Old 05-15-2018, 11:07 AM   #1
Calvear0
Drives: Currently Looking for 2019 SS
Can I get custom made mid pipes??
Hi, I’m trying to get some mid pipes for my 2016 A8 ss.
Or should I buy some from borla?
I have an mbrp axle back but I want it louder and more aggressive. Any suggestions on what I can do or should I buy a cat back system?
Calvear0 is offline   Reply With Quote
Old 05-15-2018, 11:55 AM   #2
Kise
Kise's Avatar
Drives: 16' 2SS, 06' Silverado SS
I was looking into this for my A8 2ss as well but MBRP told me the catbacks are designed for manuals only and install at your own risk (obviously with any).
id go with borla 60606 , not 100% if the mid would directly mate to the axle back but from others ive seen they sound decent.
im yet to see a system that isn't on the raspy side though.
Kise is offline   Reply With Quote
Old 05-16-2018, 03:31 PM   #3
Spartan268
Spartan268's Avatar
Drives: HB 2SS
I believe your two main options are Borla and Flowmaster. You can't go wrong with either one. The Flowmasters are cheaper than the Borla by a decent margin. The Borla can potentially include a secondary cat delete as well so if you're looking for loud it takes it a step further than the flowmaster. BUT the flowmaster is 3" piping. IMO you can't go wrong with either.
Going custom will be difficult since there's AFM modules/valve to consider as well.
Spartan268 is offline   Reply With Quote
Old 05-16-2018, 05:40 PM   #4
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
There’s also speee engineering
3” and only $180
Old 05-16-2018, 06:04 PM   #5
Calvear0
3” and only $180
Will I be able to keep the AFM valves with that system?
Old 05-16-2018, 06:05 PM   #6
Calvear0
If I go custom, could I just buy some AFM adapters and put them on?
Old 05-17-2018, 06:26 AM   #7
Booher
Booher's Avatar
Drives: 2019 zl1 6 speed
Are there any reviews out on that speed engineering kit? Seems super cheap and that makes me a little nervous.
Old 05-17-2018, 07:55 AM   #8
danhr
BAMF SS
danhr's Avatar
Not without some fabrication.... or just tune them out
I will let you know in a couple of days. Hooking up my looks 2” headers to the speed engineering x pipe to the factory npp. To me the speed engineering x pipe isn’t super cheap..... everything else is just super expensive. It’s just an x pipe...
Old 05-17-2018, 08:41 AM   #9
62nalide
62nalide's Avatar
Drives: 2013 SS
You can also have some made, I had some made years back out of aluminum. From the headers back everything was aluminum minus the mufflers.
62nalide is offline   Reply With Quote
Old 05-17-2018, 12:21 PM   #10
Booher
Booher's Avatar
I asked the company, there system is a full system that works with their headers. They haven't tried to mate their system to the stock headers,and they don't have an xpipe option
Old 05-17-2018, 04:05 PM   #11
Dubchitts
Dubchitts's Avatar
Drives: '17 Red hot 2ss, 16 Focus RS
I'm relatively happy with mine. I hooked them to my kooks LTs. I had to chop my kooks off-road connection pipes, and a little bit of the SE xpipe leads. Just take your time so you have plenty of clearance around the trans. My only real complaint is they don't bend upwards towards the tunnel like oem exhaust does. The rear tunnel brace that takes 5 bolts won't go on mine without spacers but it's not a big deal to me. I have a custom axleback so that portion wasn't an issue for me.
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC
Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance
Dubchitts is offline   Reply With Quote
Old 05-17-2018, 04:17 PM   #12
Spartan268
Spartan268's Avatar
Drives: HB 2SS
You may want to consider this thread:
https://www.camaro6.com/forums/showthread.php?t=507367
You could delete your AFM valves like this and throw in any X pipe for a far cheaper cost with no CEL. But it'll sound like ass once it kicks into V4 mode. Just throwing out options for you.
Old 05-18-2018, 01:21 PM   #13
Tech@Flowmaster
Tech@Flowmaster's Avatar
Drives: 2016 Camaro SS
We offer our Scavenger Series X-Pipe Kit that is manufactured from 409S stainless steel and includes our Active Fuel Management valves for cylinder deactivation mode when cruising at highway speeds. When paired with any of our Flowmaster Axle-back systems you'll get all the performance benefits of a full Cat-back system. Our X-Pipe kit is designed to be used in conjunction with our Axle-back systems (as well as those offered by Hurst, see below) so I cannot guarantee fitment if attempting to add to your current Axle-back. I have included 2 links below. The first is for our Flowmaster Exhaust and Intake options for your Camaro. The second link is for our sister company Hurst where there's currently some good exhaust options that are on clearance. Please feel free to PM me or give us a call at 707-544-4761 to discuss which exhaust option is best for your ride.
Flowmaster options
Hurst options
- Jason @ Hurst
Tech@Flowmaster is offline   Reply With Quote
