopt36 is offline   Reply With Quote
