Old 01-13-2019, 05:54 PM   #1
02fbody35th
02fbody35th's Avatar
Drives: 2018 ZL1
Elite E2X can performance questions
Hey guys. I just finished installing a Elite can on my 2018 ZL1. All seems well. But I noticed that if I take the oil fill cap of while the engine is running there is some pretty strong vacuum on it. Is this normal!? The engine even started running a little funny. Like a vacuum leak. I verified that everything is set up correctly. Both check valves are installed and flowing away from the can. Have any of you noticed this?
02fbody35th is offline   Reply With Quote
Old 01-13-2019, 06:53 PM   #2
kwav8r
Flyin NOE
Drives: 2018 ZL1 (A10)
I’ve never taken the oil fill cap off with the engine running. But, I don’t see how the catch can would have anything to do with that. The vacuum lines for the catch can both run off the intake side.
Would be interesting to see if this is normal on a stock setup.
Old 01-13-2019, 09:23 PM   #3
SSallday
SSallday's Avatar
Drives: ‘18 ZL1 / ‘22 ZLE
Mine sounds like it has a vacuum leak as well. I think it would throw an engine light if it wasn't installed correctly, but I could be wrong. I noticed a loud ticking noise on startup after installing my can. it goes away as the car warms up. Not sure if it has to do with how I installed it or the cold weather
SSallday is offline   Reply With Quote
Old 01-13-2019, 11:30 PM   #4
Woodchip
Drives: 2010 Camaro RS /SS IBM M6/2018 ZL1
I believe there is a vacuum pump on the lower driver side of the engine,at least that's what it appears to be
Woodchip is offline   Reply With Quote
Old 01-14-2019, 12:55 PM   #5
02fbody35th
Drives: 2018 ZL1
I believe what you referring to is the water pump for the inter coolers
Old 01-14-2019, 12:56 PM   #6
02fbody35th
Drives: 2018 ZL1
So if you pull the oil cap while it’s running you feel a suction?
Old 01-14-2019, 04:16 PM   #7
Elite Engineering
Elite Engineering's Avatar
Drives: 2010 Camaro
What your experiencing is the enhanced evacuation the system provides. But show us how you routed your factory cleanside separator to make sure your still bringing in the MAF metered filtered fresh air. It goes into the factory cleanside box located on the passenger side cylinder head and splits to both valve covers. It gets the air from the main intake air tube.
Post some pictures so we can verify all is routed correctly.
Thanks!!
Elite Engineering is offline   Reply With Quote
Old 01-14-2019, 05:49 PM   #8
02fbody35th
Drives: 2018 ZL1
[QUOTE=Elite Engineering;10410103]What your experiencing is the enhanced evacuation the system provides. But show us how you routed your factory cleanside separator to make sure your still bringing in the MAF metered filtered fresh air. It goes into the factory cleanside box located on the passenger side cylinder head and splits to both valve covers. It gets the air from the main intake air tube.
Thanks!!
[/QUOTE
Here are the pictures of my set up. In the first picture you can see nothing is touched on the clean side separator. In the second pic shows the can routing. I have the line coming from the valley plate into the center of the can. The line on the left is routed around and over to the vacuum line connected to the throttle body. The line on the right is connected to the intake elbow just in front of where the clean side pulls its air from. Also in both of the outside lines on the can I have the two check valves with the arrow running away from the can. Does that all look right?
Old 01-14-2019, 08:28 PM   #9
Alain
Alain's Avatar
Subscribed!!!
2018 ZL1 1LE/Red hot
Old 01-14-2019, 09:29 PM   #10
SSallday
SSallday's Avatar
I'll have to check it out when I start it up
Old 01-15-2019, 01:01 AM   #11
nicktechla
nicktechla's Avatar
Drives: 2012 Porsche 911 Turbo S
I think that is just for the brake booster
IG: 2fast2nick
-- Current --
2012 Porsche Turbo S - PDK - Basalt Black Metallic
-- Past --
2017 Camaro ZL1 Coupe - Red Hot - A10, PDR - HRE P101
2015 Mustang GT PP - Whipple Supercharger
nicktechla is offline   Reply With Quote
Old 01-15-2019, 06:54 AM   #12
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
Cylinder shaped object maybe 6-8" around with hose going in from top, out through bottom on drivers side below air box is the intercooler pump. Sits kinda crooked in there, not perfectly aligned in any direction.
Old 04-04-2019, 05:49 PM   #13
Tabloma
Tabloma's Avatar
Drives: Red ZL1
Hey 02fbody35th, can you post a pic of where you ran the mount bracket, I like whete the can is. Thanks
Tabloma is offline   Reply With Quote
Old 04-04-2019, 05:59 PM   #14
Elite Engineering
Drives: 2010 Camaro
02fbody can confirm, but it looks like our XL bracket
