![]() Drives: 2018 Camaro 2SS A8 Convertible Join Date: Sep 2017
Another Tony Mamo TB Convert
After reading so many positive posts on here about how great this mod was, I knew it would only be a matter of time before I pulled the trigger on a Tony Mamo ported throttle body!
The ordering process and comms from Tony was second to none and I received the TB (here in the U.K.) beautifully packed and in good time. Installation was a breeze, 15 minutes tops and that included changing the air filter to a Green Filter at the same time. My car only had around 750 miles when I did the install but that is now up to just over a thousand and I have to say the improvement is very noticeable. Certainly the throttle response is a lot more linear and driveability has improved, particularly on pull away and light throttle. The most noticeable difference however is when you come off the throttle when approaching a junction for instance and then go back on it. The pick up is instant with no lag whatsoever. It really feels like the pedal is connected to the TB by a cable rather than drive by wire. I'm still in my break in period so I haven't gone WOT yet but so far I am very happy with this mod. If you are on the fence about this then my advice is go for it. Coupled with the Green Filter it's the best bang for your buck out there (IMO) |
![]() Drives: 2017 SS Hyper Blue Join Date: Jan 2018
+1 on the tony tb. Couldn’t be happier with mine. Very noticeable difference in throttle respond seems like it’s right there when you hit it. Another happy customer.
![]() Drives: 2017 Camaro 2LT RS V6/A8 Join Date: Apr 2016
Guys, please excuse my going slightly off topic but related question for you...
I received my Mamo ported TB and am looking forward to installing it soon. I know sometimes when doing work on our cars it's a good idea as a 1st step in a given project to disconnect the battery (and reconnect when done, obviously). Do I need to/do you recommend that I do so for this project? Did you, when you did your installation? Thanks!!
No need to disconnect the battery nope. Enjoy.
![]() Drives: 2018 Hyper Blue 1SS 1LE Join Date: Sep 2014
You guys just popping the new one on and that's it? No tune or supporting parts other than a better air filter?
![]() Drives: 2010 Camaro 1SS Join Date: Mar 2015
Wouldn't disconnecting the battery clear out the memory allowing the ecm to relearn the driving conditions with the new TB? Or is there not enough difference? Sorry if this is a noob question.
Mod List: Perma-Grin, Darkened tail lights, ZL1 3rd break light, JW Motorsports LED side markers, American Authorities Window Louver, American Authority ZL1 bumper,
11/30/17 | Club F1FTY |
#7 |
![]() Drives: 2017 2SS Convertible Join Date: Jan 2018
Just ordered one today, excited to get it on.
#8 |
I didn't disconnect the battery. I would guesstimate the ECU adjusted to the changes pretty quickly-within the first 50 miles.
Forgot to mention in my OP, my car is a 2018 2SS (Euro spec) A8. |
#9 |
SABIO
Just be careful with the wiring connector on the T/B
I broke mine. It got fixed but wasn't easy to get it done.
#10 | ||
Thanks for all the feedback guys, appreciate it!
#11 |
Opus13
Drives: 2017 Camaro 1SS, Black Join Date: Jul 2017
I didn't disconnect the battery when I did the install, and mine works great. I agree with everything the OP stated.
"My entire life in one sentence:
It didn't go as hoped, but that's okay" Opus ie. Berkeley Breathed. |
#12 |
![]() ![]() Drives: 2016 Camaro Convertible 2SS Join Date: Jan 2016
Installed mine last weekend (TMTB) just before it started to rain. I only put a 30 +/- miles on. Did not blow my hair back. Seems like a small bang for the buck!. With WOT the car still seemed to have slight hesitation. Maybe that is the split second it takes to downshift? Anyway, when the weather clears i will give it another try. I will say that the Range AFM disabler was a much bigger bang for the buck. It worked perfectly. I purchased the on/off switch and tested it out also. It is all good and very nice to have control over that stupid AFM.
SWITCH (https://www.amazon.com/Tonsiki-Femal...isabler+switch)
2SS Convertible, MRC, NPP, A8, Garnet Red, Blk Bowties
GM CAI, Ported TB, Kooks Headers, E85 Last edited by Driski; 04-28-2018 at 08:17 AM. |
#13 |
![]() Drives: 2016 2SS M6 Join Date: Feb 2011
On an M6, With the TMPTB, you will notice the difference the most in track mode, there used to be like a distinct On/off throttle point in track mode, dangerous to drive with in regular traffic. With the throttle body, the power is evened out and as they say-more linear. In sport mode, that stumble stall point (M6 when creeping along in traffic) with the clutch disappears. Makes the car more responsive-I love it.
2016 SS M6
#14 |
Drives: 6 on the Flo' Super Sport Join Date: Jan 2011
Tony who??
