![]() Drives: 2018 ZL1, 2018 Tahoe RST Edition Join Date: Aug 2018
6MT Popping our of first?
Hey guys so I’ve owned my 6MT for about 6 months now with roughly 5k miles on it and out of those miles it’s popped out of gear on me from a start in first about 4 times.
How it happens is I’m sitting at a stop I confidently put the car in first, sometimes I’ll do it twice just to make sure and when light turns green I start going. As I do that it will pop back into neutral with a large CLUNK sound? Could there be an issue with my brand new trans? |
Are you sure you are fully pressing the clutch and fully engaging into first gear?
If you can rule out driver error. Dealer time :( |
![]() Drives: 2017 ZL1 6MT Join Date: Feb 2018
This^^^. Plus is this your first manual vehicle?
2017 ZL1 Arctic Blue Metallic / 6MT / sunroof / NAV / PDR / RotoFab CAI + dry filter / Tony Mamo TB V1 / Skip Shift Eliminator / Hurst Short Throw Shifter / ZL1 floor mats / Dead Pedal cover (to match other pedals) / ARH Catless 1-7/8" headers + ARH X-pipe + AWE Touring Axle-Back / Diode Dynamic smoked side markers / American Authority tow hook
![]() ![]() ![]() Drives: 2018 ZL-1 Join Date: Jan 2018
I had a Toyota truck that did that after about 175,000 miles. Trans needed rebuilding. If it's not driver error, the dealer needs to get on it.
![]() Drives: . Join Date: Jan 2013
Sounds like something wrong with the first gear synchro. That will have to be repaired under warranty. They will likely replace the entire transmission.
#6 | |
Coupe Newbie
Drives: '23 CT5-V BW, '21 Corvette HTC Join Date: Jul 2011
I don't think it's a transmission issue since it happens so randomly. There's just some scenarios where you push it into first gear but for some reason it doesn't fully engage. It's most likely driver error. Now if it would happened every 2nd or third shift into first, then I'd say there's a problem the dealer needs to address.
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 Silverado Z71 6.2L A10 Join Date: Mar 2017
I think that is the ZL1 speed shift function.
Current ride
2019 Silverado Z71 LTZ 6.2L L87 425hp A10, 4 inch BDS Lift with Fox Factory Race 2.5 Coilovers, Borla Cat back (15HP bump), BFG KM3's 33's. Past Rides 2017 M6 Camaro ZL1 Hyper Blue 2016 M6 GT350 White with blue strips 2014 M6 Mustang GT Premium Track Pack Ruby Red 2012 M6 M3 Melbourne Red Metallic |
#8 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
I have for sure, in various manuals, during the first few minutes of driving, put the car into gear and it didn't go fully into gear, but sure as hell felt like it did; thus, the shifter popping back into neutral on attempt to accelerate. A product of cold fluid/the syncros not lining up completely and me not paying close attention/shifting too quickly [for cold fluid] into gear. If the fluid is well-warmed/hot, the clutch pedal is fully depressed and you are damn-sure you have shifted completely into gear, it's 1st gear syncro time... If so, on the bright side, the Tremec has a reputable history and it should be good-to-go after the fix. |
#9 | |
#10 |
Also being that it pops into neutral like that do you guys think this could have caused a little damage to the trans in anyway?
#11 | |
I just realized that this has only happened to you four times. I retract my statement about any transmission replacement. With only four times, I would say no, there is no damage. My Corvette does the same thing occasionally if I don't pay attention and shove it all the way into 1st gear. Never noticed any difference in transmission performance with 70K miles. When you put it in gear, be sure it is actually ALL THE WAY forward, not half way. Sometimes it can get a little hung up going in. If it does, put back it in neutral, let the clutch out, push the clutch back in, and push the shifter into 1st gear. |
#12 |
![]() ![]() ![]() Drives: ZL1 1LE A10 Join Date: Mar 2015
Do you often coast to a stop without downshifting into second before going into neutral? Like say 4th or 3rd, then Neutral and stop?
In my 20+ years of driving a manual I've had over 40 cars (some nice, most junk) and I can confidently say that most cars do this. If the synchros are not aligned with the stars when the wind is blowing exactly NxNE at 31mph on any day other than Tuesday, except when you're uncles' brothers' son had beans three nights before -- it *can* happen. The gear should fit solidly into place if not or if unsure try this: 0. While stopped 1. Put the car into 2nd Gear. 2. Put then put the car into 1st Gear. This aligns the synchros and should allow 1st to fully drop in. This is a good habit to get into to. If you do this and it still pops out, guaranteed synchro malfunction. Warranty Repair.
Current: 2019 ZL1 1LE A10 Mods: MPS4s Tires | Borla Atak | CF Steering Wheel Previous: 2018 ZL1 1LE M6 | 2017 Z06 Z07 M7 | 2017 GS A8 | 2015 ZL1 M6 | 2013 GT500 |
#13 |
![]() Drives: 2018 Camaro ZL1 6MT Join Date: Mar 2017
I have the exact same issue. It happens sporadically, but I've been contemplating taking it in for warranty work. I can already imagine the scenario playing out in some tedious and nonproductive way because it is not consistently reproducible.
#14 |
![]() Drives: 2018 ZL1 M6 Join Date: Apr 2018
I rarely downshift all the way to 1st before coming to a complete stop at a light. Usually I just coast up to a stop when casually driving. No matter what gear I wind up in when stopped I always go to 1st, back to 2nd, then back to 1st while I'm sitting at the light. Might as well call it an OCD type tick. I just always watched the ole' man do it. Never really had a reason or explanation.
I wonder if he was aligning the synchros? Guess I'll never know. |
