Old 02-15-2018, 11:32 PM   #1
KirkH
DIY Wheel scuff repair
I scuffed up my rims recently. I have the RS 20" silver spokes wheels. The scratches were pretty deep into the metal.
Tools needed:
Dremel tool
Dremel #952 cone shaped aluminum oxide grinding stone
Dremel #413 sanding disc
Materials:
Body filler $12.99
Touch up paint Duplicolor Subaru 262 Quicksilver $9.99 for the Camaro OEM silver rims
sand paper 1500, 2000, 3000 grit $1 sheet
Wheel cleaner, degreaser
First: clean, clean. clean. Clean as you go along as well. The surface must be free of grease and dust.
I will focus on this one spot for the write-up.
I started with the #952 cone shaped aluminum oxide grinding stone and a Dremel tool. Speed set at 5. Grind down the burrs the best you can. It doesn't have to be perfect, just rounded off the best you can.
Change attachments to the #413 sanding disc and try to shape the rim.
Mix up a little bit of body filler.
Spread the body filler evenly over the scratched area and let dry 1-2 hours until hard. Work quickly, the body filler hardens fast.
Use the #413 sanding disk to sand down the body filler as evenly and perfectly as possible. Use the sander to shape the body filler to match the rim.
Sand with 1500 grit, 2000 grit and 3000 grit sand paper wrapped around a pencil. Be careful not to sand outside the repair area. If you do, you will need to polish that area after the paint has cured.
Clean and remove any dust to prepare for paint.
This paint matches great!
Smoothly paint the repaired area.
Apply the clear coat and allow to dry.
I will need to polish out some scratches from the sand paper where I messed up. It's not perfect, but it looks much better!
If anyone has questions I will be glad to answer them.
Old 02-16-2018, 06:12 AM   #2
Soleil
Soleil's Avatar
Wow, well done my friend looks pretty good.
Soleil
Old 02-25-2018, 10:19 AM   #3
EagleRS
EagleRS's Avatar
Drives: Nightfall Grey 2.0L Turbo
Tools needed:
Dremel tool
Materials:
Body filler $12.99
They look great and kudos on doing it yourself. If I have the grey RS wheels, what color code is that? I know there are the 2 finishes silver and grey split 5 spoke.
Thanks a lot...
EagleRS is offline   Reply With Quote
Old 02-25-2018, 01:36 PM   #4
KirkH
Thanks! I think i can get better at this with some practice. I learned a lot.
Thanks a lot...
Here's what you do...Autozone will let you return touchup paint that doesn't match if you haven't used much of it. That's how I figured out that the Subaru paint matched the silver wheels so well. Try to find a match at Autozone.
Old 02-25-2018, 02:17 PM   #5
DirectTo
DirectTo's Avatar
Drives: Sold!
Damn, nice job.
DirectTo is offline   Reply With Quote
