Old 04-19-2018, 10:16 PM   #1
JPAT
Drives: 2018 Camaro V6 2LT RS M6
Manual transmission question
Is it OK to leave from a complete stop in second gear instead of first?
I was just was just wondering if damage to the transmission could result when doing it regularly.
Thanks.
JPAT is offline   Reply With Quote
Old 04-19-2018, 10:50 PM   #2
Camaro_QC
Camaro_QC's Avatar
Drives: 08 Tiburon GS, 2018 Camaro 2.0T
It will wear down the clutch faster cause you will make it slip more.
Make a complete stop, and start from first gear. Less wear on the clutch, zero chance to get pulled cause you didn't do a full stop, Best for both.
Camaro_QC is offline   Reply With Quote
Old 04-20-2018, 02:47 PM   #3
red_johnny
red_johnny's Avatar
Drives: 2016 Gray 2SS M6
Thanks.
Should be fine. If its to avoid the stupid skip shift thing then just get the eliminator, they are only 15 bucks.
red_johnny is offline   Reply With Quote
Old 04-20-2018, 03:06 PM   #4
dotfiles
@SS_1LE
Drives: 2017 SS 1LE
Start from 1st. Starting from second results in more clutch slip and will wear your clutch faster. It should be fine on occasion but I would avoid doing it regularly
17' Camaro SS 1LE | PDR | Summit White
Borla S-Type Axleback | Mishimoto Catch Can | LED Sidemarkers | ZL1addons DRGs | Michelin MPS4S
dotfiles is offline   Reply With Quote
Old 04-24-2018, 01:01 PM   #5
4door65guy
Drives: 2016 2SS MAG/NPP
If it helps I usually go from first to 3rd when im going easy it wont lug the engine like going into 4th gear.
4door65guy is offline   Reply With Quote
Old 04-24-2018, 01:17 PM   #6
dotfiles
@SS_1LE
Drives: 2017 SS 1LE
I do the same if skip shift is activated. First -> third doesn't result in almost idle rpms like the 1st -> 4th skip shift does.
Old 04-24-2018, 04:24 PM   #7
DirectTo
DirectTo's Avatar
Drives: Sold!
No skip shift in the V6 or I4 models.
I use 2nd to start on steeper downhills, but I can’t imagine a lot of that in Florida.
DirectTo is offline   Reply With Quote
