Old 12-07-2018, 07:59 AM   #1
Cupahaters
Drives: 2017 fifty camaro
Trailering your car
For those of you who trailer your car. I am looking to buy a trailer. Have you found that the front of the car drags on the ramps? If so how did you fix that.
Thanks
Cupahaters is offline   Reply With Quote
Old 12-07-2018, 08:25 AM   #2
Travis104
Drives: 2014 ZL1
I have purchased a set of race ramps to assist in loading on my trailer. I haven't used them yet, as now I am concerned my trailer isn't wide enough. It is a featherlite aluminum trailer, but it is only 79" wide.
Travis104 is offline   Reply With Quote
Old 12-07-2018, 09:01 AM   #3
Hellobatman
Hellobatman's Avatar
Drives: 2017 Ford F250, 2019 Lincoln Navi
That's the only way really, long race ramps. Mine gets very close at the bottom of the ramp right when the wheel gets on pavement. Good luck!
Instagram: MattZ_L1 Vengeance Racing Built
Hellobatman is offline   Reply With Quote
Old 12-07-2018, 09:34 AM   #4
Travis104
Drives: 2014 ZL1
How wide is your trailer?
Old 12-07-2018, 09:45 AM   #5
Hellobatman
Unfortunately I'm not sure. I don't have it accessible currently. Sorry
Old 12-07-2018, 09:59 AM   #6
Dmaxcc6spd
Dmaxcc6spd's Avatar
Drives: 71 Camaro SS - 17 Camaro SS1LE
I would strongly encourage you to look at a trailer with e-track embedded in the floor AT THE CORRECT WIDTH! I have an H&H Speedloader EX. It is a hydraulic tilt trailer. I needed to use Race Ramps to get on the trailer. Once on, I realized the factory installed e-track wasn't wide enough. I added another row of e-track to use Mac's Custom Tie Downs.
http://www.macscustomtiedowns.com/pr...e-Block-Straps
I ordered the set for use with e-track. Not cheap, but great quality and great product. Easy to use! I was struggling with axle straps and didn't want to loop through the wheel. Further in the 1LE sub-forum, I read about a few who claimed strapping down with ZL1 Addons or using the suspension wasn't optimal. Further, I couldn't find a decent point to anchor the rear.
With enough space, the Mac's setup above is super low profile and the rachet mechanism is in the clear in front of, or behind the car.
79 Camaro RS (my first Camaro)
71 Camaro SS
94 Camaro Z-28 (sold when gas hit $4/gal)
14 Camaro RS (gone - totaled by 8&9 year olds)
17 Camaro 1LE HBM Ordered 02/21 Built 4/24, Delivered 5/4
Dmaxcc6spd is offline   Reply With Quote
Old 12-07-2018, 10:01 AM   #7
Rodan
Drives: 2018 ZL1 coupe
If it's a very close fit with your current ramps, a 2' long 2x6 under the ramp may be enough to get the job done. Tire rolls up on the 2x6 first, then onto the ramp.
Think this, but use only one layer if needed:
Rodan is offline   Reply With Quote
Old 12-07-2018, 10:45 AM   #8
Markoz28
Drives: 18 ZL1 nightfall grey A10
This is what I have done in the past with my previous cars. I no longer have a trailer but this is what I would do. Cheap and easy fix
Markoz28 is offline   Reply With Quote
Old 12-07-2018, 11:18 AM   #9
Pollock
LT4 M6
Pollock's Avatar
Drives: 2018 ZL1 1LE
I believe I might have the same trailer. It fits but I dont feel comfortable loading by myself.
The 2018 Chevrolet Camaro ZL1 1LE measures 74.70 inches in width, 188.30 inches in length, and has a wheelbase of 110.70 inches.
Pollock is offline   Reply With Quote
Old 12-07-2018, 11:48 AM   #10
Travis104
Drives: 2014 ZL1
I don’t think I would feel comfortable loading by myself either. I have some additional anchor points on the outside of the trailer, and the head of the bolts are on the inside rail, so it is actually about 78.5” wide. How close is it on the sides? I’m guessing after you remove the fender, there aren’t any issues opening the door?
Old 12-07-2018, 02:09 PM   #11
TEXASHIGHSHERIFF
TEXASHIGHSHERIFF's Avatar
Drives: 2019 ZL1 A10 to be serious modded 2
I put the red loading blocks back in the front. They are shipped like that for extra loading height.
2016 corvette Z51 A8 835 WHP
2018 Silverado crew cab lb 2500 Duramax
2018 Colorado CRew cab Duramax (toad for motor coach)
2016 Winnebago Journey 40U
2018 Traverse premier (wife’s)
TEXASHIGHSHERIFF is offline   Reply With Quote
Old 12-08-2018, 08:32 AM   #12
MoreSpeed
MoreSpeed's Avatar
I used to use the multiple pieces of wood method which was cheap but problematic. I had to haul all that wood with me to events, plus my gear and it took a little more time putting all my blocks together.
I bought race ramps ( https://raceramps.com ). I used the calculator on their website and that worked out well. No scraping even for my 2010 GT3, which was much lower than the ZL1 with longer overhangs. Little pricey but works well, saves damage on your cars (which can be pricey also), and well made.
- Life is a highway... I want to ride it all night long...
Sold 2010 997 GT3, 2016 WRX, 2006 997 C2S, 2003 996 C4S, 2001 Boxster S, 1997 E420 AMG
etc..
MoreSpeed is offline   Reply With Quote
Old 12-09-2018, 07:19 PM   #13
Pollock
LT4 M6
Pollock's Avatar
Didnt measure but only like 1.5 inches on each side..Its tight. But it works. So.. I will go with it.
Old 12-09-2018, 09:01 PM   #14
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
I have a Featherlite 18' trailer which works perfectly with race ramps and the ramps included with the trailer. I do nothing other than drive on and strap down. I leave the spring spacers out too.
