Old 05-09-2018, 01:27 PM   #1
AibraLT1
Drives: 2018 SS 1LE
High Flow cats
Hey guys,
I swapped my stock cats to high flow cats and then threw an engine light p0420 and p0430 cat efficiency below threshhold. I tried the 02 extender method but even that did not work. I would like to keep the cats but not on the expense of the engine light. What do you guys think I should try.
Thanks
AibraLT1 is offline   Reply With Quote
Old 05-09-2018, 02:05 PM   #2
Nino8309
Drives: 2018 Summit white 2SS 1LE
Get HP tuners and turn off the downstream o2's. Or pay for a professional tune, they will disable it for you.
Nino8309 is offline   Reply With Quote
Old 05-09-2018, 03:40 PM   #3
AibraLT1
Drives: 2018 SS 1LE
I thought about doing that but wouldnt that void my warranty? High flow cats themselves would not void my warranty but plugging it to HP tuners would if Im not mistaken
Old 05-09-2018, 04:06 PM   #4
Atomic Ed
Drives: 2001 Audi TT, 2016 Camaro
Originally Posted by AibraLT1 View Post
Hey guys,
Thanks
So where did you get the high flow cats?
Google Big Daddy's O2 and take a look at what he has to offer in lieu of the regular O2 extenders.
Atomic Ed is offline   Reply With Quote
Old 05-10-2018, 10:50 AM   #5
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
I keep waiting for Solo Performance- https://solo-performance.com/
to come out with a bolt on high flow.
Exceptional quality and zero CEL's in my experience. Also no raw gas smell and good performance boost. Of course, you get what you pay for, so they ain't cheap. But definitely worth it.
They've got the LS3 covered but no LT1 system yet.
How 'bout it Solo?
Ventmaster is offline   Reply With Quote
Old 05-10-2018, 04:43 PM   #6
ssmike
BL1ZZRD
ssmike's Avatar
Drives: '16 Camaro 2SS, '20 Equinox Redline
How 'bout it Solo?
Those are Solo's he's beta testing. Hopefully Solo will have an offering that doesn't throw codes like they had with the 5th gen. I had them on my 5th gen as well as the Mach-X catback. Quality stuff and amazing sound. They're also offering a new axle back setup for NPP equipped cars. Basically a muffler delete with j-pipes.
ssmike is offline   Reply With Quote
Old 07-25-2018, 12:36 PM   #7
ssmike
BL1ZZRD
ssmike's Avatar
OP any progress?
Old 08-08-2018, 05:03 AM   #8
BlueCamaro6
BlueCamaro6's Avatar
Drives: 2018 Camaro 2SS, Hyper Blue
I installed kooks high flow cats and have no issues with throwing codes....
2018 2SS, A8, NAV, NPP, MRC, Sunroof, Hyperblue, LT4 S/C, LT4 Fuel System, RotoFab CAI, Headers, HiFlo Cats
2016 2SS, A8, NAV, NPP, MRC, Sunroof, Hyperblue (GM buyback)
1999 Trans Am Firehawk, M6, headers, no-cats, slp exhaust, hot cam, intake, 3:73 gears. Red/Blk
BlueCamaro6 is offline   Reply With Quote
Old 08-08-2018, 07:30 AM   #9
ssmike
BL1ZZRD
ssmike's Avatar
You have headers, OP does not. He’s testing the Solo Performance high flows that replace the stock cats and retaining the stock manifolds. Last I spoke with him they were working on a new design. They nailed it with the 5th gen but these LT1’s are a different bear!
Old 08-08-2018, 08:53 PM   #10
Fraxum
Fraxum's Avatar
yes we already have shorties so LTs do not add much and are a PIA to install. And they are a very high $ per HP.
High flow cats make alot of sense on a mild to mid build also to hold more heat on a FI build. If well built they will be expensive.
Old 08-08-2018, 09:06 PM   #11
ssmike
BL1ZZRD
ssmike's Avatar
I think the ones for the 5th gen were right around $650. I’m really hoping Solo comes through with a working solution! By the way my 5th gen Camaro was named Big Red too!
Old 08-08-2018, 11:08 PM   #12
Drsagacity
Drsagacity's Avatar
My Kooks high flow cats are going in the garage as spare parts just in case I run into an emissions test problem...otherwise No cats for me.
776whp/745wtq (12psi)
2018 Corvette Z06 vert- Black
To be tuned by JRE Racing
TBD performance
Old 08-09-2018, 12:47 AM   #13
solobaric
solobaric's Avatar
Drives: 2002 Camaro SS
Wonder where they're at in the production of 6th gen systems.
2017 1SS Hyper Blue M6
2001 Ford Lightning
solobaric is offline   Reply With Quote
Old 08-30-2018, 11:01 AM   #14
ssmike
BL1ZZRD
ssmike's Avatar
I just talked to Jeff at Solo and they are working on a redesign to a larger size unit. They can't seem to get the CEL's to go away.
