Coopers Camaro
Drives: 18 Flex Fuel LTG Join Date: Nov 2016
Clear tail lights
Anyone offer these and a clear third brake light? Also would I need a conversion harness if I have the base model tail lamps?
#2 | |
https://www.phastekperformance.com/2...tail-lamps.htm |
Coopers Camaro
I could have swore I saw someone advertising new clear tail lamps... Maybe Im loosing my mind lol.
![]() Drives: 2016 Camaro 1LT V6 Join Date: Mar 2018
The only other clear tail lights I know of are the strange looking Lamborghini Aventador-like tail lights. And yes, as StPeteHyper2.0 said, you will need the gen5diy Non RS - RS tail light harness.
http://www.gen5diy.com/Gen6-Camaro-N...light-Harness/ |
Coopers Camaro
Ok. Thanks for the tips and link on the harness guys!! Appreciated!
#7 |
Good questions and it will probably help others as well.
#8 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1SS, 2010 Camaro SS Join Date: Apr 2012
You do not need the harness for the tail lights to work. The harness is for the reverse LED option. The tail lights them selves are plug and plug for all 2016-2018 Camaros. Shoot us a email or PM if you have any questions. sales@phastekperformance.com GM Dark Tail Lights |
#9 | |
Coopers Camaro
#10 |
People have reported hyperflashing when converting from base halogen tail lights to the LED dark tail lights. Unless the ones Phastek is selling have built in resistors, I don't see how they wouldn't need the resistor harness. I would love to be enlightened, though (no pun intended lol).
#11 | ||
Pretty sure it is need for the LED blinkers also not just reverse LED. My harness has 2 resistors. If not you will have the hyperflash blinkers. If you have the base model non-RS, a harness will be needed, unless like peyton says if they are built in, which I have not seen yet. If you don't care to have the hyperflash blinkers, then you don't necessarily need the harness for the taillights to actually work. |
#12 |
Coopers Camaro
Thanks again guys!!! Good explanation StPeteHyper2.0. Hyper flashing would not be desirable for me. I purposely got no RS package on my car, as I knew from the beginning I wanted to sway out grill and add blade spoiler. Very helpful information!
#13 | |
![]() Drives: Sold Join Date: Sep 2016
https://www.amazon.com/4Pcs-Aaron-6o.../dp/B00L4V9ECY |
#14 | |
This harness solves both problems, it does the non-RS to RS conversion and allows for LED reverse bulbs: http://www.gen5diy.com/Chevrolet/Cam...llight-Harness. It has 3 resistors, 1-1 for each LED blinker and 1 for the reverse LED bulbs (only one is needed because these are wired in series, and the resistor in the harness is sufficient to prevent any residual glow when inactive). I tested it, looks professional, it's plug and play, easy to tuck away and uninstall if need be, obviates the need for splicing and driving screws into the body or using heat resistant dual sided tape or some similar contraption. Strongly recommended.
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle Terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 Last edited by arpad_m; 04-05-2018 at 11:47 PM. Reason: typos |
