Old 10-18-2017, 01:27 PM   #1
JIMB123
Drives: 2017 Camaro Black 2ss 50th ann. pkg
2017 Camaro 2SS - silent throttle when driving
Hey ya'll. Got my 2017 Camaro 2SS (8spd auto) with the Performance NPP package.
I notice that sometimes when I'm driving (slow or fast), putting the car into Neutral and hitting the gas makes NO NOISE at all (even in Track or Sport mode). I can see the RPMs going up on the dash so it's working - just no noise. If I put it back into Drive and then neutral a few times it will eventually Roar. Guys in Mustangs constantly pull up beside and rev their engine but mine only works 50% of the time - maybe less. When I'm idle at a light, it works every time.
Chevy Dealer said revving the engine in Neutral while driving down the street "confuses the computer" and the car isn't meant to do that. Seems no one else has this issue.
Is the dealer correct?
JIMB123 is offline   Reply With Quote
Old 10-18-2017, 01:55 PM   #2
Rusty35
Drives: 2013 ZL1
Are you sure the folks beside you have automatics?
Or are they just pushing the clutch in and revving the engine?
Rusty35 is offline   Reply With Quote
Old 10-18-2017, 02:12 PM   #3
Magnum922
Magnum922's Avatar
Drives: 2017 Camaro 2SS, A8
I have a 2ss with npp. Mine makes a nice loud roar in track and a quieter roar in silent evertime I rev in in neutral or park. I especially do that while going under a bridge. The rpms are close to 4000.
Magnum922 is offline   Reply With Quote
Old 10-18-2017, 02:14 PM   #4
awpti
awpti's Avatar
Drives: 2017 1SS Camaro; 2016 4Runner
You shouldn't coast in neutral anyway.
1. It's a safety hazard (you've lost a part of your control over the vehicle)
2. Illegal in 15 states
3. Modern cars shut off the fuel flow, allowing the tires to run the engine when coasting. That's right, you'll get better economy by staying in-gear and coasting.
I'm calling bullshit on the claim that it "confuses the computer".. that's an exception state in a computer and indicates a severe failure.
Pull your NPP fuse
awpti is offline   Reply With Quote
Old 10-18-2017, 02:30 PM   #5
Need4Camaro
Drives: '17 Camaro 2SS & '99 Camaro Z28
Pull your NPP fuse
Only time I use Nuetral is when I'm in a skid, sliding on icy surfaces, or a pretty bad Hydroplane - it will help you get out of any of those by cutting power to the rear wheels making it easier to control the vehicle (you're not fighting engine power over no-traction conditions,) thats assuming you havent entered a point of which is simply too fast for these conditions.
Coasting, its best to stay in gear, I actually find when I put it in nuetral, the weight of the vehicle without the resistance of the engine will literally make the car roll FASTER if going down-hill.
Need4Camaro is offline   Reply With Quote
Old 10-18-2017, 05:24 PM   #6
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Huh? You have stability control, which works just fine when you are in gear. There is absolutely no reason to shift a modern auto to N while in motion.
Your "ideas" about driving are from the 1950s.
Old 10-18-2017, 07:41 PM   #7
SSmash
SSmash's Avatar
Drives: Mosaic Black Camaro 2SS
lol damn
SSmash is offline   Reply With Quote
Old 10-18-2017, 08:13 PM   #8
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
dealers say the darndest things
Old 10-19-2017, 01:42 AM   #9
Cool SS
Drives: Black 2017 Camaro 2SS
I believe there is a rev limiter that kicks in around 4k or so on the auto trans. You are exceeding the limit and getting nothing. Try a low slow rev vs. fast flooring the gas peddle and see.
Cool SS is offline   Reply With Quote
Old 10-19-2017, 02:09 AM   #10
JIMB123
You can tell I'm not a auto mechanic or enthusiast.. I just love my camaros. Thanks for all the feedback ya'll.
I do notice the load roar during neutral/rev works alot better at very low speeds but even when going 5mph at times -- hitting gas just doesnt make any sound.
I didn't realize how unsafe it is doing this while driving... I just remember as a kid it was good to go into neutral when coasting and was told "it saves gas". But honestly, I'm just trying to show off when someone pulls up next to me. I haven't upgrade to Corsa or Borla exhaust -- so it's still not as throaty as it could be over stock, but still sounds nice.
I guess that's just how it's gonna be on my car -- maybe it should work, but maybe it shouldn't and either way -- guess it's not safe unless I'm in park. I just wondered if anyone knew for sure why it would work sometimes and other times not. I don't think it has anything to do with 4000 RPMs, given what I said earlier that I can be going through a parking lot at 5mph or less and even then still makes no noise SOMETIMES. Thx everyone for your input. Cheers!
Old 10-19-2017, 08:14 AM   #11
HCGxKaLiBeR
HCGxKaLiBeR's Avatar
Drives: 2018 Audi S4/2016 Carmaro 2SS
There is no load revving in neutral. If you have stock exhaust you need to rev high.
The rev mapping in N is different. You have to step on the gas all the way to bring the rev up.
2SS | NPP | NAV | MRC | Ground Effect | Catch-Can | K&N CAI | DiabloSport AFM/HP tune
HCGxKaLiBeR is offline   Reply With Quote
Old 10-19-2017, 12:13 PM   #12
trboxman
Drives: 2017 2SS, M6, HBM
Should have bought a manual if you wanted to play these games. Silly in either case.
All kinds of barriers to knowledge but no barriers to belief.
trboxman is offline   Reply With Quote
Old 10-19-2017, 01:17 PM   #13
Hasti
Hasti's Avatar
Drives: 2017 Hot Red 2ss Auto adrenaline
................................. this is a terrible idea
Hasti is offline   Reply With Quote
Old 10-19-2017, 01:55 PM   #14
Kise
Kise's Avatar
Drives: 16' 2SS, 06' Silverado SS
a lot of complaining, not too many answers. I just tried it in mine and it worked just fine. not too sure why yours isn't working. I would recommend that you don't do it moving though. I did notice the rpms declined extremely slow a few times which I didn't like at all. maybe try to pull the NPP fuse while in track mode and try that.
Kise is offline   Reply With Quote
throttle silent
