Old 01-29-2018, 11:23 PM   #1
RedDragonSS2.0
RedDragonSS2.0's Avatar
Drives: 2017 Summit White Camaro SS 1LE
Anyone lower there 1LE?
If so what brand springs did you go with? Please post up part numbers as I am looking to kill some wheel gap... I parked next to some lowered cars and felt like I was driving a truck lmao this is not my daily so figured why not enjoy it!
Thanks
PLEASE DO NOT COMMENT WITH THE OMG WHY WOULD YOU LOWER A 1LE!!!!
Rotofab Intake, Borla 60606 Midpipes, Corsa Extreme Axleback
RedDragonSS2.0 is offline   Reply With Quote
Old 01-29-2018, 11:56 PM   #2
JamesNoBrakes
JamesNoBrakes's Avatar
Drives: 2SS 1LE
What would be enjoyable about increasing the spring stiffness to overpower the dampers and decrease the ride, handling, etc?
I'm not asking why would you lower it, I'm asking why would you do this without managing the effects on the damping?
2018 2SS 1LE
2023 Colorado ZR2
2022 Stinger GT-line AWD
JamesNoBrakes is offline   Reply With Quote
Old 01-30-2018, 12:28 AM   #3
Cgocifer
Cgocifer's Avatar
Drives: 2018 1SS 1LE, 2015 RAM Ecodiesel
I would not lower or mess with the 1LE. It's handling is pure magic the way it is and the stance is great. It's probably the only "stock" car I've never wanted to lower. However, I have a 2018 and I've heard that Chevy lowered it a bit from the earlier 6th gen versions but I'm not sure.
Cgocifer is offline   Reply With Quote
Old 01-30-2018, 08:20 AM   #4
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
Coilovers
J-Rod Built and Matt@FSP Tuned
ST1LE is offline   Reply With Quote
Old 01-30-2018, 09:41 AM   #5
Cgocifer
Cgocifer's Avatar
Originally Posted by ST1LE View Post
Coilovers
You would lose the magnaride.
Old 01-30-2018, 09:49 AM   #6
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
Yup. Only way to lower in my opinion though.
Edit: To each their own of course, and street driven v track driven matters a great deal in decision.
I lowered my 2013 1LE, and it certainly compromised the handling characteristics for track use. Street was fine.
Old 01-30-2018, 11:03 AM   #7
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
any springs with work with mrc will work i have seen people put eibach and bmr and a few other brands on the 1le but i would wait for the powell raceshop yyz springs to be released.
Old 01-30-2018, 11:58 AM   #8
mggeyer
Drives: 2017 hyper blue ss 1le
Wow, another guy who knows more than Chevrolet engineers , who tested & tested and tested. Genius! One if the finest handling automibiles you can buy and your going to jack with what engineering experts totally nailed! Brilliant. Car show guys are just comical.
mggeyer is offline   Reply With Quote
Old 01-30-2018, 12:20 PM   #9
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
Why not bags?
Old 01-30-2018, 12:35 PM   #10
TEX1LE
Drives: 2017 1LE - Blue
I have BMR lowering springs. It doesn't mess with magna ride and it handles great. Don't get caught up in the hype that this car is flawless from the factory and can't be improved with mods.
TEX1LE is offline   Reply With Quote
Old 01-30-2018, 01:10 PM   #11
Mr Bill
Mr Bill's Avatar
Drives: Camaro 1LE 2017
Pictures please
Mr Bill is offline   Reply With Quote
Old 01-30-2018, 03:15 PM   #12
AZ_1LE
Drives: 2019 ZL1 1LE
You're choosing to forget that GM still has to design in some "comfort" into the car, so there is a real hazy line that is between better handling, and comfort. Go any lower and the front end will scrape way more going into parking lots, and the ride is going to get stiffer. They found an amazing balance between the two, and it's up to you to make improvements (which there are plenty to be made). Solid or poly subframe and suspension bushings, free-er flowing exhaust, lowering the center of gravity with shorter, stiffer springs, better brake pads, depends on how wild you want to go with it. But there are always going to be consequences with every modification, some small, some bigger.
And yes, you CAN ruin a car, but lowering it a little bit isn't going to hurt it much as long as you go with good quality parts and do it the right way.
Old: 2017 SS 1LE
Old: 2017 ZL1
Current: 2019 ZL1 1LE
AZ_1LE is offline   Reply With Quote
Old 01-30-2018, 03:32 PM   #13
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
Well said sir! /thread
Old 01-30-2018, 04:02 PM   #14
WhyUMad1LE
Drives: 17 SS 1LE
omg why would you lower a 1LE
