Old 02-10-2019, 01:12 AM   #1
Raiden
Drives: A Box
Can't see the Heads-Up Display if seated too high up??
So I prefer to be seated somewhat higher up in the driver's seat, but to be clear my head is still maybe 1-2 inches from touching the roof still. Yet at this height the top half of the HUD is already blocked, I adjust the position of the HUD as low as I can and its still half blocked. Is this the same for everyone or is my HUD just messed up? I'm not actually tall so I can go lower (though I really don't want to compromise like that), but I'd have to imagine tall people know what I mean if this is a common problem???
Raiden is offline   Reply With Quote
Old 02-10-2019, 01:21 AM   #2
DeadSpider
Drives: 2019 Camaro SS 1LE
I have an inch or less of headroom and I see mine fine after adjusting it. My seat is back almost all the way. Perhaps the seat distance plus eye height matters.
DeadSpider is offline   Reply With Quote
Old 02-10-2019, 01:25 AM   #3
JamesNoBrakes
JamesNoBrakes's Avatar
Drives: 2SS 1LE
Can't stand how everyone always jacks the seats up as far as they'll go in our fleet vehicles at work. If there's one constant, it's that the seat is always jacked up as high as it can go, steering wheel is tilted up as far as it'll go, and mirrors are adjusted to be redundant with the rear view mirror. Every. Single. Time.
/rant
Have you tried tilting the seat back more?
2018 2SS 1LE
2023 Colorado ZR2
2022 Stinger GT-line AWD
JamesNoBrakes is offline   Reply With Quote
Old 02-10-2019, 07:37 AM   #4
Memphis SS
Memphis SS's Avatar
Drives: 2017 SS A8 Hyper Blue/White Stripes
Without being in your car and knowing what your setting angle is no here going to know for sure.
Easiest thing to do and quickest is to just go by a dealership and get into another Camaro with heads up and put the seat in the same position and compare. If yours is defective you can show the service writer and get yours repaired
2017 Camaro 2SS Hyper Blue
2011 Camaro 2SS 2004 Corvette CE SOLD
Memphis SS is offline   Reply With Quote
Old 02-11-2019, 11:14 AM   #5
majik755
majik755's Avatar
Drives: 2017 Camaro RS Fiftieth Anniversary
I agree, check out another at the dealership. I'm tall and have very little headroom and have no problem adjusting the HUD to see it. Sounds like you may have an issue.
majik755 is offline   Reply With Quote
Old 02-15-2020, 06:33 AM   #6
IkaSGC
Drives: Chevrolet Camaro 2018 SS
I also have problems with HUD. He was too high since the production. Height adjustment ranged around +/- 3mm. So practically useless. Now after hibernation, the HUD retreated into the silicon sky. I wondered why the HUD is so high, whether I grew up or why ?? I saw him before, even though it was on the edge. So I played with the height adjustment for a while. Finally, my HUD display went up somewhere and I can't adjust. Again it moves only about 3mm. But to see him, I have to look completely from the seat through the hole in the steering wheel. I will have to service it, as the car is under warranty.
IkaSGC is offline   Reply With Quote
Old 02-15-2020, 10:01 AM   #7
KirkH
I took mine in to the dealership and had the lens adjusted.
Old 02-15-2020, 10:04 AM   #8
Mov Ov3r
What speed limit?
Mov Ov3r's Avatar
Drives: 2017 SS 1LE
This... This is the most annoying thing I find about people.
Mov Ov3r is offline   Reply With Quote
