Old 10-18-2018, 12:30 PM   #1
Azerlazer26
Azerlazer26's Avatar
Drives: 2018 Camaro 2SS
Winter storage!!! (1st winter with Camaro)
Hi everyone! Hope you are doing well. Sad to say but winter is coming up pretty quickly. As this is my first winter with my Camaro I need some tips on storage. What do you all recommend me to do?
Azerlazer26 is offline   Reply With Quote
Old 10-18-2018, 12:38 PM   #2
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
store inside? outside? AC power avail?
need more info....
Old 10-18-2018, 12:47 PM   #3
Azerlazer26
need more info....
Planning on storing get inside my garage throughout the winter. AC power is available in the garage
Old 10-18-2018, 12:52 PM   #4
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
wash it/cover optional
inflate tires to 40
fill with 90+ octane, for one winter, sta bil not needed, but ok if you want
put a $30 battery tender on batt, connect thru the front engine bay
do not start the car until youre ready to use it again.
Old 10-18-2018, 01:56 PM   #5
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
https://www.camaro6.com/forums/showthread.php?t=509495
https://www.camaro5.com/forums/showthread.php?t=254887
https://www.camaro5.com/forums/showthread.php?t=23114
https://www.camaro5.com/forums/showthread.php?t=421737
Go up to the search pulldown and type 'winter storage' into the Google search field (the threads & posts search sucks). Several pages of threads will come up giving you all the information, and disinformation, you will need
Old 10-18-2018, 03:06 PM   #6
Saybo
Saybo's Avatar
Drives: 2018 SS 1LE
Hello Michibro. Here is the list of things I do.
Wash / Wax the outside.
Vacuum / Clean the inside thoroughly.
I turn air re-circulation on so it shuts the vent to the outside.
Fill the gas tank full.
I put a fuel stabilizer in it before I drive it home from the gas station.
Change the oil.
This year I also changed the diff fluid and trans fluid but it is not necessary.
Put it on jack stands on all 4 corners. I use rubber blocks between the jack stands and the frame.
Remove wheels.
I also remove the windshield wipers. Probably not necessary I just like the overkill.
Install trickle charger.
Shove towels or what have you in the exhaust pipes (remember to remove these in the spring)
I have a plastic cover I put on it.
Then say goodnight and let her hibernate for the winter.
Saybo is offline   Reply With Quote
Old 10-18-2018, 03:36 PM   #7
Azerlazer26
This is why the Camaro6 forums is my go to for questions thanks guys
Old 10-18-2018, 03:41 PM   #8
Camaro_Corvette
36.58625, -121.7568
Camaro_Corvette's Avatar
Drives: Team 1LE
I fill the Gas full, pull it into the garage, and walk away for 3 months.
Old 10-18-2018, 04:02 PM   #9
Airfuel
Airfuel's Avatar
Drives: '19 2SS M6.
Remove wheels.
A few things.
Suspension is not designed to be stored full droop. Puts strain on bushings.
This step is controversial........I never have done it and no problems.
Why remove wheels? If you are worried about flat spotting, (Not really an issue with modern tires stored for a few months) just pump up the pressure if you are really worried.
Now, what if your house caught fire? How would you move the car out? (I know, not a great possibility but hey, you never know)
Plastic cover? You want that to breath and not trap moisture.
People really over due storing a car for a few months. Relax!
2019 2SS, Shadow gray, 6mt, NPP, Magneride, Bose.
Airfuel is offline   Reply With Quote
Old 10-18-2018, 04:03 PM   #10
Airfuel
Airfuel's Avatar
Drives: '19 2SS M6.
Yup, more important things to worry about!
Old 10-18-2018, 04:54 PM   #11
GroundhogSS
GroundhogSS's Avatar
Be sure to include an oil change before you put it away. You don't want old oil with possible contamination on the engine parts. I've always done that with my boat even though not many hours on it (455 Olds).
Richard
Delivered: 08/15/2016
#TeamBeckyD
Old 10-18-2018, 05:02 PM   #12
Azerlazer26
Just got my oil changed and probably going to put another 200 miles from now till storage. Will the oil be fine?
Old 10-18-2018, 06:12 PM   #13
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
it will be fne......
Old 10-18-2018, 06:22 PM   #14
wwiiavfan
Drives: 2017 1SS Hyper Blue
Take the battery out and store inside your house. I used to be an advocate for just hooking up the battery tender, did it forever on my Harley’s, but last year I put the Camaro on a tender and in spring, it started just fine, but after about a month the battery was shot. Would die intermittently. Only 7k miles on it at the time. 😡
wwiiavfan is offline   Reply With Quote
