Old 02-03-2019, 08:17 PM   #1
juggsauce
Drives: 17 2SS, 08 Tundra
Door rub marks
Anyone else have an issue of the plastic body panel wearing the paint off the door? Pictures do the talking better than I can
juggsauce is offline   Reply With Quote
Old 02-03-2019, 08:26 PM   #2
internationlriders
internationlriders's Avatar
Drives: 2017 SS 1LE
There's a spot where the doors close and where the trunk closes on mine that shows paint rubbing away. It's not Japanese, German, or Italian so I expected imperfections from a $45k performance car, it's pretty lame to have to use excuses like this for faults that are easily removed with proper engineering. It also sucks being a perfectionist and also coming from a family of master craftsmen to see shoddy workmanship but it's a domestic car, not a European house, it's not build to last.
I'm just a car addict looking for a group of alcohol enthusiasts.
"The Lord is my shepherd; I shall not want."
internationlriders is offline   Reply With Quote
Old 02-03-2019, 08:32 PM   #3
juggsauce
I mean don't get me wrong, I think gm has come a long way. Compared to the 5th gens these things feel miles ahead on fit and finish. I just hope its still a decent daily driver by the time I pay it off.
Old 02-03-2019, 08:49 PM   #4
17rsvert
17rsvert's Avatar
Drives: 2017 HBM 2LT RS Convertible V6 A8
No problems with mine. Even the convertible top parts fit perfectly.
17rsvert is offline   Reply With Quote
Old 02-03-2019, 09:11 PM   #5
squish72
Drives: 2016 2SS 8AT
Mine has the same rub marks. Both sides. Luckily it's not into the paint like yours
squish72 is offline   Reply With Quote
Old 02-03-2019, 09:23 PM   #6
dpevans
Drives: 2024 Riverside Blue 2SS 1LE
don't see it on mine but I would think you could take a body hammer and tap it down a little to eliminate. i would do it on the door side then use some touch up paint.
dpevans is offline   Reply With Quote
Old 02-03-2019, 09:29 PM   #7
Need4Camaro
Drives: '17 Camaro 2SS & '99 Camaro Z28
What if it has more to do with the door hinge properly lining the door up?
Need4Camaro is offline   Reply With Quote
Old 02-03-2019, 09:33 PM   #8
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Pretty obvious that the door needs re-hanging/adjusting at the hinge.
Old 02-03-2019, 09:35 PM   #9
juggsauce
Problem is the rubbed part is the seam weld of the door. Any change in shape on one side will affect the other. Body side is plastic so that's a no-go as well. I'd say hinge alignment but the body lines are pretty well matched from the door to the body. I guess I'll get a touch up wand to prevent rust and slap some xpel on both sides as a sacrificial barrier.
Old 02-03-2019, 09:37 PM   #10
DC5
Drives: 2019 Chevrolet Camaro SS 1LE
My Camaro exhibits no such exterior fit or finish flaws.
DC5 is offline   Reply With Quote
Old 02-04-2019, 10:12 AM   #11
Quix
Quix's Avatar
Drives: 2016 2LT V6 Garnet Red
My car requires a lot of care with the trunk to make sure it doesn't bash into the quarter panel. The doors are ok. Your photos look pretty bad, that issue might be correctable.
Quix is offline   Reply With Quote
Old 02-04-2019, 11:00 AM   #12
camaroJD
Drives: 2019 Satin Steel 1SS 1LE w/ PDR
I thought this thread was going to be about marks on the door's plastic interior. No matter how careful I am, I seem to scuff up the panels.
camaroJD is offline   Reply With Quote
Old 02-04-2019, 11:51 AM   #13
keon718nyc
Also i have the drivers side similiar to the OP as well. Looks about the same on the inner part of the door jam. Not getting worse that i can tell but there now.
Old 02-04-2019, 01:36 PM   #14
Whitespeed
Drives: 2018 1SS 1LE & 1973 Datsun 240Z
As a teenager in the 80's, American cars of that era were the epitome of crappy engineering. Consequently, I never thought I'd own an American car and until my Camaro, I've owned nothing but Japanese cars. However, my 2008 Accord Coupe had all sorts of fit and finish problems. From new, both doors were well out of alignment, the glove box was out, there was an exhaust rattle, and water leaked through the rear glass into the trunk. After a few years, all the paint started pealing off around the rear window. I was looking at buying an E46 M3, but cracked frames, cooling systems that disintegrated in 60K miles and various other issues turned me off those. In the mean time, American car quality has improved dramatically and the delta is nowhere near what it once was to Japanese and European cars. I for one am really impressed with the engineering that has gone into the Camaro, so much so that it was the first car I've ever bought new.
All that said, I have the same issue with paint wearing in that area. I haven't spent any time yet trying to sort it out, so I'm curious to see if someone else figures out a way to correct it.
Nigel
Whitespeed is offline   Reply With Quote
