Old 03-19-2018, 08:44 AM   #1
thomaswatk
Drives: red ss convertible
open exhaust pull #51 fuse doesn't work "full time"
I love the open exhaust sound so I pulled fuse #51 as suggested. On my '16SS it isn't open "full time". If I am cruising at a given speed ( doesn't matter what speed) and not accelerating at least slightly, the exhaust closes. When I give it a little gas I hear a slight "pop" and they are open as long as I am on the gas a little. They seem to close anytime I am not accelerating a little bit (or a lot) so, for me, they aren't open "full time". They are never open when decelerating. It is much better than Is there a way to keep them open all the time ?
thomaswatk is offline   Reply With Quote
Old 03-19-2018, 09:06 AM   #2
NobleSS
NobleSS's Avatar
Drives: 17 Camaro 2SS 50th Anniversary Conv
Sounds like you are hearing the AFM valves opening and closing while its going from V8 to V4 and back to V8 mode. By pulling fuse #51 there is no power to the NPP valves, so they can't work.
2017 2SS 50th Anniversary Convertible,A8,MRC,NPP,NAV,Black Bowties
NobleSS is offline   Reply With Quote
Old 03-19-2018, 09:25 AM   #3
driven2exceSS
driven2exceSS's Avatar
Drives: 2016 2SS BLK A8 Vert
+1 agreed. Hate the AFM's... try the "Range Device", preferably the 8.6, or the current version available to date. Other option is forego the warranty and get a tune to eliminate this non-sense to stay in V8.
driven2exceSS is offline   Reply With Quote
Old 03-19-2018, 09:31 AM   #4
solarstingray
Drives: 2014 c7 corvette and 2017 camaro ss
mine works fine with the fuse pulled, always open,
and I just put in the afm range device it works flawless so far, no more afm
solarstingray is offline   Reply With Quote
Old 03-19-2018, 09:55 AM   #5
init4fun
Drives: 2017 50th Anniversary
Like other have said. AFM is what you're hearing.
Annoying as all hell.
init4fun is offline   Reply With Quote
Old 03-19-2018, 10:48 AM   #6
rap47
Drives: 2017 Camaro SS 50th
I have the fuse pulled and the Range 8.6 version installed. Exhaust open all the time and V-8 all the time.
rap47 is offline   Reply With Quote
Old 03-19-2018, 12:01 PM   #7
aronSlusa
aronSlusa's Avatar
Drives: '16 2SS
I have this same issue, and pulling the fuse did not keep the valve (before the exhaust) open all the time; still closes at cruising speed.
The tuning shop my cars sitting at right now didn't understand what valve I wanted to make sure was tuned out/ off as they went though and tuned it.
aronSlusa is offline   Reply With Quote
Old 03-19-2018, 12:43 PM   #8
awpti
awpti's Avatar
Drives: 2017 1SS Camaro; 2016 4Runner
Range device sucks -- drops a CEL after 1-2 days of use. Had multiple firmware flashes, now I just have 100 bucks of plastic in my glove compartment.
awpti is offline   Reply With Quote
Old 03-19-2018, 12:57 PM   #9
solarstingray
is it the newest version of It ?
Old 03-19-2018, 01:39 PM   #10
thomaswatk
what is a range device and where do you get it ?
Old 03-19-2018, 01:49 PM   #11
bdavies11
Try driving in manual mode (assuming you have the A8) and see if you notice a difference. Like others have said, if you have the correct fuse pulled, it is probably the AFM kicking in and out, not the exhaust valves. It should almost never go to V4 mode when driving in manual mode, even when cruising with light throttle.
I drive in manual mode almost all the time with the fuse pulled and it may kick into V4 mode when I first start the car up and am driving carefully out of my neighborhood. Then once I give a quick stab of the throttle or downshift, I'll get that "pop" that sounds like the exhaust valves opening (which is really the AFM) then it goes back to V8 mode and and stays there no matter how gingerly I operate the throttle from there on out. There's really no need for a range device or software to disable AFM you just need to keep it in manual mode.
bdavies11 is offline   Reply With Quote
Old 03-19-2018, 03:21 PM   #12
thomaswatk
Thanks for all the replies. I'll try the manual mode, which I seldom use unless I'm in the mountains, and see how that works.
Old 03-19-2018, 06:13 PM   #13
GroundhogSS
GroundhogSS's Avatar
Aren't there separate AFM valves in front of the cats separate from the NPP valves that will still open and close?
Richard
Delivered: 08/15/2016
#TeamBeckyD
Old 03-19-2018, 06:30 PM   #14
grampa_ss
grampa_ss's Avatar
Yes. Completely different. I have fuse 51 pulled too. The NPP valves always stay open. But those !@$# AFM valves I hear when it goes into V4 mode. It's a muffled sound..sounds like the car is "bogging". I think if I delete the sound tube it won't be as noticeable.
