Old 04-23-2018, 03:53 PM   #1
Mrfixxit7
Mrfixxit7's Avatar
Drives: FIFTY 2SS Callaway
Size of the rear axle bolt?
Guys I have been looking around and could not find a definitive answer for the size fo the rear axle nut I have seen 32mm and 36mm. Does anyone know waht size it is? I am not talking about the lugnuts, I am talking about the nut required to remove the rear hub.
Thanks
Mrfixxit7 is offline   Reply With Quote
Old 04-23-2018, 04:47 PM   #2
PolynesianPowerhouse
Big Samoan ina little car
PolynesianPowerhouse's Avatar
Drives: 2016 camaro
Its a 35 or 36... i wanna say 35. I just changed my driver side axle yesterday due to a broken band and torn boot.
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt
"Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant
PolynesianPowerhouse is offline   Reply With Quote
Old 04-20-2019, 05:18 PM   #3
Dysan911
Dysan911's Avatar
Drives: 2017 50th Anniversary 2SS
Did we ever figure out this one? I had my center caps off and notice the axle nut didn't quite look aligned with the blue paint mark so I went to see if I had a big enough socket . Ha!. Nothing even close. So was this a 35 or 36?
Dysan911 is offline   Reply With Quote
Old 04-22-2019, 10:30 AM   #4
HyperspaceTurd
HyperspaceTurd's Avatar
Drives: 17 1SS 6MT, 09 Tacoma TRD Sport
36 mm
I bought a socket just for this purpose as well.
HyperspaceTurd is offline   Reply With Quote
Old 04-22-2019, 11:19 AM   #5
Dysan911
Dysan911's Avatar
Originally Posted by HyperspaceTurd View Post
36 mm
Thank you very much!
Old 02-18-2020, 11:02 PM   #6
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
mine are 35mm or 1 3/8". 36 is too loose
Old 02-19-2020, 06:23 AM   #7
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
36mm (nut PN 11612295)
RUQWIKR is offline   Reply With Quote
Old 02-19-2020, 01:56 PM   #8
JCunningham
Drives: 2017 2SS M6
mine are the early style
