Old 08-21-2018, 10:27 PM   #1
toohighpsi
Drives: 2015 C7 Z06 M7
Magnuson TVS 2650 Camaro - UPDATED with photos
Well it's been a while since this thing has been at the track, but the final remaining part has just arrived -
THE DRIVESHAFT!
Car has undergone some serious changes and hoping to finally get back to the track for some shakedown passes on Friday.
A quick photo tour of the changes are as follows
So we've dropped the 8 speed auto in favor of an ATI TH400 with 4000 converter, tranbrake, and air-shifter.
Swapped out the stock rear for a G-Force 9" with axles and a 3.55 gear
Added an rear mounted intercooler ice tank and biger pump.
I'm sure we have a long road of tuning in front of us, but looking forward to gettin back behind the wheel again.
I'll keep you updated on the progress.
Old 08-21-2018, 11:39 PM   #2
solobaric
solobaric's Avatar
Drives: 2002 Camaro SS
Looking great! Any idea on release dates for the under-hood kit yet?
2017 1SS Hyper Blue M6
2001 Ford Lightning
solobaric is offline   Reply With Quote
Old 08-22-2018, 06:29 AM   #3
laynlo15
Drives: 2022 Lt1 A10
Its gonna be a wicked ride, lets hope it will hook and you can actually put all the hp down to the track. The under hood is on the horizon and when it comes it will be worth the wait. Perfection takes time, I know its running late by some earlier predictions, but it will be awesome just like the big boy sticking out of the hood.
Old 08-22-2018, 07:49 AM   #4
ShizzySupra
Drives: 16' Camaro 2SS
Glad to see the cats out of the bag!
@DeathWatchCamaro on Insta
993whp Magnuson 2.3R
9.5 @ 145, Magnuson 2300, Full Weight 2SS, 17’s (810whp)
ShizzySupra is offline   Reply With Quote
Old 08-22-2018, 08:25 AM   #5
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Why did you get rid of the 8l90? Because race car??
Old 08-22-2018, 12:19 PM   #6
ShizzySupra
At that power level/torque you need to use 2nd gear to launch which causes its own issues. Also less gear changes the better.
Old 08-22-2018, 01:05 PM   #7
KingLT1
KingLT1's Avatar
Bummer...I was hoping to see a 8 second 8l90 pass
Old 08-22-2018, 01:06 PM   #8
ShizzySupra
Several shops have already done that.
Old 08-22-2018, 01:12 PM   #9
2K16SummitSS
Resident Land Surveyor
2K16SummitSS's Avatar
Drives: 2016 Camaro 1SS - Summit White M6
Man I love this car. Good luck with the upgrades, looking forward to seeing some passes when she's buttoned up again.
2016 Summit 1SS 49th Anniversary Commemorative Limited Plutonium Edition - M6, Solo Axleback & !RearCats, Ultra-Rare Cloth Seats, Forgestar CF5V 19x10-285/35 19x11-325/30
2001 NBM Trans Am WS6, Wifey's Grocery Getter - Torquer V2 cam, Racetronix Fuel Pump, Yank 3000 Stall, Transgo 1-2 kit, TSP LTs, Magnaflow, Strano Springs/Koni STR.T shocks, 17x9.5/17x11 TTIIs, Ed Wright tuned
2K16SummitSS is offline   Reply With Quote
Old 08-22-2018, 03:38 PM   #10
WILWAXU
WILWAXU's Avatar
Drives: 2019 Crush ZL1 1LE
This car makes good noises
John Brown
Instagram @wilwaxu
Facebook @wilwaxu
WILWAXU is offline   Reply With Quote
Old 08-22-2018, 04:02 PM   #11
laynlo15
It should go into the 8s with ease if Hubert can hook it. The car is actually heavier then stock with the full roll cage. Its been 9.14 at over 150 leaving in 2nd gear on the Power Tour but none of the tracks were prepped so it still spun the tires leaving in 2nd.
Old 08-22-2018, 07:05 PM   #12
Turbo_RORO
Turbo_RORO's Avatar
Drives: Camaro 17 SS
Looking good. Cant wait to see this beast run. This is gonna be a good winter for the 6th gen. But I do wonder why the turbo 400 over a 4l80? Track only usage? Do you have any other pumps in the intercooling system or just the EMP out back?
Turbo_RORO is offline   Reply With Quote
Old 08-22-2018, 09:19 PM   #13
toohighpsi
There will be a couple Magnuson 2650 releases at SEMA, expect to see it around that timeframe.
Old 08-22-2018, 09:35 PM   #14
toohighpsi
We hurt the stock torque converter lockup clutch from the second gear launches during Power Tour and not paying attention to the fact that it was set to lockup at 27mph. Had I noticed this in the cal and raised it it probably would have been fine, but since we had to pull the trans we decided to go with a more robust solution.
The A8 has a couple issues in a car at higher power levels;
First it requires a significant amount of torque management during shifts to keep it alive, when you're making 5 shift changes during a pass with each shift change requiring ~0.25 sec of reduced power this becomes an impact to the performance of the vehicle. With torque management turned off the trans will be lucky to make 2-3 passes before failure. The TH400 will not require any power reduction during shifts.
Also, first gear is too low at higher power levels, while this is the reason why A8 cars perform so well in a stock / slightly modified condition, it makes traction difficult with small tires with higher power.
