Old 11-23-2017, 04:00 PM   #1
Adampau123
Drives: 2017 Red Hot 1SS 1LE
Zzp large throttle body
Lately have been super on the fence about whether or not to pick this up and really considering it for Black Friday. Just wanted to hear peoples experiences and thought about the throttle body and if it's a worth while purchase. Thanks everyone.
Adampau123 is offline   Reply With Quote
Old 11-23-2017, 04:22 PM   #2
Evil-Bee-NH
603 Camaros
Evil-Bee-NH's Avatar
Drives: 2017 NGM I4 1LT Coupe
Just helps the airflow a bit doesn't add any extra power that you'll feel.
Old 11-23-2017, 04:44 PM   #3
Ashium
Drives: Camaro 2.0t, 300zx TT, LSTT Mustang
Probably not worth it unless you have the intercooler kit.
Ashium is offline   Reply With Quote
Old 11-23-2017, 04:59 PM   #4
Adampau123
Now I'm even more on the fence guys 😂 Might get it anyway as I plan on making more power with the car. Hoping to get to the 350 wheel mark but not too sure how to go about it without bigger turbo looks like turbo needs to be upgraded for those numbers..
Old 11-24-2017, 02:29 AM   #5
ChicagoTommy
Drives: 2017 Camaro; 2017 Acadia Denali
If you're gonna get it, then just get it now while you can save some dough. Personally, to me, it's one of those last needed mods once you already have everything else. It's not a big gain, but the stock t/b becomes a bottle neck once you start making real power. Hopefully that makes more sense. If I was you, I'd go with the intercooler that is marked down to $559!!! That's a smokin' deal.
As far as 350whp goes, you don't need a 'bigger' turbo. Your stock turbo can get you past 350whp just fine. You do need to modify your turbo with different intake and exhaust wheels. Jason@JacFab and I have discussed this in depth several times at this point. Buy some upgraded wheels from Kinugawa, that would only cost around $250, then have your turbo rebuilt locally. A rebuilder should only charge around $300 to rebuild with the Kinugawa wheels, fresh bearings, and balance. BALANCING is KEY! Remember that your turbo spins in excess of 100k RPM!
This is in no way a personal attack or confrontation, and is not necessarily the view
of the management or sponsors, and the thoughts contained herein are mine,
and is not intended to hurt anyone's feelings or ruin their delicate self esteem, or
to invalidate anyone's personal views or thoughts, nor is it a condemnation of anyone's
race, religion, sex, sexual preferences, handicaps, or intellectual abilities.
ChicagoTommy is offline   Reply With Quote
Old 11-27-2017, 10:40 PM   #6
dpelow07
Drives: ats
the throttle body is just off a 2.5l motor right?
dpelow07 is offline   Reply With Quote
Old 11-28-2017, 01:09 AM   #7
Evil-Bee-NH
603 Camaros
Yes
Old 11-29-2017, 11:04 AM   #8
Zzsteve
Zzsteve's Avatar
Drives: 2018 2SS
Originally Posted by Evil-Bee-NH View Post
Yes
our TB's are not just straight off the shelf. we actually modify the outlet of them
Zzsteve is offline   Reply With Quote
Old 11-29-2017, 11:48 AM   #9
Jason@JacFab
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
Thanks for finally clarifying.
Old 11-29-2017, 04:02 PM   #10
Adampau123
After installing it the main difference seems to be throttle response but not much more than that. Maybe something in the tune can be changed to take more advantage?
Old 11-30-2017, 03:34 PM   #11
Start The Machine
Start The Machine's Avatar
Drives: 2016 M6 2.0T
Can you please elaborate more on this?
RS Package, HD Cooling Package, Brembo 6 Piston Front Brakes, SRP Racing Pedals, Soler Performance Throttle Controller, Dyno Tuned by Trifecta, Velossa Tech Ram Air, Mishimoto Intake, aFe Air Filter, Mishimoto Charge Pipes, ZZP 67mm Throttle Body, Trifecta T40 Stage 2 Turbo, JacFab Recirculation Valve, PTP Turbo Blanket, ZZP Catted Downpipe, Mishimoto Pro Cat-Back Quad Tip Exhaust, Mishimoto Catch Cans, Mishimoto Coolant Reservoir Tank, GM SEMA Grill, RPI Designs SS 1LE Front Fascia Extension, Ikon Motorsports 1LE Spoiler, American Authority ZL1 Side Skirts, AMPP Quad Tip Rear Valance
Start The Machine is offline   Reply With Quote
Old 11-30-2017, 03:53 PM   #12
Michigan1LTRS
Blessed ❤️
Michigan1LTRS's Avatar
Drives: 2017 1LT RS I4
Im thinking they port it some.
Old 11-30-2017, 04:20 PM   #13
Jason@JacFab
If they do it's only on the back side judging from the pictures. Probably toss it in a mill and open the very back up 2mm to match the intake manifold inlet... Just a guess
Old 03-23-2021, 07:52 PM   #14
Jsmalls8212@gmail.com
Drives: 2019 camaro 1lt RS
Ltg larger throttle body!
I have recently installed the ltg Throttle body and it definitely makes a diffewnce mainly in throttle respone. That was the last part I installed after doing cai, catless downpipe, full exhaust, glass packs and tune then I did intercooler and last was the larger throttle body.
Jsmalls8212@gmail.com is offline   Reply With Quote
