Old 04-24-2018, 06:30 AM   #1
Rayfield
Rayfield's Avatar
Drives: 2018 Camaro 2SS
Small Issue at the Gas Pump
Apologies if this has been covered, I did search before posting, but maybe I searched with the wrong terms. When I go to fill this car ('18 2SS) at my local filling station, using the capless setup as directed in the manual, the sensor in the nozzle seems to shut off well before the tank is actually full. If it's obvious that it's not there yet, I'll start it back up, of course, but as it gets closer, I don't want to do that. Any tips on how to make sure you get a full tank of gas?
Or am I the only one with the issue? 36 years of driving, and I can't pump gas..
Rayfield is offline   Reply With Quote
Old 04-24-2018, 06:42 AM   #2
mdhopt36
Drives: '17- 1ag37 V6 traded, for 1SS 2018!
Huh.
BTW, welcome!
I have so far (3 weeks since purchase) haven't had the same issue.
Every time it pops off, the gauge is right on the full mark. As I fill it, I can hear a slight change as if the tank is close to being full up.
Would it be the nozzle? Change gas stations/pumps?
mdhopt36 is offline   Reply With Quote
Old 04-24-2018, 07:20 AM   #3
Nsxmatt
Drives: 2017 Camaro
There needs to be some empty space in the tank and filler for the EVAP system to work properly. When it kicks off, stop filling the tank. Do not keep topping it off. I'm pretty sure the manual tells you this also.
Nsxmatt is offline   Reply With Quote
Old 04-24-2018, 07:27 AM   #4
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Turn the pump upside down.....or....find a new station....not all pumps have the same trigger/stop
Old 04-24-2018, 07:45 AM   #5
Rayfield
Rayfield's Avatar
If I don't restart it after it quits the first time, I'll get 1/3 of a tank of gas, so clearly that's not the issue.
I believe I've had the phenomenon happen at 2 different stations, nearby..my first thought was that it might be a defective sensor at that particular pump...but seems unlikely when it keeps happening at different places.
Old 04-24-2018, 07:48 AM   #6
Jim50thSS
Drives: 50th SS Convertible
I have had similar issues at two different stations. It's not that it goes off early, just before its full, it goes off almost as soon as I start pumping when on empty. I just keep at it and I don't do a complete fill up.
Jim50thSS is offline   Reply With Quote
Old 04-24-2018, 08:14 AM   #7
Cgocifer
Cgocifer's Avatar
Drives: 2018 1SS 1LE, 2015 RAM Ecodiesel
Shove it in there all the way!
Cgocifer is offline   Reply With Quote
Old 04-24-2018, 08:58 AM   #8
Rayfield
Rayfield's Avatar
That's what she said!
Seriously though, maybe I need to push the nozzle in there with more authority? I'll give it a try..
Old 04-24-2018, 09:03 AM   #9
hotlap
hotlap's Avatar
Originally Posted by mdhopt36 View Post
Huh.
BTW, welcome!
Likewise. I always run mine all the way down and it typically pops off at ~18 gallons.
One time I pushed it so I could get to the station near my house and ended up getting 19 gallons into it. Pretty amazing since it's rates capacity is 19 gallons so I took a picture. I couldn't have gone any further
Ronald Reagan -
Old 04-24-2018, 09:13 AM   #10
Evil-Bee-NH
603 Camaros
Evil-Bee-NH's Avatar
Drives: 2017 NGM I4 1LT Coupe
There's a few gas stations in my area where this happens jronically my old neighbor worked for a gas pump service company and i asked him about it he said someone used parts from pre-2008 on the pump to repair the nozzle. They aren't supposed to anymore but it's not illelgal and cheaper then ordering the part new. He said it's fairly common at franchise stations outside of small corporations like shell and conoco and exxonmobil 100% branded stations. Then again this is the same guy who put gasoline into his diesel tractor this winter...
Old 04-24-2018, 09:13 AM   #11
camaromike77
camaromike77's Avatar
Drives: S O L D
Ha!! That is pretty full!!
From the GM Website:
Fuel Tank Capacity
72 litres / 19 gallons
Club F1FTY
Old 04-24-2018, 09:18 AM   #12
torqueaddict
Drives: Tesla M3 LR-AWD [Former 1SS owner]
i've had this happen in different cars. I think it's the station pump more than the car. Some are senstive and you have to play around with the nozzle position to get a steady uninterrupted stream.
I haven't had it happen on the Camaro yet. I also let my gas go all the way down before refilling which helps if this ever does occur.
torqueaddict is offline   Reply With Quote
Old 04-24-2018, 09:49 AM   #13
Wolvie70
Wolvie70's Avatar
Drives: 2016 2SS, Summit White, A8, NPP
Kramer says you had plenty more.
Wolvie70 is offline   Reply With Quote
Old 04-24-2018, 10:13 AM   #14
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
Perhaps use the slower setting on the handle?
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
zx9rmal is offline   Reply With Quote
