Old 11-03-2017, 04:14 PM   #1
Blazin383
Blazin383's Avatar
Drives: 2016 SS
Rear Differential Signs of Trouble
Got in the SS today for the first time in a while. My wife drives it on a daily basis and it's got almost 10,000 miles on it now. As I backed it out of the garage and turned into the street, I felt/heard a grinding sound and it felt like one of the rear tires was skidding a little. As I drove it I consciously did some slow hard left and hard right maneuvers and several times felt something just odd about how the weight transfer from side to side felt, and a few times got that rear tire skidding sound again at parking lot speeds.
Is this a sign of the differential problems I've read about some having?
Blazin383 is offline   Reply With Quote
Old 11-03-2017, 05:29 PM   #2
awpti
awpti's Avatar
Drives: 2017 1SS Camaro; 2016 4Runner
Take it to the shop. ASAP.
awpti is offline   Reply With Quote
Old 11-03-2017, 10:32 PM   #3
JaxChris
If the groan and frozen wheel happen more on cold, low speed right turns, it is the rear diff, many of us have had it happen. Dealer should easily find the TSB. They'll need to flush your pumpkin.
Old 11-04-2017, 12:42 AM   #4
camaro5
camaro5's Avatar
Drives: X-15 Velocipede
Change the differential fluid.
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer
STANDARD DISCLAIMER
camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever,
whether express, implied, or statutory, including, but not limited to, any warranty of merchantability
or fitness for a particular purpose or any warranty that the contents of the information will be error-free.
camaro5 is offline   Reply With Quote
Old 11-04-2017, 09:58 AM   #5
camaromike77
camaromike77's Avatar
Drives: S O L D
I agree....
Club F1FTY
Old 11-04-2017, 10:01 AM   #6
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Change the diff fluid with Delco 75w-90...it will make it be better but it's never going to go completely away. On cold days, for the first couple turns, it will make noise.
Old 11-04-2017, 07:00 PM   #7
98_Camaro
98_Camaro's Avatar
Drives: 2016 2SS Coupe
Mine does exactly this, so it's good to know it's normal.
Gone but not forgotten:
1998 Bright Purple Metallic Camaro
2012 Carbon Flash Metallic 2SS Convertible
2016 Summit White 2SS Coupe M6, NPP, & MRC
Now Driving:
2016 Torch Red Corvette 2LT, NPP, MRC
98_Camaro is offline   Reply With Quote
Old 11-06-2017, 12:07 AM   #8
Marty McFlew
Drives: 17 SuperSport Camaro 6 on the Flo'
Mine doesn't. Why is it normal.
Marty McFlew is offline   Reply With Quote
Old 11-06-2017, 11:58 AM   #9
cignul9
cignul9's Avatar
Drives: 50th 2SS MRC A8 NPP
It's totally not normal. There's a TSB, and the dealer will flush and refill the diff to fix it. If it doesn't go away, they'll replace the diff. I just got mine back from the dealer on Friday for this same issue.
Club F1FTY
50th 2SS, MRC, NPP, 8A, #991
Join the Club F1FTY Registry!
Add yourself to the registry here.
Read the registry here.
cignul9 is offline   Reply With Quote
Old 11-06-2017, 12:03 PM   #10
Blazin383
Blazin383's Avatar
Drives: 2016 SS
Guess I’ll be calling my dealer today!
Old 11-06-2017, 09:17 PM   #11
JR91
Drives: Camaro 1SS
I heard this problem eventually comes back even after replacing the differential. Is this true? I am having the same issue, but I don't want to take it to the dealer just to have the issue happen again.
JR91 is offline   Reply With Quote
Old 11-06-2017, 09:45 PM   #12
Blazin383
Blazin383's Avatar
Drives: 2016 SS
What choice do we have? I'm assuming that left unfixed it will just get worse until it lets go completely or grinds itself to pieces. If its a design issue across all units they'll have to come up with a permanent fix eventually! I hope!
Old 11-07-2017, 10:35 AM   #13
KingLT1
KingLT1's Avatar
It's not normal but I am not sure it's as big of deal that some make it out to be. The clutches are setup tight in the LSD and when cold you get a little noise on the first couple turns. Just warm it up before throwing it hard into turns and change the fluid regularly and it should be fine. If the diff made the noise all the time and did not go away, then I would be concerned. I am not saying it's right, but I can tell you the last place I want to take my car is the dealer unless absolutely necessary.
