Old 05-02-2018, 09:47 PM   #1
Alain
Alain's Avatar
What jack pads are you guys using on your Zl1
Zl1 addons has a few of them but I’m not sure if they will work for the 1LE.
2018 ZL1 1LE/Red hot
Old 05-02-2018, 10:01 PM   #2
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
I looked at all the jack pads, lift points, you name it for these. Couldn't stomach $150-$300 for it. I took a Forum members advice and bought the following setup and epoxied them together...
These quantity 4: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
And one of these: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
With 4 Jack/Lift pads like that, you'll be able to put it on jack stands or on a lift safely.
Old 05-02-2018, 10:06 PM   #3
ICTsccaCamaro
Drives: 2018 ZL1 1LE
ZL1 addons bolt on style at each corner, work great with a floor jack or at work on a lift
ICTsccaCamaro is offline   Reply With Quote
Old 05-02-2018, 10:09 PM   #4
SE46
SE46's Avatar
Hockey pucks
ZL11LE; 997C2S; E39M5; SE46; E30Cab; E46XiT
SE46 is offline   Reply With Quote
Old 05-02-2018, 10:20 PM   #5
Alain
Alain's Avatar
You came through again !! Thank you sir. I’m glad I asked. I actually already have that metal pinch weld jacking pad as well as the hockey puck. I used them for jacking my Hellcat. Thank you for sharing the idea.
The zl1 addon are good but I’m not spending dough on them unless I have to.
Old 05-02-2018, 10:39 PM   #6
speedraider
speedraider's Avatar
Drives: 2016 Z06, 2017 ZL1
Originally Posted by SE46 View Post
Hockey pucks
yup
speedraider is offline   Reply With Quote
Old 05-02-2018, 11:08 PM   #7
grampa_ss
grampa_ss's Avatar
What am I missing? Why is this better that the ZL1addons lift points? It's basically the same price as your setup.
Old 05-02-2018, 11:26 PM   #8
Grumpy1
Grumpy1's Avatar
For me, the main reason for the lift pads is that they are always attached to the car.
I'm sure you've heard the stories of damage done by lifting at the wrong locations or using the wrong equipment.
This way I don't have to worry (too much) about a service department if I need to bring it somewhere not having the right lift or jack pads.
Grumpy1 is offline   Reply With Quote
Old 05-02-2018, 11:30 PM   #9
unavailablezl1
unavailablezl1's Avatar
Drives: 2019 Silverado Z71 6.2L A10
I bought these and they are $80 for a 4-pack
https://zl1addons.com/collections/ja...-on-for-camaro
Current ride
2019 Silverado Z71 LTZ 6.2L L87 425hp A10, 4 inch BDS Lift with Fox Factory Race 2.5 Coilovers, Borla Cat back (15HP bump), BFG KM3's 33's.
Past Rides
2017 M6 Camaro ZL1 Hyper Blue
2016 M6 GT350 White with blue strips
2014 M6 Mustang GT Premium Track Pack Ruby Red
2012 M6 M3 Melbourne Red Metallic
unavailablezl1 is offline   Reply With Quote
Old 05-02-2018, 11:37 PM   #10
full*throttle*therapy
Drives: '18 RH ZL1 1LE
What makes you believe that they won't work on a ZL1 1LE? Please provide sources if you can? (I just had some delivered and was under the impression they would work fine.)
full*throttle*therapy is offline   Reply With Quote
Old 05-02-2018, 11:49 PM   #11
Can'tHave2MuchHP
Drives: Fast
I wanted the mag pads not the lift points. I prefer the big puck to put my jack/stands or lift points at. I don’t like the lift points by ZL1Addons. Had them on several customers car and they’re slippery as hell.
Quantity 4 of ZL1Addons mag pads was like $210 or something. And if you bought the 4 lift points, if you ever want all four wheels off the ground and aren’t using a lift, you’ll need a mag pad for your jack (the lift points would only cover the jack stands, need a spot to lift from. Diff only handles the rear two) anyway so $80 + $56 or so at minimum.
Old 05-03-2018, 12:15 AM   #12
rjacobs
Drives: none
I have 6 spare hockey pucks since I ordered a 12 pack I think.
If anybody wants them to make the same setup that can'thave2muchhp suggests, cover the small flat rate box they will fit in and they are yours.
I bought 5 of the mag adapters, 1 for each corner plus 1 for my jack since I jack from the middle jacking point.
rjacobs is offline   Reply With Quote
Old 05-03-2018, 08:34 AM   #13
unavailablezl1
You just gave me an idea of getting some hockey pucks and putting a groove in it to the lift points will stay right in. I have two floors jacks so I can lift both sides fairly much at the same time.
Current ride
Past Rides
Old 05-03-2018, 08:55 AM   #14
grampa_ss
grampa_ss's Avatar
Gothcha, thx
