Old 01-01-2019, 06:21 PM   #1
Cupahaters
Drives: 2017 fifty camaro
19x12 and 19x13
Anybody tried and using 19x12 front and 19x13 rear wheels?
Cupahaters is offline   Reply With Quote
Old 01-01-2019, 06:35 PM   #2
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
I think that is why you got these ugly Wide body kits floating around....
Old 01-01-2019, 06:38 PM   #3
Cupahaters
It’s only one inch bigger than stock
Old 01-01-2019, 10:38 PM   #4
BradfordCamaro
SABIO
1 inch wider on wheels that already poke past the fenders.
Old 01-03-2019, 10:19 AM   #5
Destroyer_1LE
Destroyer_1LE's Avatar
Drives: 2017 Camaro 1LE
I don't even think its possible to run a 19x12 up front the largest that I've seen available is 19x11 front and 19x12 from Apex wheels https://support.apexraceparts.com/hc...-Fitment-Guide
To even be remotely possible your going to need a ZL1 1LE or a ZL1 with coil overs that have a lot of room
2017 Camaro SS 1LE
Instagram: @Destroyer_1LE
Sponsor: Tires: Michelin, Wrap: Protective Film Solutions, Wheels: APEX RACE PARTS
Destroyer_1LE is offline   Reply With Quote
Old 01-03-2019, 09:58 PM   #6
Cupahaters
I have a zl1 1le
Old 01-03-2019, 10:42 PM   #7
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
They will stick out solid 1.5" There is no room to go inboard w/o coilover top hats to move upper mount inwards. Even then, gain what... 6-10mm?
ing for grip.
http://www.motorsportsne.com/
Old 01-04-2019, 11:10 AM   #8
Destroyer_1LE
I have a zl1 1le
Since you do have a ZL1 1LE you maybe able to make it work, however what size tire are you trying to put on the front. 315? 325? Because you can put those tires on 11" wheel without a problem, however you should be careful with it rubbing.
2017 Camaro SS 1LE
Old 01-04-2019, 06:18 PM   #9
Carlos_MRRWheelsInc
Carlos_MRRWheelsInc's Avatar
Drives: camaro
Smile
We have a dealer that did 18x12 front and back but is strictly a track set up, camber adjustments where done at about 3.7-4.2 and is running 315/30/18 front and back. no rear mods
since the only et i had was a 50et he needed to use a 2" front spacer
If anyone is ever in need of such a set up I can pass down his info/ he said he would be more then happy to share what was done on the car etc/
again was a track set up not a daily.
Carlos_MRRWheelsInc is offline   Reply With Quote
Old 10-28-2023, 11:30 AM   #10
Sgtrod
Drives: Camaro 1LE
Anyone know what wheels those are?
Sgtrod is offline   Reply With Quote
Old 10-28-2023, 11:36 AM   #11
DaveC113
DaveC113's Avatar
Drives: 2018 Camaro 1SS 1LE
I fit 18x12 square on my car, the front is very tight but it works without rubbing, there's definitely poke. I don't run this setup on the road.
