Old 08-21-2018, 08:04 PM   #1
barnesbr
barnesbr's Avatar
Drives: 2018 ZL1 10 spd
Power seems low
Curious how much the hot weather here in Florida affects the power. When I bought my car at the end of April I couldn’t keep the tires from spinning. Lately it just feels weak. Only things I have done is drop in a K&N air filter and pull the sound plate out of the supercharger lid, which I actually put back in. Anyone else have a similar experience?
barnesbr is offline   Reply With Quote
Old 08-21-2018, 08:24 PM   #2
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Turn off traction control and mash it. If the tires dont spin you are way down on power.
No the heat doesn’t help but we are at sea level. Mine lights em up from a dig with full nannies on.
Get an OBDII reader on it and look for BadThings(TM): high IAT, knock retard/timing pulls, extra rich, etc... Check coils and plugs. Change your fuel. Fuel economy drop off?
Put it back to stock and make sure you don’t have oil in the MAF sensor from that K&N, or an air leak in the SC lid gasket. IIRC you’re supposed to replace the SC lid gasket if you open it. And now that I said this you’ll see three pages of “I’ve had mine open ten times and it’s fine.”
Finally, check it on a dyno and have a tuner look at it. Then if all else fails, take it to a dealer.
Old 08-21-2018, 08:31 PM   #3
barnesbr
barnesbr's Avatar
Thanks for the tips. I will definitely check up on those things. Fuel economy has not dropped off and boost doesn’t seem to have changed going by the gauge. I know that’s not an accurate portrayal FWIW. It will definitely spin from a dig but not from a roll like before.
Old 08-22-2018, 04:10 AM   #4
Gunkk
Gunkk's Avatar
What else is different between April and now besides just ambient temps & humidity? Brand new tires with mold release still on them back in April? Stock goodyears are very temperature sensitive. They will spin at 2-3 shift below 70F even on a coarse surface. Much below 60F and you're on marbles. You'll understand this coming winter
Old 08-22-2018, 05:18 AM   #5
IneedAZ
IneedAZ's Avatar
I noticed it too. Doesn't feel like the same car.
Old 08-22-2018, 08:15 AM   #6
barnesbr
barnesbr's Avatar
Nothing has changed other than what has been mentioned. Put the stock filter back in and checked MAF sensor. Didn’t notice any oil/particles on it. Oddly enough, I got a check engine light and “reduced engine power” after checking the sensor. Pulled negative battery cable and it went away. Seems to be running a bit better for now. I think this is a sign to leave the car bone stock, other than some visual stuff.
Old 08-22-2018, 08:37 AM   #7
STAY IN IT
Drives: 2017 Camaro ZL1, M6
Based on my experience in Arizona without significant humidity I think ambient temperature is the biggest variable you are experiencing (Ultimately impacting traction level more than any significant changes in horsepower).
Prior to replacing my stock Goodyears with R888Rs, my car (in the winter with temps below 70ish) would spin the tires as you described. With our crazy summer heat and extremely hot pavement the car hooked up very well (night and day difference from cooler ambient temp. situation). Obviously part of that could be due to significant changes in power output, but my feeling is that in my situation it is mainly changes in traction I’ve noted which are admittedly dramatic. There are obviously quite a few variables, but it would be interesting to see what level of actual horsepower loss occurs as ambient temperature increases.
STAY IN IT is offline   Reply With Quote
Old 08-22-2018, 08:51 AM   #8
Markoz28
Drives: 18 ZL1 nightfall grey A10
I live in south TX and Temps here are in the 100s with humidity of a whole lot of wet. I can spin the tires at will in 2nd and 3rd. Sometimes on the highway at 75 punching it I can feel it get a bit loose but I’ll pedal that. I’m not noticing any power loss.
Markoz28 is offline   Reply With Quote
Old 08-22-2018, 09:05 AM   #9
RedHot18
Drives: 2018 ZL1
Should smoke em at will. I'm putting my second set on the rear at 9K miles.
RedHot18 is offline   Reply With Quote
Old 08-22-2018, 09:49 AM   #10
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
set your performance to zero to 60 lets see what you get! if its in the 4s you go a lemon!
Old 08-22-2018, 11:45 AM   #11
collinms
Drives: 2017 ZL1 A10 Summit White
Haha yes considering I got 3.7 with me and my brother who both weigh 200 pounds lol.
collinms is offline   Reply With Quote
Old 08-22-2018, 12:54 PM   #12
Artos
Artos's Avatar
Drives: A10 LT4
Mark, where in the valley are you located??
Artos is offline   Reply With Quote
Old 08-22-2018, 07:14 PM   #13
barnesbr
barnesbr's Avatar
Well, I got 3.6 before so I do need to try again. Unfortunately, there aren’t many “closed courses” close to me 😂
Old 08-22-2018, 09:50 PM   #14
Markoz28
Laferia/Harlingen
Where you at?
