Old 09-02-2018, 08:17 AM   #1
SpeedLimit
Drives: 2019 F150
Bose system sub addition question
When adding a box with a 12inch driver. How to filter low end (40Hz) before the Bose amp so the low frequency signal doesn't make it to the Bose amp and speakers ?
Anyone found a way to do this with passive components ?
SpeedLimit is offline   Reply With Quote
Old 09-02-2018, 08:37 AM   #2
SpeedLimit
Drives: 2019 F150
I just read the answer to this question on the ST website. It's digital from the infotainment system to the amp input. Which leads me to the next question. Anyone make a harness and DSP that works with the factory equipment and a sub box ?
Old 09-02-2018, 09:13 AM   #3
SpeedLimit
Drives: 2019 F150
Found the answer to this question on the forums. Navtv M650-GM $850 Navtv is definitely proud of this item at $850 dollars.
Any alternatives the the navtv m650-gm ?
Old 09-02-2018, 10:10 AM   #4
tecboy
tecboy's Avatar
https://pac-audio.com/catalog/amppro...faces/ap4-gm61
Dont know if anyone on here has tried this yet...
Here is thread talking about it
https://www.camaro6.com/forums/showthread.php?t=535567
Wish the Nav or Pac were out before i did my system...i used a Rockford Fosgate 3Sixty.3 connected to my Bose amp outputs....the NAV or PAC unit would have made things much easier and cleaner sounding..
2016 Black 2SS A8 NPP Sunroof - Tinted Windows - Black Chrome Wheels - Custom Striping - ASC Sideskirts/Splitter - GM Lowering Kit - Complete Sound System - DD LED Sidemarkers
tecboy is offline   Reply With Quote
Old 09-02-2018, 10:40 AM   #5
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Use song Cherry Twist on The Crystal Method's Vegas album to test your system.
Before adding a sub, the bass line is almost completely absent in the factory Bose system.
After, hold onto your hat
Old 09-02-2018, 11:15 AM   #6
SpeedLimit
Drives: 2019 F150
Thanks Techboy ! Love this forum and the information that can be found here.
Hey I noticed you posted the pin-out for the Bose thing in the trunk a couple years ago. Do you happen to have diagrams/pin-outs for the other connectors on this thing?
Old 09-02-2018, 11:35 AM   #7
tecboy
tecboy's Avatar
Here is an older thread with the info..note the incorrect pinout for the rear deck speaker...diagram is backwards for that speaker if you decide to use it
https://www.camaro6.com/forums/showthread.php?t=488428
