Old 08-15-2018, 12:03 PM   #1
C Man
Drives: 2018 White Convertible Camaro ZL1
Clicking noise around tight turns on front wheel - Any ideas?
Hi Guys,
When driving aggressively and making swooping right turns along curves entering a highway or other curves, my front Driver side wheel makes a clicking noise... a very pronounced click click click for each rotations of the wheel (so very quickly)
The noise stops when driving straight or even making quick sharp turns at an intersection doesn't do it. Just hard turns on curves moving fairly quickly.
I do also have a slight squeak on that side as well when sometimes turning slightly right... but I'm not sure if it is related.
Any idea what would cause this click?
White 2018 Camaro A10 Convertible ZL1
C Man is offline   Reply With Quote
Old 08-15-2018, 12:05 PM   #2
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Retorque your wheels to #140......thats the solution for many.....
Old 08-15-2018, 12:57 PM   #3
BDivine76
Drives: 2018 Camaro ZL1
This works for most and it should be tried first. If not, pull the wheels, clean the hubs, and add a thin layer of white lithium grease. Put the wheels back on and torque to 140.
I had the same issue and this solved it.
BDivine76 is offline   Reply With Quote
Old 08-15-2018, 01:48 PM   #4
Sub
Sub's Avatar
Drives: 2017 ZL1
What is the oem spec for torque? 140 seems really high!
My Car Blog and mods. Previous Chevys: 2016 2ss, 2015 C7 z51, 2004 C5 Z06
Sub is offline   Reply With Quote
Old 08-15-2018, 01:54 PM   #5
zeroescence
zeroescence's Avatar
Drives: 2018 ZL1 A10, 2011 6.2 Ford Raptor
Hope this helps.
zeroescence is offline   Reply With Quote
Old 08-15-2018, 01:54 PM   #6
SoCal Smith
SoCal Smith's Avatar
Drives: 2019 Camaro ZL1 1LE A10
This worked for me! Oem is 140
SoCal Smith is offline   Reply With Quote
Old 08-15-2018, 02:04 PM   #7
k20attack
k20attack's Avatar
Drives: 2018 Camaro ZL1 M6
Removing the front wheels, cleaning hubs and re-tightening to SPEC gets rid of this. Had same issue. Dirt builds up.
3000-9/18/2017
Received-12/1/2017
k20attack is offline   Reply With Quote
Old 08-15-2018, 02:07 PM   #8
Sub
Sub's Avatar
Drives: 2017 ZL1
Thanks Zero.. So what is the issue? They loosen after a bit of use, or they were improperly tightened from the factory?
Whats actually making the noise? Is it moving/riding on the threads a bit?
Old 08-15-2018, 02:19 PM   #9
waterman
waterman's Avatar
Drives: Grandad's C2 L89
Mine were all over the place at delivery. Every single lug was under torqued.
No issues since, checked @ 300 and 500.
2018 ZL1 1LE sw/PDR
Old 08-15-2018, 02:27 PM   #10
zeroescence
Not a problem. I wish I knew what the issue is. Lol. I’m so tired of it. I had the lugs torqued to 140 and it didn’t fix the issue at all. So this weekend I’ll be taking off the front wheels and cleaning the hub area as some have started will fix the issue. I hope it works.
I have a feeling it has something to do with the two piece rotors. Maybe they can make noise if not perfectly fastened straight. So the little bit of corrosion and dirt on the rotor and hub area allows them to move just enough to cause this noise. That’s just a thought I had.
Old 08-15-2018, 02:44 PM   #11
C Man
Thanks guys for the responses.
I will look into it and see if the suggestions worked. Stay tuned.
Old 08-15-2018, 11:37 PM   #12
R3ctivision
1LE Convert
R3ctivision's Avatar
Drives: 2018 ZLE
I have the same noise I just noticed, never before. Haven't torqued my wheels in a few months, so makes sense..
R3ctivision is offline   Reply With Quote
Old 08-16-2018, 12:34 AM   #13
mr965
mr965's Avatar
Drives: ///M3
Check the wheel weights. Might be too close to the brake caliper.
mr965 is offline   Reply With Quote
Old 08-16-2018, 03:08 AM   #14
dwill8335
Drives: 2017 Camaro ZL1 Ice Metallic A10
https://static.nhtsa.gov/odi/tsbs/20...82871-5448.pdf
dwill8335 is offline   Reply With Quote
