Old 02-01-2019, 09:42 PM   #1
ParisTNDude
Owning SSes for 50 Years
ParisTNDude's Avatar
Drives: Sharkskin Grey LT1
MY First Service at Chevy Dealership
Took the new to me HPB 1le in to get the dealership to install the tires I bought with 300 miles on them from a forum member. Had them check the brake pads and undercarriage including the suspension parts. Everything checked out perfect. While I was there, we did it's fourth engine oil service in under 10K miles. I had them do a 4 wheel alignment as well.
I stressed to the very knowledgeable technician that I wanted the standard alignment as opposed to the track mode alignment. He told me the 1le came from the factory with the track alignment! Just wondered if anyone knew if that was true.
I've heard that, if daily driven modestly, tire wear would be significantly improved with the street tune. The front wheels needed an equal adjustment on both to return it to the street tune. I don't know enough about it to say one way or another.
After the new tires and alignment, the car drove like a very different automobile. This 1le is without a doubt the best car I've ever owned, and that's saying something!
One other thing: I had them confirm that they would flash ECU or whatever computer involved after I install the GM Performance CAI I bought without charge (there's a note in the box that tells them to do it). Dwain Taylor in Murray, KY is an awesome dealership and their service department has never let me down...perfect record with me!
The new ride: 2023 Camaro, LT1, Sharkskin Grey
Previous Performance Cars:
1966 Chevelle SS 4M, 2010 Corvette 6M
1968 Dodge Charger R/T Auto 2012 1SS 6M
1982 Corvette Auto 2010 1SS 6A
1984 Corvette Auto 2016 2SS 8A
1999 Camaro Auto 2017 HBM 1SS 1le
2002 C5 Corvette 6M 2018 2SS
2006 Corvette Auto 2023 Camaro LT1
ParisTNDude is offline   Reply With Quote
Old 02-01-2019, 10:00 PM   #2
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
Track alignment from the factory...Ha! Put it on the machine and find out the real truth. Factory alignment is usually -1.1° camber front and -.5° rear and the toe can be anywhere.
Old 02-02-2019, 02:35 PM   #3
davef
Drives: 2017 SS 1LE Garnet Red
Agreed. That tech was dead wrong on the alignment. I've never heard that they come out of the factory with the track alignment. I know mine didn't.
davef is offline   Reply With Quote
Old 02-02-2019, 03:03 PM   #4
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
Either he just assumed, or worse, it's BS blown up his ass by GM's product training for Technicians.
'18 1SS 1LE Black, PDR
Old 02-03-2019, 08:14 PM   #5
ParisTNDude
I don't know enough about it to say what it is, was or should be. For now the car drives wonderfully well and a whole lot better than it did before the tires and alignment. And, I'm not sure what to attribute the improvement, tires, or alignment. I guess it doesn't matter, does it?
Old 02-03-2019, 09:39 PM   #6
samr350
samr350's Avatar
Drives: 2017 SS 1LE
Can you post a picture of the alignment specs before and after? The dealer should have given you a sheet with it.
samr350 is offline   Reply With Quote
Old 02-04-2019, 12:44 AM   #7
WhyUMad1LE
Drives: 17 SS 1LE
They come from the factory with no alignment. Toe is consistently off.
Old 02-04-2019, 07:30 AM   #8
WCKD 1LE
WCKD 1LE's Avatar
Drives: 2018 SS 1LE
My 18 came with the Track Alignment, I had it on the rack the same day as purchase.
WCKD 1LE is offline   Reply With Quote
Old 02-04-2019, 09:44 AM   #9
Apex_Missing_Ape
Drives: 2018 2SS 1LE
My 18 did not come with the track alignment. I took it to Barber Motorsports Park with the factory alignment and it performed great except for one turn where I got a lot of push. The next time I hit Barber I had my track alignment and it made such a huge difference on the track. My times were consistently nearly a second faster per lap. I'm not sure if that was credit all to the extra grip or partly because of the extra confidence it gave me to push it harder.
Apex_Missing_Ape is offline   Reply With Quote
Old 02-04-2019, 10:36 AM   #10
TrackClub
TrackClub's Avatar
With what specs if i may ask?
Mine came with a street alignment, as most of them.
It wasnt perfect, but wasnt too badly messed up.
I did the break in per the manual then track alignment change of fluids etc before my first track day.
Old 02-04-2019, 01:15 PM   #11
WCKD 1LE
WCKD 1LE's Avatar
Drives: 2018 SS 1LE
I've got the sheet at home, Ill upload for you.
Old 02-04-2019, 01:29 PM   #12
JonD
JonD's Avatar
Drives: 2018 SS 1LE
My 18 did as well... lost my sheet though
I need to call to see if I can get it again
🌽 Sauced, 2018 SS 1LE - 123mph @ 5,000 DA
ARH 2”x3” FULL System, Pray Ported MSD Intake Manifold, Pray Ported GM 95mm TB, RotoFab CAI, DsX e85 Kit, MightyMouse Catch Can, NicD Tune
https://instagram.com/corn_sauced?ut...d=o0ako89uurwl
JonD is offline   Reply With Quote
Old 02-04-2019, 02:42 PM   #13
TrackClub
TrackClub's Avatar
Thanks!
Old 02-04-2019, 03:52 PM   #14
Dave-ROR
Drives: A few
Mine was more aggressive than the track alignment - however - the selling dealership is the one who changed it before I bought it. You could clearly see that the factory paint on the bolts (that they add to show it was tightened) no longer lined up so it was changed after it left the factory.
Mine was -2.1 up front and -1.9 in the back. Front was toe'd out. Rear was zero toe.
Now it always runs -2.6 front and -1.9 rear, but with less toe.. car is less responsive at turn in now but of course tire wear will be much better without that toe out.
-Dave
HPDE/DD: 2018 Camaro ZL1 1LE || HPDE/DD: 2015 Subaru BRZ ||Tow Vehicle: 2004 GMC Sierra 2500 8.1L || Weekend toy: 1994 MR2 Turbo || The other weekend toy: 1993 MR2 Turbo || Track car: 1998 Integra Type-R || Race car: 1996 Integra GS-R || New race car build: 1992 Honda Civic Hatchback
Too many cars.. never.
Dave-ROR is offline   Reply With Quote
