Old 02-23-2018, 08:41 PM   #1
DirectTo
DirectTo's Avatar
Drives: Sold!
Elite catch can install
Anyone have good pictures of how you hooked in the lines?
The Elite website has nothing about the can on the V6, only the clean side, and the can that's shown in the pictures for the clean side doesn't even mount the same way as the can I received from them.
I've got that hard plastic line that runs from the rear of the engine to the intake tube, and before I start trying to remove that from the tube I want to know if anyone has suggestions for how they did it. The lack of instructions from EE is quite frustrating to be honest.
Thanks.
DirectTo is offline   Reply With Quote
Old 02-23-2018, 10:10 PM   #2
KirkH
I have a YouTube video of the install.
https://youtu.be/d8XriT0JIvo
Old 02-24-2018, 12:53 AM   #3
DirectTo
DirectTo's Avatar
Drives: Sold!
Thanks Kirk, I've watched that in the past. So you just cut the hard line from the rear of the engine to the intake and spliced it in? I'm guessing that's what I'm going to end up doing eventually.
For the bolt where you mounted the can mounting arm, do you know the torque value or did you just go until it felt good? I assume you just have the sound tube pressed out of the way and not secured?
Thanks for the info, and the video. It's helped so far.
Old 02-24-2018, 02:24 PM   #4
KirkH
Yes you are just putting the can inline.
I just tightened the can bolt til it was snug. It has stayed tight.
Yes I just moved the sound tube around. I think it is secure where I tucked it.
Old 02-24-2018, 06:49 PM   #5
KirkH
I’ll be glad to go take pictures if you need them.
Old 02-24-2018, 10:16 PM   #6
DirectTo
DirectTo's Avatar
Drives: Sold!
I picked up a little extra hose in 5/8” and got it done. Thanks for the video, just knowing where to place it helped a lot.
Old 02-25-2018, 02:30 AM   #7
zryan
zryan's Avatar
Drives: 1973 z28 Rs, 2018 SS 1LE
LOL, pretty sure i did it right lmao. I empty the valve every 2k or so miles and get a little bit of dirty oil.
2018 HBM SS 1LE Built 7/26: Black emblems, Smoked reflectors/lights, Dimple magnetic drain plugs, Carbon rock guards, Carbon fuel door, Elite Engineering Catch-can, BMR strut-brace,
zryan is offline   Reply With Quote
Old 03-01-2018, 03:02 PM   #8
Billabongi
Billabongi's Avatar
Drives: '17 SS 50th Camaro
You have to drill and tape the manifold on the v6?
2017 50th Anniversary 2LT\RS - #1583 SOLD
2017 50th Anniversary 2SS - #3410
Billabongi is offline   Reply With Quote
Old 03-01-2018, 04:10 PM   #9
Kairles
Kairles's Avatar
Drives: 2015 Camaro 1SS
Think he did that because he has a 2 port can. I always thought 2 ports where more for boosted applications.
Kairles is offline   Reply With Quote
