Old 01-25-2019, 08:36 PM   #1
ParisTNDude
Owning SSes for 50 Years
ParisTNDude's Avatar
Drives: Sharkskin Grey LT1
While I"m Waiting for my 1le...
I guess I have read most of the threads on the 1le segment of Camaro6 and watched most of the videos on YouTube about them. One thing I've noticed is the drag strip guys are having trouble launching and 12.3 @ 114 might be about the best possible bone stock. Yeah, I know, the 1le isn't a drag strip car, but it is a place to run legally at over 100 mph or so. Some questions, if someone wants to share:
1. Is lots of wheel hop relatively normal on launch? In most of the videos it looks like there may be too much traction causing wheel hop and...is there a bone stock fix for it?
2. I'm not much in favor of burning up these expensive Goodyear tires at the drag strip. Is there a reasonably priced rear wheel rim for drag radials that will clear the brakes?
3. It looks like no-lift-shift is nearly as fast as the Auto 8. Some say it's very difficult to execute and otheres say it's easy. What do you think?
Just wondering...
The new ride: 2023 Camaro, LT1, Sharkskin Grey
Previous Performance Cars:
1966 Chevelle SS 4M, 2010 Corvette 6M
1968 Dodge Charger R/T Auto 2012 1SS 6M
1982 Corvette Auto 2010 1SS 6A
1984 Corvette Auto 2016 2SS 8A
1999 Camaro Auto 2017 HBM 1SS 1le
2002 C5 Corvette 6M 2018 2SS
2006 Corvette Auto 2023 Camaro LT1
ParisTNDude is offline   Reply With Quote
Old 01-25-2019, 08:55 PM   #2
Whocares05050
Drives: 2018 Camaro SS 1LE
Don't waste your time at the strip unless you upgrade the rear suspension. Upper and lower trailing arms, and upper control arm. I think each is 100 bucks for the non adjustable and they bolt right in. These cars wheel hop like hell...
Whocares05050 is offline   Reply With Quote
Old 01-25-2019, 08:57 PM   #3
MP3BOOSTED
MP3BOOSTED's Avatar
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C)
NLS isn’t hard, just do it, to many babies out here scared to do it, wheel hop is bad, not worth going to the track on street tires or stock setup. And 1LEs just don’t like brake stand burnouts, more of a dump the clutch and go kind of girl.
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw
MP3BOOSTED is offline   Reply With Quote
Old 01-25-2019, 09:58 PM   #4
ParisTNDude
I did that stuff on my 5th gen Camaro and it didn't help one bit. I'm going to take my 1le to Memphis a couple times and set my bone stock times and then do a few mods and see what happens. Beyond that, I will go to CamaroFest and or Holley LS Fest and car shows. Memphis also has a road course and track days which I will surely take advantage of. I'm going to love this car!!!
Old 01-25-2019, 10:13 PM   #5
ParisTNDude
After reading the posts, your comment made me think of something: Is the 1le any more prone to wheel hop, or drag strip woes than a 2SS 6M. I can't imagine that it would be...surely magnetic ride can adjust shocks and suspension to the degree that it is no better or worse than a 1SS?
What do you think?
Old 01-25-2019, 11:51 PM   #6
Cammed_1LE
Drives: 2018 Camaro 1LE
Guess I got lucky. My 1LE didn’t have wheel hop like my 5th gen did. My 5th gen was horrible.
My best run on a bad launch was 13.01@112 bone stock with 2000miles.
For the rims, you can look into racestars, they’re price pretty fairly, or if you want nicer and lighter you can go with welds. But they’re not as easy on the wallet.
No lift shift... I’m trying to get used to it. It very hard.. for me anyways... to do it after driving manual cars for so many years and having to lift to shift. It is quicker. Once you get used it it becomes much easier.
Cammed_1LE is offline   Reply With Quote
Old 01-26-2019, 05:51 AM   #7
wnta1ss
Drives: 2017 Camaro 1SS
The rear brakes on the 1LE are the same size as a normal SS. This means you can use the same 17" rear wheels that fit on the SS. Race Stars are cheap. The Weld RTS costs more than the Race Star but seems nicer quality.
Old 01-26-2019, 06:52 AM   #8
DorkMissile
DorkMissile's Avatar
Drives: DZ
I made a few trips last year to the track and had horrid wheel hop. Both with and without using the launch control.
I plan on doing the BMR links, but the first thing I want to try is the rear cradle lock-out. Looking at videos on the BMR website, you can see a lot of movement in the cradle under just normal driving conditions.
DorkMissile is offline   Reply With Quote
Old 01-26-2019, 09:28 AM   #9
Warrior102
USCG Retired (MKC)
Warrior102's Avatar
Drives: 2018 2SS 1LE Black
No idea on the wheel hop, I tried a couple of launch control mode runs for fun and nothing bad happened. As far as no lift shifting it can be a challenge if you're a long time manual driver, I still have trouble not letting off the gas.
Warrior102 is offline   Reply With Quote
Old 01-26-2019, 10:10 AM   #10
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
Indeed NLS is all about developing new muscle memory where that right foot doesn't twitch with the shift.
I have to consciously mash the pedal to the floor and practically lock my knee out to avoid the twitch that comes from 45 years of muscle memory (oh that sounds old!).
It takes concentration and practice. Make sure you NLS at high rpms - at or near red line.
476 rwhp/440 rwtq (sold)
Old 01-26-2019, 10:14 AM   #11
JonD
JonD's Avatar
Drives: 2018 SS 1LE
Don’t waste your time on stock wheels/tires unless you have seat time.
Race Star 17x9.5” in the rear & 18x5” up front
🌽 Sauced, 2018 SS 1LE - 123mph @ 5,000 DA
ARH 2”x3” FULL System, Pray Ported MSD Intake Manifold, Pray Ported GM 95mm TB, RotoFab CAI, DsX e85 Kit, MightyMouse Catch Can, NicD Tune
https://instagram.com/corn_sauced?ut...d=o0ako89uurwl
JonD is offline   Reply With Quote
Old 01-26-2019, 10:57 AM   #12
Camaro_QC
Camaro_QC's Avatar
Drives: 08 Tiburon GS, 2018 Camaro 2.0T
No lift shift needs some practice. Especially if you're a long time manual driver. Not lifting the gas when shifting takes a little concentration at first haha. But it is an awesome feature and I love that it comes standard on all Camaro.
2018 Camaro LS | 6 spd | 2.0L turbo | Nightfall Grey | RS package | Technology Package.
Order WDGHKX
1100 - 5/08/2018 | 3800 - 6/18/2018
2000 - 5/09/2018 | 4200 - 6/21/2018
3000 - 5/28/2018 | 5000 - 6/27/2018
6000 - 6/29/2018
Camaro_QC is offline   Reply With Quote
Old 01-26-2019, 04:28 PM   #13
Gasoline_Farts
Drives: 19 SS 1LE
NLS is super easy, keep right foot planted, clutch, change gear, release clutch. I suppose I have practice from my simulator (iracing), but it really is easy.
Gasoline_Farts is offline   Reply With Quote
Old 01-26-2019, 07:20 PM   #14
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
40 years of muscle memory is sometimes stubborn.
'18 1SS 1LE Black, PDR
