Old 06-14-2018, 10:18 AM   #1
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
nearly stock dyno sheet 2017 ZL1 A10
Nearly stock meaning a Tony Mammo ported TB and green panel drop in filter. This is a new facility called National Speed in Richmond, VA. Awesome dyno cell and ventilation with an AWD Dynojet. The pull was performed in 1:1 ratio 7th gear in the A10. 577hp/592tq SAE corrected!
Old 06-14-2018, 10:22 AM   #2
Stephen12ZL1
Drives: '21 ZLE A10
pic:
Old 06-14-2018, 10:26 AM   #3
Stephen12ZL1
Drives: '21 ZLE A10
comparison thread with the same mods:
https://www.camaro6.com/forums/showthread.php?t=518895
Old 06-14-2018, 10:27 AM   #4
Krowser
Krowser's Avatar
Drives: ZL1 Mosaic Black
Originally Posted by Stephen12ZL1 View Post
pic:
Very nice. I have the same warranty saving mods; however, my car is an M6 so I'm putting down a little more hp and 600lbft of TQ.
Krowser is offline   Reply With Quote
Old 06-14-2018, 10:30 AM   #5
2018ZL1
2018ZL1's Avatar
Drives: 2018 ZL1 A10 NFG 2019 COPO 350 SC
Those are really good numbers! I haven't heard how much you should loose thru the A10 but i would think 20%??
2018ZL1 is offline   Reply With Quote
Old 06-14-2018, 10:45 AM   #6
Bill_76
Drives: Camaro ZL1 2018
This is my car, same setup, he you better numbers!, it depends on the dyno, but looks really good!
On July 1st the car will be 1 week in Lashway Motorsport for coilovers, AHR headers 2" + 3" long system (no cats) connected to the NPP, 9.1 lower pulley and Cold air intake......it will be tested on a Mustang dyno, and sure with high temperature here in Florida...lets see the numbers then, they hope to get around 630 whp on 93.
Bill_76 is offline   Reply With Quote
Old 06-14-2018, 11:31 AM   #7
kttxz06
kttxz06's Avatar
Drives: '18 Zl1. '18 GT350.
Those are insane numbers for stock. What are air temps? Just had a forum member throw down 530 as his baseline on a A10, but 100 degrees, 100% humidity, plus Mustang Dyno doesn't help.
There's only 2 people I trust. 1 of them is me, the other's not you. 2018 Zl1. 1199 RWHP/931 TQ.
kttxz06 is offline   Reply With Quote
Old 06-14-2018, 12:11 PM   #8
Ricco
Ricco's Avatar
Drives: 2018 ZL1 Vert A10
Judging by the look of the dyno cell, there may be some AC going on
2018 ZL1 Vert - 854Whp / 791Wtq
2016 BRZ
2013 X5D
2005 STI
2001 2.5 RS
Previous cars in chronological order
2016 GT350, 2014 MEV Rocket, 2013 Nissan Qashqai + 2, 1.6L Diesel, 2010 Nissan Note 1.5L Diesel, 2012 Dodge Ram 2500 6.7L Cummins, 2009 Subaru Impreza STI, 2005 Dodge Ram 1500, 2004 Mini Cooper S, 1997 Subaru Impreza Catalunya special Edition, 1992 Daihatsu Charade GTti, 1978 Mk1 Ford Fiesta
Ricco is offline   Reply With Quote
Old 06-14-2018, 12:38 PM   #9
ninetres
ninetres's Avatar
Drives: Crush ZLE M6 | 2000 Corvette FRC
All dynos read different. This is just a baseline. I never understand why people get so excited about dyno sheets. It’s literally a tuning tool that can not be used to compare horsepower output to another dyno, or even the same dyno on another day. There are soooooo many variables.
This same car could put down 530whp on a second dyno. And 590whp on a 3rd dyno.
ninetres is offline   Reply With Quote
Old 06-14-2018, 01:05 PM   #10
IneedAZ
IneedAZ's Avatar
Good to know for reference as i have the same two mods
Old 06-14-2018, 01:07 PM   #11
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
That and its a dynojet over a mustang
Old 06-14-2018, 01:10 PM   #12
BlaqWhole
Drives: 2017 Camaro ZL1 A10
You say that on a thread where 2 different cars on two different dynos in different areas and at different times put down remarkably close numbers, lol!! It's always good to know what your car makes and what you're getting out of the mods you add on.
Old 06-14-2018, 01:32 PM   #13
kttxz06
kttxz06's Avatar
Well no shit. But a 50 hp difference? I was just wanting to know air temps that's all. We all know if I take my last run of 803 which was in 98 degree temps with 100% humidity and rerun on the same dyno, but do it in Oct when it's 60 and 40% humidity, I'll get close to 850.
I like seeing high baseline numbers, but I also like to know air temps and the dyno used cus that does matter. And dyno numbers do matter cus it gives you a baseline to work on. Just because it may read 530 on another dyno means nothing.
What matters is when yo ass is on the streets anyways. I know my 803 dyno run was a hero run cus I heat soak after one hit. Blah, nevermind.
OP. those are good numbers. Build from there. Who cares if they could be lower on another dyno on another day.
Old 06-14-2018, 01:51 PM   #14
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Is there really any merit to 1:1 trans gear ratio.. since there is still ratio in diff to account for.. so its NOT 1:1.
ing for grip.
http://www.motorsportsne.com/
