Old 06-26-2018, 09:29 AM   #1
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
Katech Breakthrough LT Direct Injection Technology - 1000 RWHP Capable
Check this out. Might be a good answer for the big builds.
https://youtu.be/npwMohtNC2s
Old 06-26-2018, 11:15 AM   #2
newchevyman
Drives: 2017 Camero ZL1
Too bad there's still no reasonably priced fueling option besides meth.
http://store.katechengines.com/mobil...stem-p631.aspx
2017 ZL1 A10
Dyno/Quarter Mile/Dragy
9.71@141.2 MPH so far.
2007 Z06 H/C/I/E Half Mile - 169 MPH. Sold.
newchevyman is offline   Reply With Quote
Old 06-26-2018, 11:21 AM   #3
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
so they grabbed a diesel guy to make a dual cp3 type steup for lt1's?
sweet.
now how many first borns will it cost?
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock
800 SAE rwhp. 9.4 @ 145 mph.
Old 06-26-2018, 11:51 AM   #4
7WSM
7WSM's Avatar
Drives: 2017 ZL1 A10
Only 4500... But as I see it, this might be the best option available.
7WSM is offline   Reply With Quote
Old 06-26-2018, 12:18 PM   #5
Can'tHave2MuchHP
Drives: Fast
Pretty much everything direct injection costs an arm and a leg so far. I'm not surprised by the price of the system and Katech does good work.
Old 06-26-2018, 01:45 PM   #6
Franko07
Drives: 17 white 1LE
Great idea,its actually a really simple concept, its a "lobe box" with a high psi pump bolted to it. completely adjustable with pulley and pumps
Franko07 is offline   Reply With Quote
Old 06-26-2018, 01:46 PM   #7
Ricco
Ricco's Avatar
Drives: 2018 ZL1 Vert A10
So they are saying that as long as you can provide the air, this fuel system is good to 1200whp on straight E85? No cam, no injectors, no Lowside, no Meth.
2018 ZL1 Vert - 854Whp / 791Wtq
2016 BRZ
2013 X5D
2005 STI
2001 2.5 RS
Previous cars in chronological order
2016 GT350, 2014 MEV Rocket, 2013 Nissan Qashqai + 2, 1.6L Diesel, 2010 Nissan Note 1.5L Diesel, 2012 Dodge Ram 2500 6.7L Cummins, 2009 Subaru Impreza STI, 2005 Dodge Ram 1500, 2004 Mini Cooper S, 1997 Subaru Impreza Catalunya special Edition, 1992 Daihatsu Charade GTti, 1978 Mk1 Ford Fiesta
Ricco is offline   Reply With Quote
Old 06-26-2018, 02:39 PM   #8
kttxz06
kttxz06's Avatar
Drives: '18 Zl1. '18 GT350.
If that's the case, then this mod is a no brainer.
There's only 2 people I trust. 1 of them is me, the other's not you. 2018 Zl1. 1199 RWHP/931 TQ.
kttxz06 is offline   Reply With Quote
Old 06-26-2018, 02:48 PM   #9
Ricco
Ricco's Avatar
Indeed.
2016 BRZ
2013 X5D
2005 STI
2001 2.5 RS
Old 06-26-2018, 02:52 PM   #10
TMS
TMS's Avatar
Drives: 2018 ZL1 1LE - HBM, PDR
How is it possible that the lowside pump wouldn't require upgrading? I would surely think the lowside would not keep up with those power numbers. Inquiring minds.
Intrigued and subscribed.
Sent from my SM-G950U using Tapatalk
JRE Tuned (HPTuners) | 15% OD (9.17" crank pulley) | TVS2300 Maggie Heartbeat Supercharger - 14 psi | E-50 (DSX Flex Fuel kit) | JMS FuelMax Fuel Pump Booster | LPE Big Bore High Volume DI fuel pump | LPE High Flow DI fuel injectors | LT5 95mm TB | RotoFab CAI | AEM X-Series OBD2 wide band gauge | Elite Engineering E2-X catch can | Borla S-type NPP Cat-Back 3" exhaust | Forgeline GTD1 5-lug Satin Graphite | SunTek wrap | C-Quartz Finest Reserve ceramic coated
TMS is offline   Reply With Quote
Old 06-26-2018, 02:56 PM   #11
Fraxum
Fraxum's Avatar
Indeed.
Hey can you guys straighten me out on Meth?
We need that early in the HP game because the little LT4 is already turning so fast we need the meth to cool the charge down?
So where on a build would it be wise to go with meth? I was hoping to add enough hp to my LT4 to push my A10 into the 10s some of the time and leave a stock appearance.
Is using E85 instead without pushing the timing another option?
Of course fueling is another matter with DI.
Sorry for the diversion.
Old 06-26-2018, 03:21 PM   #12
Ricco
Ricco's Avatar
E85 has a higher octane rating than pump gas but you need to flow about 30% more of it to make the power. The stock fuel system simply can’t deliver enough fuel to take advantage of it fully. Meth is used to primarily cool the intake charge, when you start spinning the tiny blower much past stock, the cooling bricks just can’t keep up and iat’s go through the roof, meaning timing is pulled up top to protect the engine from detonation. The more you run it the higher the iat’s go.
You should be able to easily get into the 10’s with headers & exhaust, intake, pulley and a good tune. No e85 or meth required.
2016 BRZ
2013 X5D
2005 STI
2001 2.5 RS
Old 06-26-2018, 03:39 PM   #13
7WSM
7WSM's Avatar
That would be too simple. I just don't see the need for a secondary injection system if this pump can handle all that. But if it is true, and they make the brackets for a Camaro, put me down for a twin turbo kit.
Might have to do a little more research into this as I think the Mustangs are running a similar aux injection pump on the 18s to be able to make huge HP.
Old 06-26-2018, 03:48 PM   #14
Blackdevil77
Blackdevil77's Avatar
Drives: 2008 Pontiac G8 GT, Shelby GT500
Maybe if I sent Al O chocolates, he'll put the LT5 in the future ZL1's.
Blackdevil77 is offline   Reply With Quote
