Old 07-03-2018, 04:50 PM   #1
Booher
Booher's Avatar
Drives: 2019 zl1 6 speed
Stock ss tires short life span?
Hey guys, my car just passed 7200 miles and I checked my tread wear today. The inside of my rear tires are 2 1/2 mm while the outside is 3 1/2 mm. Is this normal wear for the tire, 1mm difference? I normally have it filled to 38 psi when hot. I was thinking maybe I smoked the tires too much trying to launch it so I checked my front tires. They are 4mm all around, I thought I remember reading people getting 10k plus out of them. Is it possible the roads are just that bad where I live?
Old 07-03-2018, 05:15 PM   #2
i007spectre
i007spectre's Avatar
Drives: 2016 2SS, 2008 HHR ECTO-2H
Needed to change my stock tires out at about 8000 miles. Im not a hard driver either.
2016 Camaro 2SS. Hyper Blue, Ceramic White, Auto, MRC, and NPP.
1100 - 9/25
2000 - 9/28
3000 - 9/30
3100 - 10/27
3300 - 10/28
3400 - 10/29 TPW 11/09
3800 - 11/10
4300 - 11/24
4B00 - 11/25
4200 - 12/5
5000 - 12/7
6000 - 12/11
i007spectre is offline   Reply With Quote
Old 07-03-2018, 07:08 PM   #3
VinnAY
Drives: 18 1SS/1LE
38 hot is a bit much, should be setting to 32 cold. Also are you on a square setup or staggered? If square I'd rotate them a lot more but then it's pretty typical in this type of car with these kinds (summer) of tires that that they're not going to last long at all.
Old 07-03-2018, 09:07 PM   #4
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
I have 20,000 miles on mine and they are still above the wear bars. Miles are mostly highway driving. Maybe have your alignment checked to see if the tires are wearing faster due to an alignment issue. It only takes a few minutes to check alignment these days. They just pull you into the service writer's lane, attach a device to the wheels, and roll it a few feet at the local dealership. They will print out the readings while you wait.
Mark114 is online now   Reply With Quote
Old 07-03-2018, 10:22 PM   #5
Booher
Booher's Avatar
I'm staggered, I always wondered about my tire pressure. My cold is 88 degrees as summer is here lol, been 110 plus for a few weeks now. I'm glad I'm not the only one. How are the roads out there for you mark? I don't know how some people get that as I know you aren't the only one.
Old 07-04-2018, 05:57 AM   #6
VinnAY
Drives: 18 1SS/1LE
The air temp has no factor...cold as in it's sat overnight "cold".
Spec is 32psi cold. Check your door jamb. Otherwise staggered you can't rotate them so that's all you got. Would concur with the alignment check, usually a check on that would be free, and $80 to align it if it needs it.
Old 07-04-2018, 02:23 PM   #7
Spanky1
Drives: 2017 2SS Summit White Camaro M6
I thought spec is 35psi.
Spanky1 is offline   Reply With Quote
Old 07-04-2018, 02:42 PM   #8
JoeCamaro444
JoeCamaro444's Avatar
Drives: 2018 2SS M6 Hot Wheels Camaro
Spec is 35PSI cold. You are correct. I find that a bit too much, as they are mostly driven in warm weather and obviously heat up when driven on as well. I fill them to 33PSI cold, that way they range from 33-37PSI while driving. That’s just where I like them. 👍🏻
2018 2SS M6 Hot Wheels Camaro loaded (Moonroof, Magnetic Ride Control, NPP, etc…)
Previous cars:
2017 1SS Nightfall Gray Metallic w/A8 and NPP
1988 IROC-Z (tons of mods), 1995 Z28, 1998 Z28, 2006 GTO, 2010 Camaro 1SS, 2015 Subaru STI, a couple Acuras and multiple Jeeps.
JoeCamaro444 is offline   Reply With Quote
Old 07-07-2018, 10:46 AM   #9
cmferdz63
Camaro Fan
cmferdz63's Avatar
I’ve got 16k on my tires, hoping to get 24k out of them, but I’m not sure I’m going to make it. Going forward my question will be on what to replace them with. I’ve already been looking at options on tirerack.com but my choices are limited due to the runflats.
CMF
cmferdz63 is offline   Reply With Quote
Old 07-07-2018, 11:07 AM   #10
Corvette_Mike
Corvette_Mike's Avatar
Drives: 2018 Camaro SS
Im at 6k on mine. Hoping for a couple thousand more.
Corvette_Mike is offline   Reply With Quote
Old 07-07-2018, 12:20 PM   #11
apexit53
apexit53's Avatar
Drives: 22 1SS 1LE Summit White
still on my 1st set and i have about 20k on it. Granted I put snow tires on this winter that added up to about 5k miles so lets say 15k on the OE tires.
That said if i went to a dealer they would tell me i need new rears... the rears will need to be replaced probably this fall/spring.
#53 F Street
2025 FS National Champion
2026 Sponsors
autocrossdigits.com
karcepts.com
Autocrossing Videos
https://www.youtube.com/channel/UCm-...3tiMt0KOg_2Aag
Instagram: apexit_53
apexit53 is offline   Reply With Quote
Old 07-07-2018, 02:24 PM   #12
enzia35
Drives: '16 Garnet Red 1SS
I did about 21-22k on mine.
'16 Camaro 1SS
'18 Miata GT
Old 07-13-2018, 02:14 PM   #13
samsumon
Drives: 4 wheels
what are good alternatives? Doesn't have to be run flat. But I need new set ASAP up front and i'm trying to be price conscious
samsumon is offline   Reply With Quote
Old 07-13-2018, 02:23 PM   #14
Kise
Kise's Avatar
Drives: 16' 2SS, 06' Silverado SS
have 20k on mine and I burn them a good bit. would say I have like 35-40% left
Kise is offline   Reply With Quote
