Old 05-09-2018, 01:37 PM   #1
tsakow
Drives: 2018 ZL1 1LE
Diff Fluid
New to the forums and my first post. I have a ZL1 1LE and taking it to the track for the first time. I am swapping the brake fluid and oil as recommended but having trouble finding the Differential Fluid that I should use. In the car groups here in Tampa, people are recommending Redline, Amsoil and Royal Purple.
I have seen AC Delco 75W-90 posted on the forums as well.
Any recommendations would be great and what weight?
tsakow is offline   Reply With Quote
Old 05-09-2018, 01:46 PM   #2
ZL1 1LE
@zle_blackwing
ZL1 1LE's Avatar
The general consensus is to stick with the OEM:
https://www.amazon.com/ACDelco-10-40.../dp/B008BZS6J8
Old 05-09-2018, 01:47 PM   #3
hawk02
Coupe Newbie
hawk02's Avatar
Really no need to look at other brands. Just stick with the recommended AC Delco gear oil.
Old 05-09-2018, 10:10 PM   #4
SJFGTO
Oh Oh it's Friday Night!
SJFGTO's Avatar
Drives: 2018 ZL1 1LE Nightfall Gray
I would go with the specific designation by GM engineers over random brand names thrown around by friends.
Four that wanna own me
Two that wanna stone me
One says she's a friend of mine...
SJFGTO is offline   Reply With Quote
Old 05-10-2018, 09:39 AM   #5
rjacobs
Drives: none
I would run Amsoil if I could figure out how much slip lock additive to put in...but nobody will publish the number and I dont feel like experimenting with a 2000+ dollar differential.
So I will be, against my desires, running the GM fluid.
Buy it at Amazon because the dealership prices are akin to rape without lube.
rjacobs is offline   Reply With Quote
Old 05-10-2018, 12:39 PM   #6
DangerZL1
Drives: 2023 Black ZL1 Auto
I know there's a pun in here somewhere.
Old 05-10-2018, 02:35 PM   #7
tsakow
Many thanks to all... it is hard when you have a lot of people giving you advise who don't own the car.
very much appreciated!
Old 05-10-2018, 04:38 PM   #8
unavailablezl1
unavailablezl1's Avatar
Drives: 2019 Silverado Z71 6.2L A10
Yes, you buy the lube to get raped without lube....
Current ride
2019 Silverado Z71 LTZ 6.2L L87 425hp A10, 4 inch BDS Lift with Fox Factory Race 2.5 Coilovers, Borla Cat back (15HP bump), BFG KM3's 33's.
Past Rides
2017 M6 Camaro ZL1 Hyper Blue
2016 M6 GT350 White with blue strips
2014 M6 Mustang GT Premium Track Pack Ruby Red
2012 M6 M3 Melbourne Red Metallic
unavailablezl1 is offline   Reply With Quote
Old 05-10-2018, 04:41 PM   #9
unavailablezl1
I was reading somewhere that there are connections that hold gear lube as well as the cooler. It said you have to pay attention to the connections, as it is not just a straight drain and fill, like on my Tacoma. One reason I have put off changing it. I need more research.
Anyone chime in....
Current ride
Past Rides
Old 05-10-2018, 04:44 PM   #10
SJFGTO
SJFGTO's Avatar
Anyone chime in....
Just drain and fill. I do it in my driveway. Easy.
Old 05-13-2018, 09:24 PM   #11
Inthepasture
Inthepasture's Avatar
Drives: 2017 Camaro 2SS
Differential Oil
I recommend you change it twice in the first 5000 miles. First around 1250 and then again at 5000. When I changed mine at 1500 it was black. Remember that you are not able to flush the differential cooling radiator nor the lines to the front end and back.
Inthepasture is offline   Reply With Quote
