Old 04-29-2018, 07:26 PM   #1
Goertz
Goertz's Avatar
Drives: 2016 1SS Auto
G1 Intake Manifold Coming
been commissioned to do a intake for the 4cly ats and being that the camaro is same engine guess we'll have a 4 banger manifold coming soon
will be setup ready for port injection for those looking for more hp than the direct injection can supply
For controlling 4 additional injectors SplitSec Makes a box that works great.
Give it power, ground, a rpm signal (ground off a coil wire) and then run it a boost reference (it has built in map sensors) and you are set with with additional fueling!
Goertz is offline   Reply With Quote
Old 04-29-2018, 07:41 PM   #2
cooper1965
Coopers Camaro
cooper1965's Avatar
Drives: 18 Flex Fuel LTG
This is some of the best news I have read in a long time !!
Adding port injection could also eliminate any need for a catch can system too. ($400.00ish)
Any rough guesstimate on production date?
Flex Fuel tuned by me using HPT-:-
---My Build Thread---
-----My IG PAGe-----
Old 04-29-2018, 08:17 PM   #3
6th_gen_gino
Drives: 2016 camaro 2.0t gray
This is really good news, I know my next purchase
6th_gen_gino is offline   Reply With Quote
Old 04-29-2018, 08:21 PM   #4
Goertz
Goertz's Avatar
Coming really soon as in within next 4-5 weeks
have to do one for local shop over here
will not be setup for dinky oem tb however we could if someone really wants.
Will be setup for the gen 6 camaro ss oem tb which should be a near plug and play setup
Old 04-29-2018, 08:27 PM   #5
Goertz
Goertz's Avatar
https://splitsec.com/product/aic2-p-...pressure-mode/
for additional injector controlling
you would still need injectors, rails (we will be making), lines, regulator, etc.
Old 04-29-2018, 08:33 PM   #6
Evil-Bee-NH
603 Camaros
Evil-Bee-NH's Avatar
Drives: 2017 NGM I4 1LT Coupe
Old 04-29-2018, 10:05 PM   #7
Goertz
Goertz's Avatar
can do it for the dinky baby tb if yall really want....
more for setups in excess of 500hp
Old 04-29-2018, 10:26 PM   #8
cooper1965
Coopers Camaro
cooper1965's Avatar
Big difference between 70ish? mm Current LTG T/B options and, this.
I would assume this intake would accept any T/B the SS LT1 cars will accept,
Like the Tony Mamo 103mm ?
I would be curios what a full E85 , upgraded turbo , forged internal would put down....I bet Shocking !!
Old 04-29-2018, 10:27 PM   #9
Evil-Bee-NH
603 Camaros
I'm not sure we can use the SS TB i think biggest we can go is 72mm and that's with an adapter.
Old 04-29-2018, 10:46 PM   #10
Goertz
Goertz's Avatar
I would be putting the oem ss tb on it not doing an adapter plate could go bigger or smaller, my stuff is custom per order
Old 04-29-2018, 11:04 PM   #11
cooper1965
Coopers Camaro
cooper1965's Avatar
Any ballpark pricing?
Old 04-30-2018, 01:30 PM   #12
Jason@JacFab
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
Boy IDK about using the SS throttle body, that's 87mm iirc. Thats awful big. Might be better off to use the 72mm LFX or LGX throttle body.
Also, I notice your runners look very short. This will most likely be geared towards top end power, with very little love for the low end torque...
I like what you're doing here. But I'm questioning a lot of the ideas. Whoever is getting the first one I'm guessing is going to be spinning a big ass borg warner, one off custom build.
Old 05-01-2018, 02:19 PM   #13
Corner carver
Corner carver's Avatar
Drives: 2017 Camaro 2.0T RS
Would love to see something similar to this with a built in water to air heat exchanger... For anyone reading *hint, hint*
As Delivered: 2017 Mosaic Black 1LT RS 2.0T | M6 | HD brake and cooling | Bose & 8"screen | Front lip extension | Blade spolier | Black bowties | Painted splash guards
Installed Mods: 25% Window tint | Headlight, side marker and third brake light Phastek tint kit | GM black taillights with Gen5diy LED harness and bulbs | LED license plate bulbs | Gorilla lug nuts, black | GM 'performance' center caps | RS and sheild badges removed
Old 05-08-2018, 11:41 AM   #14
DatsunBob
Drives: ATS 2.0t Rwd Performance
Will CFD flow analysis be done? Any chance of getting longer runners? These engines and drivetrains are designed to maximize use of the early available torque. Lose that trait it will negatively effect the cars performance.
DatsunBob is offline   Reply With Quote
