Old 04-19-2018, 12:25 AM   #1
cryssm
cryssm's Avatar
Drives: Car
Internals of Resonator
I searched this forum and couldn't find a solid answer -- do we yet know what is inside the rectangular resonator on the V6 Camaro? Is there an H or X crossover? I'm soon having some exhaust work done, and would hate to have it removed for a crossover, if one is already present inside. Thank you!
the one and only
cryssm is offline   Reply With Quote
Old 04-19-2018, 01:35 AM   #2
dgriff14
waddupdgriff
dgriff14's Avatar
Drives: Supercharged 2016 2LT RS
IIRC I believe @PolynesianPowerhouse was recently talking about cutting one open
2016 Chevrolet Camaro 2LT RS
• Edelbrock E-Force Stage 1 Supercharger • Custom tune by Overkill Motorsports • AFE Momentum GT Pro Dry Cold Air Intake • MBRP SS Cat Back Exhaust • iROC-z Wheels • Nitto NT555 G2 Tires (275 fronts, 305 rears)
dgriff14 is offline   Reply With Quote
Old 04-19-2018, 07:27 AM   #3
Big Samoan ina little car
PolynesianPowerhouse's Avatar
Drives: 2016 camaro
Was gonna cut it last week but when i leave work ill upload a pic as its still in my trunk... that rear resonator we have... two perforated tubes and straight through. Theres no x or h inside at all.
Also to note theres like a lil nipple area in the middle. Its for water evac. It can start to rust and eventually crack. Just something to keep an eye on..
Will post the pic hopefully sometime before 2pm today. When i redid my exhaust last week i added in a legit x pipe and v band clamps.
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt
"Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant
PolynesianPowerhouse is offline   Reply With Quote
Old 04-19-2018, 01:15 PM   #4
WhiteLightening
WhiteLightening's Avatar
Drives: 2016 Camaro V6 RS, 2005 Mustang GT
What's the difference between a resonated x pipe and a non resonated x pipe? I have an x pipe and my exhuast restyled some now against something I'm not sure what or where it's rattling at around 2k rpms. Could the x pipe need more reinforcement around that area, since the resonator was removed? Did the resonator have supports that were removed along with it?
Sorry to hijack the post
2016 Camaro RS V6, Custom Leather interior, Flowmaster American Thunder exhaust, x pipe
WhiteLightening is offline   Reply With Quote
Old 04-19-2018, 02:37 PM   #5
Drives: 2016 camaro
What is a resonator? Its a small muffler, right?
If there's a resonated x pipe... its basically an x pipe within a muffler or an x pipe that functions as a muffler as well. Google magnaflow 11836.
Rattles can come from crappy welds breaking, vibrating components touching other components like a heat sheild or part of the chassis.
If you have vibrations you need to get under the car while its running and start pinpointing the noise. If whoever installed it knows how to weld worth anything why would need to reinforce any part of your exhaust?
Old 04-19-2018, 02:42 PM   #6
Drives: 2016 camaro
First pic is the right side, then the second is a close shot of the front of the resonator, third shot is the left side straight through. Last shot is the nipple piece in the center of the resonator thats prone to cracking.
Old 04-19-2018, 10:02 PM   #7
cryssm
cryssm's Avatar
Drives: Car
Perfect. Thank you much! Looks as if I'll be having an x-pipe installed in its place.
the one and only
Old 04-20-2018, 02:33 AM   #8
dgriff14
waddupdgriff
dgriff14's Avatar
Thanks for the pics and your contributions as always, my man! And is it safe to assume you installed the Magnaflow 11386 you mentioned?
Old 04-20-2018, 07:56 AM   #9
Drives: 2016 camaro
Notta prob. Tryin to help out
I actually didn't do the 11386 on the 2016. On the 2013 i did. On the 2016 i just used an x pipe. http://www.camaro6.com/forums/showpo...7&postcount=31
Old 04-20-2018, 08:02 AM   #10
Camarolover85
Drives: 2019 Dodge Challenger Scat Pack
Interestin, I just did an axle back and nothing else. This is the 2nd resonator you guys are replacing?
Camarolover85 is offline   Reply With Quote
Old 04-20-2018, 08:10 AM   #11
Drives: 2016 camaro
Theres only one resonator from what ive seen.
Old 04-21-2018, 12:21 PM   #12
Camarolover85
Sorry, I wasn’t thinking. I was thinking secondary cats when I posted that. Replacing the straight through should create a lower, quieter tone, no?
Old 04-22-2018, 09:15 AM   #13
Drives: 2016 camaro
all depends on what you replace it with... and what you have at the rear already. just adding straight pipe could easily allow more sound and noise to get to the end (sound is refined tones, noise is rasp and all the stuff you don't want).
x pipe may quiet it down "some"... but from the engine masters test, the sound difference between x and h was merely like 1-2 decibels or less. and that was on pretty powerful engines in comparison. 129 was straight pipe, 128 was H pipe, and 127 was x pipe... nothing significant. (ep 22 if interested)
stuffing a resonated one would be ideal if you can find the space.
Old 04-22-2018, 10:51 AM   #14
Camarolover85
I’ve got the magnaflow American thunders as an axle back. I guess I would replace it with the X-pipe, non resonated. I don’t like what you posted about it cracking but if it doesn’t change anything, id rather just wait till I have an issue. I can’t imaine the difference would be night and day. I did straight through on my 2013 and I felt it to be raspy at high RPM’s even with an axle back.
