Old 02-05-2018, 11:36 PM   #1
homsangpradit
Drives: '17 Camaro SS 1LE
Whipple Off the shelf/ stock tune, any good?
Hi guys/gals, I am going to be ordering a Whipple 2.9 for my 1LE in a few months and wanted to see if other have been using the tune that comes with the kit that whipple sells. If so, are there any issues with what's provided, or should I just get the tuner kit and have it tuned after install? (I want to do my own install regardless.)
This is the only performance mod I intend to put on the car.
2017 Krypton SS 1LE.
homsangpradit is offline   Reply With Quote
Old 02-05-2018, 11:41 PM   #2
ninetres
ninetres's Avatar
Drives: Crush ZLE M6 | 2000 Corvette FRC
Have it tuned by CMS. He isn’t all that far from you. The Whipple tune won’t be nearly as good.
ninetres is offline   Reply With Quote
Old 02-06-2018, 07:30 AM   #3
oneredry
HYPER SS
oneredry's Avatar
Drives: 2016 Supercharged 2SS
needless to say, any boosted (from the factory) applications are pretty conservative. For a reason of course.
Ordered: 1/15/2016
2000 status 02/01/16
3000 status 02/29/16
3400 status 03/07/16 TPW of 03/14/16
4200 status 03/17/16 in transit!
Delivered 03/23/16
2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points.
| AWE touring - resinated catback with link pipes.
oneredry is offline   Reply With Quote
Old 02-06-2018, 07:47 AM   #4
chross12
chross12's Avatar
Drives: 2016 ss whipple,rotofab,A8,magride
i had added a cold air box as well as the whipple and the factory tune was very rich and it showed detonation on the dyno. I had a local kid who doesn't have a lot of experience go step by step to remove it and it ran a lot better. I will say their customer service is great. The expansion tank in the kit was cracked. They sent a new one out the next day. They also sent the wrong thermostat, same thing next day a new replacement in the mail. We returned the wrong stuff back to them. Other than those issue its an awesome deal. I blow the tires off at 20 mph or 120 mph....
chross12 is offline   Reply With Quote
Old 02-06-2018, 09:33 PM   #5
Epx998
|Engineer|
Epx998's Avatar
Drives: 2016 Camaro SS
So all you'd change is the tune?
Epx998 is offline   Reply With Quote
Old 02-07-2018, 08:38 AM   #6
brettman
That is the key sometimes, If it's done right.
The tune to match the build. I had mine tuned by a "professional" company (so they advertise) I had it re-tuned by a "PRO". I think his neck still hurts from shaking his head so much. My car runs GREAT now, all from a correct tune. (dyno numbers coming in spring)
brettman is offline   Reply With Quote
Old 02-07-2018, 10:57 AM   #7
chross12
chross12's Avatar
yes the factory whipple tune had detonation as well as a very rich tune. I live at sea level so that may have had something to do with their rich tune. I also added a cold air inductions air box. Which took all of twenty minutes. I also ordered the sound delete option which removed some weight from the front end of the engine. a plus for sure.
I had a kid with little experience and he put a better tune in it. The bottom end torque will blow the tires off the car. It's so fun to drive. Just need to get it to hook.
Old 02-07-2018, 01:57 PM   #8
JANNETTYRACING
JANNETTYRACING's Avatar
The Whipple calibrations are pretty good, but they will not work when combined with any aftermarket parts like cold air kits and LT headers.
I offer Remote tuning services and can take the calibration to the next level and tune for aftermarket parts to get your combination dialed in.
All you need is JRE, custom tuning, a wide band AFR gauge and Free Logging software from SCT/Bullydog and your on your way to a perfect tune.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 02-07-2018, 03:54 PM   #9
Boost or bust
Drives: 2018 ZL1 M6
Ted- I spoke with you a few days ago. This is wht I plan to do and may be making the drive from Cali out to your shop this year. My sis is next door in NY, so what the heck, right? Once I have timeframe, I’ll order the kit up. FYI, Whipple said the CARB certification should be approved in about 3months.
Boost or bust is offline   Reply With Quote
Old 02-07-2018, 04:13 PM   #10
JANNETTYRACING
Awesome, I look forward to working with you.
Old 02-08-2018, 01:12 AM   #11
boostednut
Drives: Nothing cool atm
If I were to do hp tuners through you, what do I need to buy? Also, how do you recommend logging? Mexico pulls in 1:1 gear? I like your system, I think it's great. I'm not at that stage yet, but I like to have all my chickens in a row.
boostednut is offline   Reply With Quote
Old 02-08-2018, 07:38 AM   #12
JANNETTYRACING
I would set you up with HPtuners cable, AEM AFR gauge, gauge pod.
Contact me when ready at tedj@jannettyracing.com
Thank you
Ted.
