Old 11-04-2017, 08:57 PM   #1
Hyperlinkblue
Drives: 2017 1ss m6. Blue.....
Tr6060 tail shaft support bearing upgrade?
Hi, i know the 5th gens did not come with the tail shaft support bearing and it was an upgrade, heres a link with the how to about half way down http://www.camaro5.com/forums/showthread.php?t=390234
I was wondering if the 6th gens with the tr6060 come with the tail shaft bearing?
Hyperlinkblue is offline   Reply With Quote
Old 02-20-2021, 05:11 AM   #2
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
So later model 5th Gens had the support bearing so the 6th Gens should.
Orange Krush II
1LE Front sway bar, Splitter, shocks and struts, Z28 dual mode mufflers, Intake, UCA Bushings, and Toresen 3.91 Diff. 1 piece DSS Drive Shaft, ZL1/C7 Calipers, and 32mm JPSS Rear Bar. ASC race spec splitter and wicker. 6th Gen M017 Wheels. Stainless Works 1 7/8 LTs. DSE and PAFDT Suspension components.
olblue75 is offline   Reply With Quote
Old 02-20-2021, 11:33 AM   #3
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
yup, i had a '13 1LE. it had the tail shaft support bearing
Old 02-21-2021, 10:22 AM   #4
Jhunsberger
Jhunsberger's Avatar
Drives: 2017 Camaro 1SS M6 (SOLD)
I am pretty sure the 6gen TR6060 does NOT have a tail shaft support bearing. I just had my 6060 rebuilt and when reviewing what went wrong and options for the rebuild this support bearing came up. It was said the shaft and case are all machined for the bearing but GM just didn't opt to put one in. Now this 6060 is from a 17 SS, so idk if the ZL1's have them or not, but mine did not.
My trans was in great shape considering the car makes 650+ rwhp and has 50+ passes at the track on it. The plastic shift fork pads showed some abuse for 1-2 & 2-3. The clutch was also in pretty good shape.
The trans locked up because the 2 round magnets in the bottom of the case came loose, got chewed up in the case and jammed it up. The Tremec trans shop said they never seen this happen before, go figure. But a thorough cleaning in a few replaced parts and I am good to go. Just been waiting 2 months for my McLeod RXT clutch, should be here this week.
Jhunsberger is offline   Reply With Quote
