Old 06-01-2018, 02:14 PM   #1
flaps100
flaps100's Avatar
Drives: 2017 Camaro 2.0 RS
Does this really add HP and Torque
I know this has been covered a lot, but there Dyno info shows a dramatic increase in HP and Torque,
And the people reviewing are all happy with results and some say no tune?
https://www.phastekperformance.com/2...ke-evo7300.htm
Thoughts ?
flaps100 is offline   Reply With Quote
Old 06-01-2018, 02:21 PM   #2
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
That much torque gain with that kind of torque delta vs. RPM is implausible for an airbox change.
It looks to me that the "after" graph is with increased boost and a poorly futzed with tune at high RPM. The "after" torque crashes around 6200 and looks like torque plausibility or perhaps turbo overspeed limits being clipped and the ECM doing emergency torque reduction.
I'd be thrilled if someone did a legit back-to-back test with datalogging.
Old 06-01-2018, 02:51 PM   #3
cooper1965
Coopers Camaro
cooper1965's Avatar
Drives: 18 Flex Fuel LTG
Yes that intake works wonderfully. Multiple examples all over this section of the forum. Don't believe that dyno graph though. Using the "best" and "worst" dyno graph comparison is a great way to sell more product.
Flex Fuel tuned by me using HPT-:-
---My Build Thread---
-----My IG PAGe-----
Old 06-01-2018, 02:57 PM   #4
flaps100
flaps100's Avatar
If I read you correctly?
So your saying there set up , tune and Dyno test are all BS, why would a company like that offer BS results to sell something that wont really do what there saying it does ? Don't they care about there reputation ?
Old 06-01-2018, 03:01 PM   #5
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
Did anyone post their own dyno comparisons, or perhaps MAF datalogs?
I can't speak for the manufacturer's intentions. To me their published dyno raises more questions than answers, and as is so common with automotive aftermarket, there is no regulation regarding proving the products' claims. CARB is the closest it gets, and that's just measuring tailpipe emissions during their drive cycle, not WOT power.
Old 06-01-2018, 03:16 PM   #6
JohnCobalt
JohnCobalt's Avatar
Drives: Camaro and Mazda CX3
I put one on my ss and the guy who used to tune it said get that crap outta there because it’s not doing anything. He seemed to know a lot about parts so I took it out. However I’ve heard many other experts talk about their benefits.
The topic is always ongoing, but I don’t feel like they help. I actually read more stories where they hurt the car. It’s all minor stuff of course, but I don’t think they’re worth it.
JohnCobalt is offline   Reply With Quote
Old 06-01-2018, 04:25 PM   #7
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
We're talking about the LTG 2.0T engine. The LT1 airbox is fairly well documented.
Old 06-01-2018, 04:30 PM   #8
JohnCobalt
JohnCobalt's Avatar
Oh golly gee thank you for that information. Obviously I thought the V8 and 2.0 I4 were the same thing.
You don’t have to agree with me, but being condescending is a dick move.
Old 06-01-2018, 05:00 PM   #9
cooper1965
Coopers Camaro
cooper1965's Avatar
I don't think there are any back to back intake only dyno's posted. All things equal, by design this intake will always make more power than the factory unit. The stocker heat soaks horribly on the 2.0T. Today at lunch, ambient temp was about 92F , IAT1 was showing around 96F IAT2 around 107F while cruising. Drove around about 30min or so and pulled in to get gas.
In the time it took to fuel up, IAT1 was over 135F and IAT2 150F !!.
The Injen Evolution intake is made up of layered plastic laminated in a phenol resin. So it provides a great thermal insulation for a cooler charge, and should resist some of that heat soak the stock unit exhibits. And everyone around here says they can actually "feel" the difference. Ive not seen any reason to doubt them or the design, and certainly wouldn't think it could "hurt" anything if installed properly. Perhaps someone with some data can chime in.
Old 06-01-2018, 05:32 PM   #10
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
I wasn't being condescending, sorry you felt that way. Your post specifically mentioned the SS, not the 2.0T. Their airboxes are different.
Old 06-01-2018, 07:47 PM   #11
Evil-Bee-NH
603 Camaros
Evil-Bee-NH's Avatar
Drives: 2017 NGM I4 1LT Coupe
I have the open box wrinkle black and I've prolly been the most transparent on my gains with mods and tuning as anyone on here and people will be quick to point out dynos are measuring tools and can be fudged. I doubt you will exhibit that kind of power from just their CAI however it's a good start to your bolt-on modification journey
Old 06-01-2018, 08:24 PM   #12
Start The Machine
Start The Machine's Avatar
Drives: 2016 M6 2.0T
It's all bullshit. These cars are so ECU and TCU sensitive, you are going to get zero gains from any bolt on unless you get a tune to unlock the ECU and TCU.
RS Package, HD Cooling Package, Brembo 6 Piston Front Brakes, SRP Racing Pedals, Soler Performance Throttle Controller, Dyno Tuned by Trifecta, Velossa Tech Ram Air, Mishimoto Intake, aFe Air Filter, Mishimoto Charge Pipes, ZZP 67mm Throttle Body, Trifecta T40 Stage 2 Turbo, JacFab Recirculation Valve, PTP Turbo Blanket, ZZP Catted Downpipe, Mishimoto Pro Cat-Back Quad Tip Exhaust, Mishimoto Catch Cans, Mishimoto Coolant Reservoir Tank, GM SEMA Grill, RPI Designs SS 1LE Front Fascia Extension, Ikon Motorsports 1LE Spoiler, American Authority ZL1 Side Skirts, AMPP Quad Tip Rear Valance
Start The Machine is offline   Reply With Quote
Old 06-01-2018, 10:24 PM   #13
cooper1965
Coopers Camaro
cooper1965's Avatar
Old 06-02-2018, 03:54 AM   #14
6th_gen_gino
Drives: 2016 camaro 2.0t gray
Here it goes
6th_gen_gino is offline   Reply With Quote
