Old 12-10-2017, 07:07 PM   #1
Beasley91
Drives: 2016 Summit white 1SS 6MT
My experience after nitrous for over a year.
Ok guys, I’ve had a lot of questions on how nitrous on a 6th gen camaro holds up on our cars. So before I swap over to turbo I figured you guys would like to hear from someone who has actually beat the hell out of one of these cars directly, then from people that think it doesn’t work. Now if you blow your car up out of pure stupidity, that is on you, not me. My car is a 2016 1ss 6 speed and has been on no less than a 150 shot for over a year, and on a 200 shot and e85 for around 6 months with a nitrous express plate kit. Car consistently goes mid 10’s at 135+ and hold the record for 6MT 6th gens. First thing I always hear is on stock fuel system out car runs out of fuel. That is false. Unless mine is a freak in some way which I highly doubt lol. Even like the car is Your tuning is what is going to make or break your car as to what usually breaks car. Mine is tuned on e85 through HPTuners, no flex fuel sensor, 36 degrees of timing. Only problem i have had is axle issues, usual downfall to IRS. We also turn the car to 7300 rpm on a factory sealed engine, stock trans, clutch, rear end, etc etc. Only upgrades are a rotofab CAI, muffler delete, cat delete, lingenfelted timing control, and innovate PSN-1 wide band. Plugs i run are LTR7-IX and are the best choice i have found. Guys, our cars love nitrous, even with the tight ring gap. One of the benefits to the direct injection is keeping the piston cool enough to really not have to worry about popping the piston.If you have any questions, feel free to message me.
Beasley91 is offline   Reply With Quote
Old 12-10-2017, 10:13 PM   #2
Turbo_RORO
Turbo_RORO's Avatar
Drives: Camaro 17 SS
Thanks for posting this. You were one of the guys that I reached out to when I first started to spray my car. I was also surprised when I didn't have fuel supply issues. I did usually spray 150 even on E85. I run the same plugs, just not as much timing. What are your plans for the turbo? Are you going to start a build thread?
Turbo_RORO is offline   Reply With Quote
Old 12-10-2017, 10:20 PM   #3
Beasley91
Thank you sir, I’m sure I’m going to once it starts
Old 12-10-2017, 10:31 PM   #4
Turbo_RORO
Turbo_RORO's Avatar
Are you going to build it or buy and bolt on?
Old 12-11-2017, 05:58 AM   #5
laynlo15
Drives: 2022 Lt1 A10
Dam Beasley I thought you had disappeared. Glad your having good luck with the NOS.
Old 12-11-2017, 11:28 AM   #6
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
36 degrees timing with a 200 shot? or you saying 36 degrees before spraying? If so how much timing do you pull?
Old 12-11-2017, 11:57 AM   #7
Turbo_RORO
Turbo_RORO's Avatar
In all honesty it is not that much. The usual rule of thumb is what I went with. 2* per 50 hp of nitrous applied. So a 200 shot will only have you pull 8* of timing. My E85 tune was usually in the mid to high 30s. so even on nitrous that would keep timing in the 30s to high 28*. But I don't remember going that high honestly. Even now on boost with E85 I run 24-26* timing. But I can speak for Beasley.
Old 12-11-2017, 12:44 PM   #8
grampa_ss
grampa_ss's Avatar
Which exact Lingenfelter timing control did you use? Was it the LNC-2014
Thank you
Old 12-11-2017, 05:50 PM   #9
Turbo_RORO
Turbo_RORO's Avatar
I don't know what Beasley uses. I don't use a box. I change my timing in my tunes.
Old 12-12-2017, 01:50 AM   #10
hitmix300
2016 loaded 2SS
hitmix300's Avatar
Drives: Maverick X3 Turbo R
Thank you
yeah, that's the component.
hitmix300 is offline   Reply With Quote
Old 12-13-2017, 09:28 AM   #11
KingLT1
KingLT1's Avatar
The best rule of thumb is to read the plugs and give the engine what it wants. However yes 2 degrees per 50 is the standard. I am surprised these engines can take that much timing. I thought 29-30 degrees NA on E85 was max for Wot spark around peak tq. Either way thanks for sharing your thoughts!
Old 12-15-2017, 06:06 AM   #12
PRAY
PRAY's Avatar
Drives: 2016 2SS
It is very interesting to me the amount of timing you are running. I have tested timing in N/A cars on E over and over and over again on the dyno and at the track. The cars never make any more power on the dyno past 26*-27* and never run any faster at the track. I have run up to 30* and in some cases it has cost us time at the track. The car's don't knock but they don't make any more power or go any faster. I have ssen them knock if you go below that. I try to target 13.0 on E and have run it all the way down to 12.3 or so to possibly take advantage of more timing. Pretty amazing that you are up to 36*.
Old 12-15-2017, 11:46 AM   #13
Turbo_RORO
Turbo_RORO's Avatar
Pray, I'm not sure if you were talking to me but I will point out that I use different types of "E85". I have posted this in other threads before. But the actual octane content of C85, E98, X98, FTW Purple are very different than the pump stuff. I am sure that you are aware of this. What have you found as the max power timing and AFR for some of the higher end race fuels? Also I don't know AFR so this is a genuine question. I use Lambda as I try many different fuels.
Edit: just re-read the thread. Seams you weren't addressing me. But I just want to keep this thread alive as nitrous builds are few and far between.
Old 12-15-2017, 11:59 AM   #14
PRAY
PRAY's Avatar
Drives: 2016 2SS
I was referring to the OP but he didn't respond on FB either so I appreciate your input.
I will admit that the only alternate E85 I have used is the FTW brand. And yes, it bumped content to 95+% and it didn't make any more power than pump. But it seems that I didn't lean on it hard enough. My target AFR in lamda is .89. I am curious about C85 though. I have some customers asking me about it but I don't talk or speculate about things I don't know about. The deal with target AFR/Lamda/EQ is how you have you WB configured. I leave mine configured for AFR and use that regardless of the fuel. (I can see Ted Jannetty (sp) rolling his eyes right now.) But it works for me so I stick with what works.
This thread does need to stay alive cause the guys using nitrous are flying but it still really hasn't caught on around here.
