Old 10-02-2018, 10:42 AM   #1
D3adpool
D3adpool's Avatar
Drives: Garnet Red 2018 SS 1LE "Deadpool"
First mechanical issue with my 1LE...
Ever since day one of ownership, I noticed that the steering wheel would "click" softly while turning to the right just past center of the wheel. There was never any resistance...just that annoying click, and it would do it every time.
I just assumed that the car was new and maybe parts needed to be broken in or something like that.
A little over 4 months and 4000 miles later, it was still doing it, and at this point it started driving me insane. So I dropped the car off yesterday morning, and low and behold, I need an entire new steering column!
My dealer ordered the part under warranty and the car will be ready later today.
Has anybody else had this happen to them on their Camaro?
D3adpool is offline   Reply With Quote
Old 10-02-2018, 11:00 AM   #2
Tim202
Drives: 2018 ZL1 1LE
Mine doesn't make a 'click' sound, but if I'm not moving/1-3mph and slowly turn the wheel there is like a bump or dead spot (don't really know how to describe). It happens really quick and doesn't happen again for the rest of the turn, but it does happen shortly after center.
Tim202 is offline   Reply With Quote
Old 10-02-2018, 11:13 AM   #3
FH212
FH212's Avatar
Drives: 2015 Camaro Z/28
Hmmmm that pretty crazy needing a steering column! So far I have not had an issue...
2015 Camaro Z/28 - Red Hot
1978 Trans Am Y88 Special Edition 400/4 speed
2001 Mecham Trans Am #3 - 7.0L LS1
FH212 is offline   Reply With Quote
Old 10-02-2018, 11:16 AM   #4
D3adpool
D3adpool's Avatar
Yep, that's exactly when mine would "click"...turning right, just after center, and it wouldn't do it again the remainder of the turn, or when turning back to the left.
I'd bring it in Tim, it may be something serious like mine was, and it'll be covered under warranty.
Old 10-02-2018, 03:39 PM   #5
Scargoes
Scargoes's Avatar
Drives: '18 Hyper Blue 2SS1LE '20 Crush RSR
Tim, it could be that the dead spot is from the electric power assist. There is a torque sensor in the steering column that notifies the control module that you are putting pressure on the wheel to turn. The module then controls the level of assist required based on which tuning setting you have chosen. It really shouldn't be noticeable so you might want to get that checked out.
2018 Hyper Blue Metallic 2SS 1LE with Nav, PDR, and track alignment
1:28.95 Willow Springs Big Track
Scargoes is offline   Reply With Quote
Old 10-02-2018, 04:51 PM   #6
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
That sucks.
I hope it's a pain free visit to the dealership and all turns out well.
'18 1SS 1LE Black, PDR
Old 10-02-2018, 05:09 PM   #7
7speed
Drives: 21 SS
Anybody have any issue of steering wheel feeling kind of tight for a split second (mid turn) if having to crank it right all the way real fast at "high speed" making a right turn like onto a side street for example?
I only notice it if doing real fast turn of wheel, never if just cranking all the way at low speed right turn.
I do have headers but doesn't look like anything is touching when I look at steering shaft and turning the wheel.
FBO, E85
11.1@123
7speed is offline   Reply With Quote
Old 10-02-2018, 05:44 PM   #8
Boost Creep
Drives: '18 1SS 1LE
Just double check the headers for witness marks.
The steering shaft may be making contact when the engine is torqued under load or shifted slightly in the mounts due to turning. Static inspection may appear to be Ok, but under load/forces things may contact.
It could also be your steering angle sensor.
Old 10-03-2018, 08:29 AM   #9
Bad Anvil Garage
Bad Anvil Garage's Avatar
Drives: 2000 GMPPSV SS & 2020 2SS
Some Camaros have wiring harness issues for the steering. You intermittently lose power steering... There's a TSB out there for it.
Bad Anvil Garage is offline   Reply With Quote
Old 10-03-2018, 09:32 AM   #10
D3adpool
D3adpool's Avatar
Originally Posted by Boost Creep View Post
That sucks.
Of course, it wasn't bro.....
Not all of the parts arrived and the car wasn't ready. I got a loaner (2017 Silverado ) and they tracked the parts, they should be there today and the car SHOULD be done this afternoon.
Old 10-03-2018, 09:46 AM   #11
Pollock
LT4 M6
Pollock's Avatar
My steering feels way easier after I get off the track. I dont know if its in my head or what.
Pollock is offline   Reply With Quote
Old 10-03-2018, 01:57 PM   #12
Boost Creep
Drives: '18 1SS 1LE
Hope today turns out better.
Old 10-04-2018, 09:57 AM   #13
D3adpool
D3adpool's Avatar
**Update**
I Picked up the car yesterday, and it feels great! No noise at all and the handling feels razor crisp as it did before.
Overall, the Dealership service department was really pleasant to deal with, kept me well updated and was an overall great experience...go figure lol
If anybody else has the same issue, I strongly suggest taking your car in and having it checked; it could be a much more serious issue than it seems. I spoke to another of the service techs, and while he said it's not a common issue, he has seen it before on Gen 6 Camaros.
Old 10-04-2018, 10:04 AM   #14
Boost Creep
Drives: '18 1SS 1LE
**Update**
Good news man, I bet that's a relief.
